5th September 2011, 14:39 | #1 | Link |
sound not working but video is great
this just started happening lately where most of the newer things i try and convert to avi i get great video but the sound is gone and what is there is this squeeky high pitched noise every once in a while
any idea what i can do to remedy this? and what info do you need to see so that you can help me figure this out? thanks |
5th September 2011, 15:11 | #2 | Link |
First, tell us which program you are using.
AutoGK or genuine GK. Second, post some Log files. Third, post a Mediainfo log of the source file. Did you install a suspicious codec pack lately or some obscure audio drivers/codecs? |
5th September 2011, 17:10 | #3 | Link |
[9/5/2011 11:11:50 AM] AutoGK 2.55
[9/5/2011 11:11:50 AM] OS: Windows Vista (6.1.7601).2 [9/5/2011 11:11:50 AM] Job started. [9/5/2011 11:11:50 AM] Input file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_0.IFO [9/5/2011 11:11:50 AM] Output file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\RIO2.avi [9/5/2011 11:11:50 AM] Output codec: XviD [9/5/2011 11:11:50 AM] Audio 1: English AC3 6ch [9/5/2011 11:11:50 AM] Subtitles: none [9/5/2011 11:11:50 AM] Format: AVI [9/5/2011 11:11:50 AM] Target size: 1120Mb [9/5/2011 11:11:50 AM] Audio 1 settings: Auto [9/5/2011 11:11:50 AM] Started encoding. [9/5/2011 11:11:50 AM] Demuxing and indexing. [9/5/2011 11:12:58 AM] Processing file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_1.VOB [9/5/2011 11:12:58 AM] Processing file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_2.VOB [9/5/2011 11:12:58 AM] Processing file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_3.VOB [9/5/2011 11:12:58 AM] Processing file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_4.VOB [9/5/2011 11:12:58 AM] Processing file: C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_5.VOB [9/5/2011 11:12:58 AM] Source resolution: 720x480 [9/5/2011 11:12:58 AM] Found NTSC source. [9/5/2011 11:12:58 AM] Source aspect ratio: 16:9 [9/5/2011 11:12:58 AM] Source seems to be pure FILM. [9/5/2011 11:12:58 AM] Output will contain 138021 frames [9/5/2011 11:12:58 AM] Using VAQ in XviD [9/5/2011 11:12:58 AM] Audio1 size: 322,370,048 bytes (307.44 Mb) [9/5/2011 11:12:58 AM] Overhead: 959,488 bytes (0.92 Mb) [9/5/2011 11:12:58 AM] Video size: 851,075,584 bytes (811.65 Mb) [9/5/2011 11:12:58 AM] Running compressibility test. [9/5/2011 11:14:20 AM] Duration was: 1 minute, 22 seconds [9/5/2011 11:14:20 AM] Speed was: 83.81 fps. [9/5/2011 11:14:21 AM] Compressibility percentage is: 62.58 [9/5/2011 11:14:21 AM] Chosen resolution is: 656x288 ( AR: 2.28 ) [9/5/2011 11:14:21 AM] Predicted comptest value is: 70.89% [9/5/2011 11:14:21 AM] Running first pass. [9/5/2011 11:34:17 AM] Duration was: 19 minutes 56 seconds [9/5/2011 11:34:17 AM] Speed was: 115.39 fps. [9/5/2011 11:34:17 AM] Expected quality of first pass size: 64.95% [9/5/2011 11:34:17 AM] Running second pass. [9/5/2011 12:02:45 PM] Duration was: 28 minutes 27 seconds [9/5/2011 12:02:45 PM] Speed was: 80.82 fps. [9/5/2011 12:02:45 PM] Job finished. Total time: 50 minutes 54 seconds ==================================================== i use DVDFab to rip the movie, then AutoGK to form the avi, main movie only, thats all i have ever done before and its always worked perfect, lately its hit and miss no new codecs to my knowledge how do i get a mediainfo log of the source file? |
6th September 2011, 02:08 | #6 | Link |
What are you using to play the AVIs? I assume the same program plays all of your older AVIs fine?
In your example above it appears the original AC3 audio was used so there was no audio encoding involved, just video encoding, which would seem to point to the problem being a playback one, not an encoding one. If you're not, try using Media Player Classic-Home Cinema to play the newly created AVI, but first open it's options and under "Internal Filters", make sure everything is checked. That should ensure it uses it's own internal splitters and codecs which will hopefully eliminate a rouge codec on your PC. PS If you open a video file with MPC-HC and use the File/Properties menu, under the MediaInfo tab you'll find the same information MediaInfo would provide only without having to install MediaInfo as a separate program to obtain it. Last edited by hello_hello; 6th September 2011 at 02:13. |
6th September 2011, 12:11 | #9 | Link |
well because your reply doesnt help at all, because i have moved the AVI file to 3 different computers, so it cant be JUST a rogue codec on MY computer
it doesnt work on my desktop, laptop, a mac, or my xbox streaming. so it has to be something during the creation of the AVI or the ripping of the DVD |
6th September 2011, 13:45 | #10 | Link | |
Custom User Title
As mentioned, there is nothing in the log about transcoding the audio so it must have just copied the audio to the new file. Since the file doesn't play with audio on any of your machines, either something went wrong in the muxing process or DVDFab didn't rip the audio properly. To help determine where things went wrong, open each file in MediaInfo and select View > Text to copy/paste here if you can't see yourself what the problem is. |
6th September 2011, 13:53 | #11 | Link | |
You didn't mention any of the above in your OP and the batteries in my crystal ball must have been flat when I asked the questions. I've been using AutoGK for years and years and even if it's just through a bit of trial and error I, and others, could probably have helped you find the cause of the problem, but we can't if you're deciding which questions are helping us to help you and which ones aren't. You've been asked for the info MediaInfo supplies for a problem AVI and given two ways to obtain it, yet still nothing. |
7th September 2011, 12:09 | #12 | Link |
this is from the AVI file, the info from one of the vob files is ridiculously huge, do you want me to make that in several posts?
General Complete name : C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\RIO2.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.09 GiB Duration : 1h 35mn Overall bit rate : 1 633 Kbps Writing application : VirtualDubMod 1.5.4.1 (build 2178/release) Writing library : VirtualDubMod build 2178/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 1 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Custom Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 35mn Bit rate : 1 178 Kbps Width : 656 pixels Height : 288 pixels Display aspect ratio : 2.25:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.260 Stream size : 808 MiB (72%) Writing library : XviD 58 Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 2000 Duration : 1h 35mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 307 MiB (27%) Alignment : Split accross interleaves Interleave, duration : 96 ms (2.30 video frames) Interleave, preload duration : 96 ms Language : English |
7th September 2011, 12:11 | #13 | Link |
just the first vob was huge this is the second and was more manageable
General Complete name : C:\DVD Ripping\MainMovie\RIO\VIDEO_TS\VTS_01_2.VOB Format : MPEG-PS File size : 1 024 MiB Duration : 23mn 6s Overall bit rate : 6 196 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Duration : 23mn 6s Bit rate mode : Variable Bit rate : 5 177 Kbps Maximum bit rate : 9 800 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Scan order : 2:3 Pulldown Compression mode : Lossy Bits/(Pixel*Frame) : 0.625 Stream size : 856 MiB (84%) Audio #1 ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : DVD-Video Duration : 23mn 6s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -588ms Stream size : 74.0 MiB (7%) Audio #2 ID : 189 (0xBD)-129 (0x81) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : DVD-Video Duration : 23mn 6s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -588ms Stream size : 74.0 MiB (7%) Text #1 ID : 189 (0xBD)-32 (0x20) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Delay relative to video : 1s 34ms Text #2 ID : 189 (0xBD)-33 (0x21) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Delay relative to video : 1s 34ms Text #3 ID : 224 (0xE0)-DVD-2 Format : EIA-608 Muxing mode : DVD-Video Muxing mode, more info : Muxed in Video #1 Stream size : 0.00 Byte (0%) Menu |
7th September 2011, 13:46 | #14 | Link |
There's nothing in the MediaInfo info I can see which indicates the audio shouldn't play properly so I guess it's a little trial and error....
First thing I'd do (not that I really think it's anything to do with the problem, but you never know) is update the version of VirtualDubMod AutoGK installed (it's in the AutoGK installation folder) to the last VirtualDubMod release. You can simply copy and paste the new files over the top of the old ones. http://sourceforge.net/projects/virt...od%201.5.10.2/ AutoGK creates a temp folder in the same directory as the output file. In it you'll find the original AC3 audio (and any converted MP3 audio etc). Open the AC3 audio with a media player to confirm it plays correctly. Open it with MediaInfo to confirm the AC3 has the same properties on it's own as it does when inside the AVI. Try ripping the DVD with a different program. RipIt4Me is the one I use (you'll find it with Google and it requires DVD Decrypter and DVD Shrink to be installed). If it's not the ripping where it's going wrong, try forcing AutoGK to convert the AC3 to MP3 to see if it still has the same problem. You can probably run a few different encoding tests on just one of the vob files (copy it to a separate folder) rather than have to encode the whole movie. Running the test encodes using a default (75%) quality setting rather than picking a file size will also speed up the process. If none of the above finds the problem, another thing to try would be to manually remux the original audio into the AVI AutoGK creates and save it as a new file. If you're not familiar with how to do that, I can post instructions. |
7th September 2011, 20:34 | #15 | Link |
@iamkeq
Maybe just post a sample of the vob and the final avi. DGSplit to cut a sample from the vob and for the avi use Virtualdub in Direct Stream modus. Cut at I frames. 5 -10 megabytes should be fairly enough. May I suggest Mediafire as file hoster? No more guessing, just the plain truth Bye |
9th September 2011, 12:07 | #17 | Link |
here is the cut of the vob, for some reson virtualdub wont open the avi bc it cant "locate the decompressor for format XVID"
http://www.mediafire.com/?9pcna4axtbtqa12 |
9th September 2011, 16:33 | #18 | Link | |
May I suggest a nice clean install of Xvid or Helix or FFdshow VFW. If you use ffdshow make sure the VFW decoder is set up correctly. |
9th September 2011, 16:50 | #19 | Link |
I've just encoded your sample to xvid.
Everything's just fine. The sound is loud and clear. All AC3 5/1 channels are running. Encoded to mp3 vbr 128kbs as the next step, and yes it's running too. I give up. There is something on your side totally burked. The best thing is: Download the whole package from Autogk Website. Deinstall AutoGk, deinstall Xvid, ffdshow and /or ac3filter and do a clean install with just the needed components. Good luck! |
