Old 31st July 2020, 08:48   #901  |  Link
pistacho
Sorry this program is over 10 years old and now I just keep it updated. There are no new features planned.
pistacho is offline   Reply With Quote
Old 31st July 2020, 08:58   #902  |  Link
pistacho
Version 2.9.6 (07/31/2020)
  • Updated: x264 encoder to version 161.3018 (r3018).
  • Updated: x265 encoder to version 3.4+14.
  • Updated: Mkvmerge to version 48.0.
DOWNLOAD => BDtoAVCHD_v2.9.6.msi
Old 27th October 2020, 10:10   #903  |  Link
pistacho
Version 2.9.7 (10/27/2020)
  • Updated: x264 encoder to version 161.3027 (r3027).
  • Updated: x265 encoder to version 3.4+30.
  • Updated: Mkvmerge to version 51.0.
DOWNLOAD => BDtoAVCHD_v2.9.7.msi
Old 2nd January 2021, 12:47   #904  |  Link
pistacho
Version 2.9.8 (01/02/2021)
  • Updated: x264 encoder to version 161.3030 (r3030).
  • Updated: x265 encoder to version 3.4+35.
  • Updated: 2D/3D tools to Intel Media SDK 2020 R1.
DOWNLOAD => BDtoAVCHD_v2.9.8.msi
Old 7th January 2021, 01:08   #905  |  Link
KaraokeAmerica
Thank you!
KaraokeAmerica is offline   Reply With Quote
Old 27th January 2021, 02:35   #906  |  Link
ersmiller
Is there a way to get full SBS or TAB resolution? I.e. 3840*1080 or 1920*2160? I'll be viewing the files with a VR headset that is more than capable of the resolution.
ersmiller is offline   Reply With Quote
Old 23rd February 2021, 20:52   #907  |  Link
pistacho
Version 2.9.9 (02/23/2021)
  • Fixed: Conversion fails when source is MKV with FLAC audio and destination is FLAC audio (untouched audio).
  • Updated: x264 encoder to version 161.3048 (r3048).
  • Updated: x265 encoder to version 3.5+2.
  • Updated: Mkvmerge to version 53.0.
DOWNLOAD => BDtoAVCHD_v2.9.9.msi
Old 26th February 2021, 13:03   #908  |  Link
ersmiller
Bump?
Is it not possible to get full resolution SBS video or am I just missing the option in the settings? Is there a command line option maybe?
I've been able to get the result I'm looking for using a series of other programs, but it's a lengthy process. It would be wonderful if I could get full resolution SBS with this program with its more simple and mostly automated process.
Also, I haven't found any other program that gets the subtitles right like this one does and the subtitles this program generates don't line up correctly with the full resolution SBS videos I've been making elsewhere. So it would be wonderful if this would be possible here.
Old 6th March 2021, 11:14   #909  |  Link
pistacho
Maybe there is an option to do what you want although I cannot give you any guarantees:
When the conversion is starting (x264/x265 encoding step) stop it (stop job) and go to the temp folder and look for an .avs file (Avisynth script)
Open it with a text editor and replace the line:
return StackHorizontal(HorizontalReduceBy2(Left), HorizontalReduceBy2(Right))
With:
return StackHorizontal(Left, Right)
Once edited, start conversion again (start jobs). This will create a FULL SBS output.
For more info and examples about 3D SBS / TAB scripts see this thread: http://forum.doom9.org/showthread.php?t=170004
Old 10th March 2021, 07:49   #910  |  Link
ersmiller
With:
It worked! Thank you.
Old 14th June 2021, 10:54   #911  |  Link
pistacho
Version 3.0.0 (06/11/2021)
  • Updated: x264 encoder to version 163.3059 (r3059).
  • Updated: x265 encoder to version 3.5+1 (final branch).
  • Updated: Mkvmerge to version 57.0.
  • Updated: 2D/3D tools to Intel Media SDK 2021 R1.
DOWNLOAD => BDtoAVCHD_v3.0.0.msi
Old 14th July 2021, 09:55   #912  |  Link
pistacho
Version 3.0.1 (07/14/2021)
  • Fixed: Conversion fails when source is MKV with MPEG Audio Layer-2 (mp2) and destination is same (untouched audio).
  • Updated: IMDb scraper to handle new web layout.
  • Updated: x264 encoder to version 164.3065 (r3065).
  • Updated: Mkvmerge to version 58.0.
DOWNLOAD => BDtoAVCHD_v3.0.1.msi
Old 9th October 2021, 09:55   #913  |  Link
pistacho
Version 3.0.2 (10/08/2021)
  • Updated: x264 encoder to version 164.3075 (r3075).
  • Updated: Mkvmerge to version 61.0.
DOWNLOAD => BDtoAVCHD_v3.0.2.msi
Old 23rd November 2021, 19:38   #914  |  Link
robl45
Hello,
Got error message below. Says couldn't init. Possibly problem with hardware decoding? I know there was a way to trick into software decoding but I don't remember, rename a file or something like that? Could you advise on any possible solution?
MVCenc v3.0.0 (64-bit). This tool is part of BDtoAVCHD software.
Intel Media SDK Information:
- API Level: 1.34, Implementation: SW
Source Information:
- Resolution: 1920x1080
- Frame Rate: 24000/1001 (23.976 fps)
Target Information:
- Codec: AVC, Level: 4.1, Profile: AVC Stereo High
- Num Slice: 6
- Num Ref: 4
- GOP: 24-4-0 Open
- Buffer Size: 30000 Kbits
- Max Bitrate: 60000 Kbps
- Bitrate: 30816 Kbps
- Tar. Usage: 4
MVCenc: Can't init encoder
robl45 is offline   Reply With Quote
Old 12th June 2022, 21:20   #915  |  Link
darkio
about 1080i resize to 720p
I suggest to improve bd2avchd to deinterlace into 50p/60p, can be very usefull.
darkio is offline   Reply With Quote
Old 31st October 2022, 11:46   #916  |  Link
pistacho
Version 3.0.4 (10/31/2022)
  • Improved: compatibility with MKV's containing AAC audio.
  • Updated: x264 encoder to version 164.3101 (r3101).
  • Updated: IMDb scraper to adapt to changes on the web.
DOWNLOAD => BDtoAVCHD_v3.0.4.msi
Old 9th January 2023, 10:22   #917  |  Link
pistacho
Version 3.1.0 (01/09/2023)
  • New: On systems with hybrid processors (P-cores + E-cores) running on Windows 11 22H2, the video encoding process is now configured correctly to avoid using only E-cores when the app is minimized.
  • Updated: x264 encoder to version 164.3103 (r3103).
  • Updated: Mkvmerge to version 72.0.
  • Updated: IMDb scraper (again).
DOWNLOAD => BDtoAVCHD_v3.1.0.msi
Old 27th August 2023, 13:03   #918  |  Link
arapaz
Hello,
I have the same problem as ROBL45
Do you have any idea how to make it work ?
arapaz is offline   Reply With Quote
avchd, bdtoavchd, blu-ray ripper, m2ts, ps3
