7th March 2023, 11:00 | #2741 | Link | ||
Now the problem of the characters may be solved. I mean, I think there is another problem now. Now every time I try to load the script, every time I reload it with F5, it shows me a different error... Something very strange. The different errors that are displayed each time I press F5 are the following: Quote:
Thank you very much for everything! |
8th March 2023, 07:28 | #2743 | Link | |
8th March 2023, 09:50 | #2744 | Link | ||||
Every time I run the command, each time it shows me a different error from those I indicated in my previous comment. |
8th March 2023, 10:16 | #2745 | Link |
Big Bit Savings Now !
What happens if you delete the old index file first and then F5 ?
19th April 2023, 00:49 | #2747 | Link | |
there is no such problem in ffms2_6ad7738. |
24th April 2023, 00:35 | #2749 | Link |
ffms2_r1360 (pass: BLxmx6YsVJ03):
- AviSynth: input filenames converted to UTF-8. - ffms2@cf7c4b2; - ffmpeg@7ecf1bf; - libxml2 v2.10.4. Last edited by StvG; 24th April 2023 at 00:38. |
26th April 2023, 20:17 | #2750 | Link | |
27th May 2023, 19:58 | #2751 | Link |
Reading documentation for Avisynth+ i found that to open MP4 need to use function FFmpegSource()
Which is missing in plugin v2.40, spent like hour troubleshooting this before i found this solution. Wish you have provided proper ffms2.avsi that included this function with your plugin v2.40. |
27th May 2023, 20:46 | #2752 | Link | |
That FAQ entry is referring to the old 1.x version of FFmpegSource, which is well over ten years out of date. |
22nd June 2023, 07:44 | #2755 | Link | |
Also if rffmode=1 is fixed, please can you make it set the field order per-frame, since many NTSC DVDs have dynamic field order and even Bob() will not work on them because Avisynth will display frames in wrong order because FFMS2 is not telling Avisynth the field order of the source clip. Test clip: https://rationalqm.us/misc/lainvob.vob Test script: Code:
FFMS2(clip, atrack=-1, rffmode=1) ScriptClip(last, \ """ fieldbased = propGetAny("_FieldBased") parity = GetParity(current_frame) if (!IsInt(fieldbased)){fieldbased = "undefined"} else if (fieldbased==0){fieldbased = "progressive"} else if (fieldbased==1){fieldbased = "bottom field first"} else if (fieldbased==2){fieldbased = "top field first"} if (!IsBool(parity)){parity="undefined"} else if (parity==true){parity = "top field first"} else if (parity==false){parity = "bottom field first"} Text( "_FieldBased: " + fieldbased + "\n" + "GetParity: " + parity + "\n", lsp=0) \ """) To summarise:
7th July 2023, 06:59 | #2756 | Link |
ffms2_r1363 (pass: BLxmx6YsVJ03):
- AviSynth: both GetParity and _FieldBased now can be changed per frame. - ffms2@cf7c4b2; - ffmpeg@4b1969; - zlib 1.2.13; - dav1d 1.2.1; - libxml2 v2.11.4. |
8th July 2023, 13:10 | #2759 | Link |
Please support AviSynth+ r4001 including the audio channel mask.
