14th December 2018, 19:28 | #53881 | Link |
So, I found out why I did not have 10 bit output in either fullscreen windowed of exclusive modes. It was because I had the "native display bitdepth" set as 8 bit in the madVR display device settings. With this configured to 10 bit, I have 10 bit output in both fullscreen windowed or exclusive modes. It's 8 bit only when the player is not playing fullscreen.
I also remembered why I did not leave the "native display bitdepth" setting to "auto" in madVR. It was because madVR would output 10 bit even when the nvidia driver was configured for 8 bit output (madVR knows this, but it does not seem to matter). |
14th December 2018, 22:43 | #53882 | Link | |
At 4k 60Hz I only have the option of 8bpc in NCP. If I lower it to 30Hz then I get the 12bpc option as well. I was just wondering why there is no 10bpc option anywhere. MadVR reports the display is capable of 8, 10, 12bpc. I'm using a 980 ti and have two HDMI 2.0 cables from monoprice, a 6ft one and a 50ft active one For my setup I have to go into fullscreen as well. Otherwise madVR is outputting HDR but the TV isn't displaying it (doesn't switch to HDR mode). But fullscreen, exclusive or not, gives NV HDR 12 bit. I didn't have to set 10 bit for native display bitdepth or higher as the auto selected it for me. Also, what do you have selected in NCP? RGB Full range? Last edited by Arm3nian; 14th December 2018 at 22:45. |
14th December 2018, 23:03 | #53883 | Link | |
You need to drop down to 12bit YCbCr 4:2:2 or 8bit RGB @ > 30hz. |
14th December 2018, 23:12 | #53884 | Link | |
15th December 2018, 01:02 | #53885 | Link |
why according to the type of file controlling OSD do I have some "dropped frames" (3-6-9 or 12)? this happens above all with files at 23.976 while 25fps files statistics are excellent, 0 dropped frames, 0 repeats! even renders are always lower with files at 25 fps. What could I enable to make sure that there are no "dropped frames"?
I'm using the Chroma upscalling NGU standard medium. Thanks to everyone. |
15th December 2018, 03:58 | #53886 | Link |
Posts: n/a
With madVR's 24Hz custom resolution, I can only select 8bit or empty space in NVidia CP, but my 2008 TV normally allows up to 12bit. The default for 24Hz madVR custom resolution is empty space, but 10bit is selected in madVR and I asked it's some UI bug. Empty space is probably 12bit.
BTW, will madVR utilize NVidia's AI cores to further improve quality? |
15th December 2018, 18:10 | #53887 | Link | |
1 frame drop every xx minutes It is likely clock jitter, which is normal. The only way to improve that is with a custom resolution. The question is whether you actually noticed any of those dropped frames?
15th December 2018, 20:43 | #53888 | Link |
Smooth motion is a great way to avoid dropped frames and not deal with custom refresh rates.
madVR options explained |
15th December 2018, 23:16 | #53889 | Link | |
It's a wonder why panel manufacturers haven't pushed high refresh rate panels to do this. I expect 100+hz frame blending aka Smooth Motion looks quite good. Last edited by ryrynz; 15th December 2018 at 23:19. |
16th December 2018, 05:45 | #53891 | Link |
Got another dumb question, does MadVR favor any of the newer units in RTX vs GTX in terms of performance? For example does 2070 have similar performance as a 1080 the way they do in games? Same thing can be asked for 2080 and 1080Ti.
Thanks! |
16th December 2018, 08:41 | #53892 | Link |
No, madVR does not use any of the new RTX features, the performance similarities from current games carry over to madVR too.
16th December 2018, 09:02 | #53893 | Link |
Yeah, we'll be able to do it ourselves with madVR at that point but frame blending could've be added by TV manufacturers using the panels unexposed native refresh. With the likes of Tom Cruise and Christopher McQuarrie saying "Please turn Motion interpolation off, this is not how the film should be watched" and with the Soap Opera effect being wildly known and typically despised for over a decade, I wonder why any TV manufacturer hasn't simply added this alternative as an option?
16th December 2018, 09:58 | #53894 | Link |
Warner, yesterday I saw 1 movie and an episode of TV series and I did not see anything strange, no shooting and frame lost, but I can not understand why if I look at the OSD I always know those few "dropped frames".
Smooth motion is an "interpolation"? I prefer not to activate "Smooth motion" I prefer the original cadence of the film, with nothing added. https://imgur.com/a/UPstRZu |
16th December 2018, 10:54 | #53895 | Link | |
FYI Madshi himself doesn't advise buying GTX GPUs anymore at this stage but recommends RTX instead. He has made no promises or committed to anything, but it's most likely his intention to take advantage of the new architecture in the future with MadVR. So no differences now, but down the line possibly a significant one. If you want best possible PQ in HDR using MAdVR's excellent HDR tonemapping with all options/features available, I wouldn't buy anything below a 2080 (roughly equal to 1080ti), and I recommend a 2080ti if you can afford it to have some headroom. My 1080ti is struggling with the latest HDR test algos and I have to use it in D3D11 native as Copyback isn't up to the task without degrading quality. That means I lose black bar detection with D3D11 native, or have to lower the quality of chroma upscaling (using NGU AA High at the moment, so it's possible to downgrade without too much of a downside visually). My plan is to upgrade the 1080ti as soon as nVidia releases a model supporting HDMI 2.1 and 7nm, at some point in 2019.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 16th December 2018 at 11:06. |
16th December 2018, 11:28 | #53896 | Link |
Is this for real?
Any advantage to setting the display/TV to 12-bit in Nvidia control panel when the movie is encoded in 8-bit anyway? Or is it best to just leave it at 8-bit?
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
16th December 2018, 14:14 | #53897 | Link |
No, not really.
16th December 2018, 14:17 | #53898 | Link | |
https://forum.kodi.tv/showthread.php...942#pid2238942
16th December 2018, 22:29 | #53899 | Link |
Smooth motion is not interpolation, it is designed to get the movie to play at its original cadence while playing on the display's refresh rate. Please trust your eyes.
17th December 2018, 02:35 | #53900 | Link | |
