Old 27th March 2011, 06:16   #1121  |  Link
mindbomb
This 200mb sample is out of sync when played with lav audio decoder:
http://www.megaupload.com/?d=HFYOGAB5
It has flac audio, and I was using lav splitter as well.
also, did you take a look at the really large sample i sent you?
mindbomb is offline   Reply With Quote
Old 27th March 2011, 09:52   #1122  |  Link
fastplayer
Playing around with LAVAudio and I can't figure out how to properly setup the channel mapping to downmix 5.1 to stereo...
With this setup I hear no voices: FL->1, FR->2, FC->1,2, LF->1,2. Obviously, I'm doing something fundamentally wrong...
Edit: Front Center needs to be mapped to channel 3 otherwise it never gets outputted.
fastplayer is offline   Reply With Quote
Old 27th March 2011, 10:47   #1123  |  Link
nevcairiel
You're playing in the code?
The channel mapping tables do not support mixing, if one number is encountered twice, the previous channel is being overwritten.
Old 27th March 2011, 11:00   #1124  |  Link
fastplayer
Sorry for the confusion! I was talking about MPC's audio switcher.
I realized that I don't need to enable custom mapping at all. It sounds the same either way.
Old 27th March 2011, 13:05   #1125  |  Link
Carpo
Carpo's Avatar
nevcairiel - is there any chance you could add thumbnail extraction to your splitter? Seeing as haali removed it from his, and i do not like to have to use DivX to do the thumbs, if possible i would like to stay away from MF altogether.
Under linux there is a program called ffmpegthumbnailer, that i used to make the thumbs for all my videos, looks like it could be used on windows too.
There is one mkv i did that causes exporer.exe to have fits when it tries to make a thumbnail for it, yet under Linux it was fine.
Would be a nice feature, but i understand if you would prefer not to add it.
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 27th March 2011, 13:07   #1126  |  Link
BatKnight
BatKnight's Avatar
I've noticed the same thing. It only happens with LAV Audio and FLAC tracks.
Nuno
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers
MPC Home-Cinema
madVR
LAV Filters
BatKnight is offline   Reply With Quote
Old 27th March 2011, 15:07   #1127  |  Link
mindbomb
if you using directsound as your audio renderer, it will automatically downmix things to whatever windows is configured for.
Old 28th March 2011, 00:14   #1128  |  Link
diizzy
I've mentioned some of this earlier without response so I'll give it a try again.
Is it intentional that LPCM tracks doesn't connect to either ffdshow and/or MPC-HCs filter (VOBs)?
I also have a few MKVs that loads but doesn't play/show any frame at all (MPC-HC), are compressed headers etc fully supported?
It would also be nice if you could set file types to handle instead of all or nothing since a few features are lacking for at least Matroska such as embedded fonts and compatibilty issues.
I highly appreciate the work going into this project.
diizzy is offline   Reply With Quote
Old 28th March 2011, 09:55   #1129  |  Link
Thunderbolt8
does DTS mean HD audio like DTS-HD MA works as well?
and are 2in1 .mkv movie version supported? (those which are originally seamless branching BDs and now work with chapters when being remuxed)
Old 28th March 2011, 09:57   #1130  |  Link
nevcairiel
In the Splitter it works just fine, in the audio decoder only the DTS Core will be decoded, not the HD extensions.
Not yet, no.
Old 28th March 2011, 18:05   #1131  |  Link
BatKnight
BatKnight's Avatar
@nevcairiel
Since you are working on the splitter, would you please look into the sync problems of LAV Audio when playing movies with FLAC tracks?
I do a lot of remuxes to FLAC and have a lot of movies with this problem.
Thanks
Nuno
MPC Home-Cinema
madVR
LAV Filters
Old 28th March 2011, 18:23   #1132  |  Link
nevcairiel
I don't see the relation between working on the splitter and fixing audio decoder bugs, but okay!
In any case, there are several good FLAC decoders around, and you can configure formats now in LAV Audio .. i'm not exactly sure when i'm going to have time to look into it. I recommend madFlac
Old 28th March 2011, 18:54   #1133  |  Link
BatKnight
BatKnight's Avatar
I'm sorry.
I just thought that since LAV Audio is part of the LAV Splitter, that you could look into it.
And yes, madFLAC is a great decoder, and this bug is not urgent. Just a reminder.
Do you have a a bug tracker I could fill for this LAV Audio issue?
Nuno
MPC Home-Cinema
madVR
LAV Filters
Old 29th March 2011, 01:46   #1134  |  Link
neoufo51
Just out of curiousity, what's keeping this splitter from being added to MPC-HC right now?
Running Win7 laptop with Nvidia GT120M card, 267.xx drivers.
neoufo51 is offline   Reply With Quote
Old 29th March 2011, 09:42   #1135  |  Link
jmone
Hi nevcairiel, thinking outloud with the BD splitter, I understand we will at some point be able to select a playlist (from the mpls) but is there any meta data available to say what each playlist is? Eg. Is there any data in the mpls that will let you display that a particular playlist is say the Std or Extended play etc?
jmone is offline   Reply With Quote
Old 29th March 2011, 09:45   #1136  |  Link
nevcairiel
No.
You can get the length, though, which should give you some hints.
They do not contain such data because it usually relys on menus to navigate.
Old 29th March 2011, 09:59   #1137  |  Link
jmone
True - makes "alternative endings" a tough guess however (but we can not have everything!)
Old 29th March 2011, 10:00   #1138  |  Link
jmone
mmmm does the order in the mpls give any clues - eg is the "first" of the longer playlists the "std" one, the second the "alternative ending" etc or is this a very long bow to draw do you think?
Old 29th March 2011, 10:33   #1139  |  Link
nevcairiel
I don't think you can really rely on that.
Old 29th March 2011, 11:03   #1140  |  Link
jmone
I guess we will test and see all in good time
