17th May 2017, 01:32 | #1 | Link |
the Interrogator
Weird prob with AVIs containing x264 video
When I open one of these in VirtualDubMod 1.5.10.2 it gives a warning: "Couldn't locate decompressor for format 'H264' (unknown). VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable. Only 'Direct stream copy' is available for this video."
x264vfw is in fact installed and used quite happily by TMPGEnc Video Mastering Works 6. So AVIs can be cut etc. and saved using direct stream copy using VDubMod, only prob being video is not displayed. VirtualDub FilterMod 38919 can open and display AVIs with x264 video, but is unable to use direct stream muxing: "The source video stream uses a compression algorithm which is not compatible with AVI files. Direct stream copy cannot be used with this video stream." Truly weird. I recently migrated from WinXP to Win10. In WinXP, VDubMod with x264vfw worked without probs. It could display/decode videos with x264/h264 video and cut them etc. using direct stream copy or full processing mode etc. Any suggestions? (no I do not want to convert these AVIs to MKV) |
17th May 2017, 07:35 | #2 | Link | |
Retried Guesser
Given the preconditions, Nope, none at all. |
17th May 2017, 11:53 | #3 | Link | |
the Interrogator
In the past 7 years I have backed-up hundreds of blu-rays to AVI/x264. Those backups invariably play without problem. |
17th May 2017, 12:54 | #4 | Link | |
the Interrogator
x264 10-bit - H.264/MPEG-4 AVC codec x264 8-bit - H.264/MPEG-4 AVC codec |
17th May 2017, 13:56 | #5 | Link |
Retried Guesser
OK I was wrong. I found an x264 AVI on my end that can not be stream-copied in VirtualDub FM with the native decompressor, but can when forced into using the x264vfw decompressor (via File, Open, files of type, AVIFile input driver).
17th May 2017, 14:17 | #6 | Link | |
the Interrogator
DirectShowSource("x264 AC3 Hugo 1360x768.avi") where x264 AC3 Hugo 1360x768.avi is x264 video, AC3 audio 27,740,160 bytes. The AVS opens and displays in VDFM OK using File, Open, files of type, AVIFile input driver and will even Direct Stream Copy without error, but the result is an AVI of 2,278,020,244 bytes, clearly some form of uncompressed video. If you got a Direct Stream Copy AVI result almost identical in size to your input AVI, please tell me what you did. |
17th May 2017, 14:44 | #7 | Link |
Retried Guesser
AVIFile input driver does not see AVI files? Hmmm yeah. What I did was copy & paste a path without even trying to browse (I had to search for a suitable AVI)
An Avisynth file appears as a raw, uncompressed stream, so copying it will result in a huge file. EDIT and the copied video stream has exactly the same size and other properties. Audio copying failed, but that is another story... Last edited by raffriff42; 17th May 2017 at 14:48. |
17th May 2017, 15:04 | #8 | Link | |
the Interrogator
HOW did you "copy & paste a path without even trying to browse". Into WHAT did you paste this path? |
17th May 2017, 22:08 | #10 | Link |
For the standard VirutalDub, "Audio/Video Interleaved" is included in the drop down list when opening files. "AVIFile input driver" doesn't include AVIs. Try the standard version if you're using the modded version, but it probably works the same way as the standard version with the ffmpeg input driver plugin installed and you need to select "Audio/Video Interleaved". For the standard VD, without the ffmpeg input driver plugin, it should open AVIs in the usual way. If the plugin is present, it'll probably default to opening the files so you won't be able to use directstream copy unless you select "Audio/Video Interleaved". Even if VD complains about not being able to find a codec for decompression, you should still be able to use direct stream copy if you open them that way.
https://www.videohelp.com/software/Virtualdub https://sourceforge.net/projects/vir...eginputplugin/ Last edited by hello_hello; 17th May 2017 at 22:15. |
18th May 2017, 00:25 | #12 | Link | |
the Interrogator
I would like a SINGLE app which can both open AVIs and view them (so I can select regions to cut etc.) AND do Direct Stream Copy. At the moment I have to use VDM and VDFM. |
18th May 2017, 02:34 | #13 | Link |
virtualdub can do that but can only cut at specific frames (keyframes), not at any point.
Sometimes there's only a keyframe every 10-15s (250-300 frames is common default in encoders), so you wouldn't be able to cut such series of frames in the middle. You can cut at exact frames with some supported codecs if you use "smart recompress" mode (or whatever it's called) instead of direct stream copy. virtualdub would copy segments outside cut points directly (like direct stream copy) and decode segments which have cut point inside and recompress the portion you still want in video. but h264 in avi is already such a hack i wouldn't be surprised if "smart recompress" won't work. Really, stop using avi and use mp4 or mkv Last edited by mariush; 18th May 2017 at 02:49. |
18th May 2017, 04:07 | #14 | Link | |
the Interrogator
As I say I have done hundreds of AVI/x264 rips without problem, that's the bottom line... I could convert AVI to MKV at any time, but not the reverse, another thing I dislike about MKV. |
18th May 2017, 04:24 | #16 | Link | |
It packs one or several video streams, one or several audio streams, one or several subtitles and their related data (fonts, various resources) and chapter information into a single file. AVI is worse, it supports only 2 audio streams (good luck storing original audio and multiple commentary tracks in one avi file), it has problems with large sizes (some players can't play AVI files larger than 8 GB or crap like that), there's index at the end so if you don't have the complete AVI file you can have problems playing the video... it's crap container. The limitation of cutting just at a keyframe with MKV is probably just some lazyness from the developer's part - it's easier that way, it's like i said direct stream copy and just editing the "index" of the MKV file (a collection of seek points which tell video players to jump to specific keyframes in the video). MKVToolnix is a popular tool to mux streams in matroska containers or to extract segments from matroska files and it only cuts at keyframes. So it's quite a high possibility the software you're using relies on this tool in the background to edit MKV files. x264 in AVI is done as a HACK. Even XVID when it was popular was implemented in AVI as a hack, because AVI as a movie container has some limitations and couldn't normally support all the "features" of modern video codecs like XVID or h264. You would most likely get better quality or more quality per bitrate if you'd encode some video to a raw h264 stream or to MKV or MP4 (x264vfw codec even let's you output the encoded data to a separate file in a format it supports and return some fake video back to Virtualdub) , and then mux that video-only file with the audio compressed separately to MP3 or AAC or Opus or FLAC (or whatever you prefer) and mux both into MKV or MP4. You can't do MP4 to AVI or MKV to AVI most likely for the reason that the bitstream of the video would have to be specially crafted to fit inside AVI, and there's no guarantee the stream that's in MP4 or MKV was produced like that originally. And no developer cares to somehow find a hack or some way to put that h264 data from mkv or mp4 to AVI because as you've been told already, it wasn't meant to be used with AVI and AVI should just die. Last edited by mariush; 18th May 2017 at 04:31. |
18th May 2017, 05:26 | #18 | Link |
the Interrogator
I understand that dude, it's a wrapper..
The advantages of MKV, I don't use: * Never use 2 audio streams * Don't use files sizes above 8 GB (mostly under 4 GB) * Never use chapters Even embedded subtitles which is something I find appealing haven't worked well last time I looked. There is a marked "judder" when turning subtitles off and on which does not occur (in MKV or AVI) with external subtitles. Being able to cut at a given downstream frame is a big deal to me, so sorry MKV... I had this discussion with a leading MKV proponent (moderator) before. In the end he admitted there was no absolute reason I should leave AVI given what I want and how AVI is performing. |
18th May 2017, 06:52 | #19 | Link |
What is the supposed to see in the start post about vanilla VirtualDub not being an option?
Is the decoder component of x264vfw deactivated? Which version/from where? Tried to install it again? Did you try ffdshow vfw? H.264-in-AVI is a bit special but softwares like SolveigMM Video Splitter, VideoReDo and AviDemux are supposed to handle cutting H.264 correctly. (Including in MKV container.) |
18th May 2017, 14:59 | #20 | Link | ||
the Interrogator
x264vfw_full_43_2694bm_43159_fix Not yet but TMPGEnc Video Mastering Works 6 is quite happy with x264vfw as installed. No. Quote:
