20th February 2010, 18:15 | #2 | Link |
Your sample has a lot of motion, and is difficult to encode. Use a higher bitrate, 5.8Mbps is not a lot for 720p50 with that type of source complexity
BTW, satd and 16 ref frames is overkill, the quality gains will be negligible , but encoding speed will be 5-10x slower. 3pass is pretty much useless as well. |
20th February 2010, 18:23 | #3 | Link |
Can you post a sample from the source so we know what it is supposed to look like. The colours look a bit off, but maybe they are supposed to be like that and anyway that would be more of a PC/TV range or BT.601/709 issue. Impossible to tell without the source and the avisynth script you used. The final stats x264 spits out would also be interesting.
Apart from that video game footage isn't easily compressible in general because unlike film there is no motion blur. So for 720p50 at your bitrate you maybe can't get much better results. Also you should probably stick to the presets and tunings and not set everything manually. Everything you set is very slow, but then you use --subme 9, --no-mbtree and don't use b-pyramid and potentially throw away a lot of quality (mainly mb-tree) for relatively little speed gain, especially compared to using --slow-firstpass and --me tesa. |
20th February 2010, 19:20 | #4 | Link |
this is huffy example , and well , i know more bitrate should be used but there are several people that has already created way more quality videos with these presets , probably could you recommend me some exact settings which i should change ? and btw the motion blur is just half amount what is usually used
20th February 2010, 19:26 | #5 | Link | |
If you had very little motion, with very little action & explosions (e.g. just camped out like a sniper) , then maybe with that bitrate, otherwise I seriously doubt it. You also have some weird frame blends in your encoded sample. How did you do this capture? Did you feed it through an NLE? |
20th February 2010, 19:39 | #6 | Link |
then probably i did something wrong in vegas or during capturing , but this first preset example also used a guy for 720p 50 fps vid who gained very decent quality with that setting
i dont know what is nle , but i was capturing it with image et tool , which records and also immediately adds motion blur into frames , merged them in virtual dub into huffy avi file and done some color corrections in vegas |
20th February 2010, 19:46 | #7 | Link | |
But what was the source complexity for the other guy? The content matters. For example, if it's a still shot with low complexity you might be able to use 1Mb/s. If you're not fixated on bitrate or don't know what to use, try a crf encode. e.g. crf16-20 Your encoding settings are already very high, and most of them are absurd (diminishing returns) as discussed above. You won't get much better by adjusting them, except the bitrate. NLE = non linear editor. e.g. vegas, premiere Frame blending is the default action in most NLE's when your project/sequence settings DON'T match the actual footage. e.g you might have had a 60fps capture, but used 50fps project settings. It might have also been a product of your capture If you're wondering what I'm talking about blends here is an example from your encode: http://tinypic.com/r/i73gd0/6 What did you use to capture the original gameplay footage? e.g., FRAPS ? , Blackmagic intensity pro ? etc... Last edited by poisondeathray; 20th February 2010 at 19:57. |
20th February 2010, 20:02 | #8 | Link |
i dont know what "source complexity" you mean, if the action in the video , then its equal or even higher in that video of the other guy
i was capturing it with image-et tool as i said , and i was capturing 150fps - because im planning to play a lot with velocity(the speed of video) and just 50 would result in terrible overall quality , dont know if that could cause those blends sorry for my lack of informations about this encoding stuff , im pretty much a newbie to this |
20th February 2010, 20:08 | #9 | Link | ||
I'm sorry. I don't believe you. Please post an example from "that guy". If your claims are true, I am certain there will be differences ,like fps, dimensions, content. Quote:
50fps should be easily obtained from 150fps, because it's evenly divisible. (there should be no blends or resampling) In vegas, you can right click the clip and disable resample. When speed changes occur, it will duplicate frames instead of blending . This will give jerky playback. Both are bad IMO. Last edited by poisondeathray; 20th February 2010 at 20:14. |
20th February 2010, 20:23 | #10 | Link | ||
20th February 2010, 20:32 | #11 | Link | |
I didn't check the sample or what fps he used yet, but that's a big difference, wouldn't you say...
The colors and luma values are an entirely different huge disussion Quote:
If it was a straight encode and you had a CFR source (constant frame rate) at 150fps with no frame drops, and did no speed changes (ramps), and encoded a 50fps export, there should be no blends, because 50 is evenly divisible (just every 3rd frame). So either you screwed up the settings, the source had frame drops, or blends were in the source to begin with |
20th February 2010, 21:20 | #13 | Link |
I downloaded that video. He's using ~10.5Mbps. Of course it looks better.
Summary: Use a higher bitrate for 720p50 if that content is typical of what you're planning to encode x264 is a great encoder, but it can only do so much at relatively low bitrates for that content complexity Cheers Last edited by poisondeathray; 20th February 2010 at 21:29. |
bad quality, gaming, problem, video |
