Old 30th April 2012, 07:20   #1  |  Link
Musafir_86
Lone Wanderer
WMV/VC-1 Encoder Development Progress Until Now
Hello everyone (& hi Mr. Alex Zambelli ),
-As we know, H.264 encoders (specifically x264) - and to some extent, VP8/WebM too (refer http://blog.webmproject.org/) are continuously being improved over time to make them better, more efficient and produce higher quality output files. Even XviD has (somewhat) continually minor improvement/bug fixes, with last official patch released last year (2011) .
-The questions:
1. How about WMV/VC-1? Is there any improvement to WMV3/WMV9/VC-1 since WMP11/WMSDK11 (according to http://forum.doom9.org/showthread.php?t=112634 this is the latest)?
2. Do the encoder bundled with Windows Live Movie Maker 2011 is the latest/an improved version?
3. How about the encoders in Expression Encoder 1/2/3/4; do they gradually get an increase in the output quality/improve their encoding efficiency with each newer release?
4. Do Expression Encoder 4 uses the built-in encoder in Windows or the one bundled with .NET Framework 4 ? I can't seem to find the binary that do the encoding in its Program Files directory.
EDIT: I found vc1ecore.dll with version 11.5.2568.7346 dated 04 November 2009 (in its security certificate) there, which I assume should be the encoder binary I'm looking for.
5. Any test has been done? Any change log?
-Also, is there any (better) third-party encoder(s) aside those from Microsoft that I'm unaware of?
Thanks & regards.
Musafir_86 is offline   Reply With Quote
Old 30th April 2012, 07:48   #2  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Yes, there is Mainconcept Reference 2.x
Midzuki is offline   Reply With Quote
Old 30th April 2012, 07:58   #3  |  Link
Musafir_86
Lone Wanderer
-Oh, thanks. Is its output quality noticeably better than Microsoft's?
Old 30th April 2012, 14:51   #4  |  Link
Midzuki
Unavailable
Midzuki's Avatar
^ To my eyes, there are no significant differences regarding quality, BUT there are significant differences regarding the encoding SPEED --- MCR 2 is somewhat faster.
Notice, I have used only Windows Media Encoder 9 + WMF 11 (through Zambelli's wmcmd.vbs) and TinTime's modified avs2asf, so I have nothing to say about Expression Encoder, except that it's overbloated for what it does, and still depends on the silly dotNET framework.
Old 30th April 2012, 15:12   #5  |  Link
Musafir_86
Lone Wanderer
-Hmm, quality is more important to me than speed (we only encode once, but the video will be played back countless times, right?). Can the latest encoder rival x264's quality?
-Regarding Expression Encoder, I'm not sure too, that's why I asked here (I don't have resources to do thorough comparison).
-And yes, I also dislike .NET platform for overheads it causes; beside Expression Encoder, Paint.NET is the other .NET app that useful for me. IMHO, a developer should prioritize his program's quality instead of taking easier path, by using C++ or such (or even assembly where it makes sense) instead of interpreted/managed code e.g. .NET or Java. I understand the argument of improved code security & reliability, but the same can be achieved without a managed platform, just need more effort, skills, and time (the same quality vs. speed argument as first paragraph).
Regards.
Old 30th April 2012, 15:30   #6  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Right --- however, a faster encoder doesn't always mean it outputs inferior quality, sometimes it means its source-code has been optimized.
I don't think so.
EDIT: The FAQ thread you mentioned in the first post is outdated, because it doesn't say a word about Microsoft's VC-1 SDK:
http://alexzambelli.com/blog/vc-1-sdk-faq/
Old 30th April 2012, 16:17   #7  |  Link
Musafir_86
Lone Wanderer
-I already visited his blog and saw that FAQ before posting this, and that VC-1 Encoder SDK package dated back to 2007...
Old 1st May 2012, 21:57   #8  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
x264 in terms of quality and speed is alot better than vc1. stick to x264 and forget about the rest until x265
Old 2nd May 2012, 15:21   #9  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
-The questions:
The WMV9/VC-1 encoder in Windows 7 (and soon Windows 8) is the latest DMO/MFT. In comparison to the WMF11/Vista binaries it contains 8-way threaded encoding (versus 4-way threading in WMF11/Vista) and some minor optimizations and bug fixes. I haven't worked on the Windows codec team in 4-5 years so I'm not as aware of code changes as I used to be.
There's no encoder bundled with WLMM. Movie Maker just uses Windows codecs.
Expression Encoder uses the VC-1 Encoder SDK for VC-1 compression - it doesn't rely on any Windows codecs (except for WMA compression). The last time the VC-1 Encoder SDK was updated was in November 2009 when 8-way threading was also added.
There is no video encoder bundled with .NET 4 runtime, I'm not sure which one you're referring to.
vc1ecore.dll is compiled from the VC-1 Encoder SDK.
There hasn't been any significant development of the VC-1 encoder at Microsoft (to the best of my knowledge) since 2009/2010, largely due to lack of demand and the ongoing change in industry priorities. Most companies, including Microsoft, are relying on H.264 for interoperability so continuing to invest money into VC-1 encoding for marginal enhancements just doesn't make a lot of sense fiscally. VC-1 decode speed advantage, which was important in the early days of HD, has lost its relevance with the advent of multi-core computing, DXVA and hardware decoders. VC-1 played an important role in the previous decade in advancing HD video adoption and forcing MPEG-LA to lower licensing fees for advanced codecs such as H.264 (competition always drives prices down). There's still a market for VC-1 encoder innovation out there, but I think that market is better suited for small companies at this point. I doubt Microsoft will ever release another singificant VC-1 encoder update.
zambelli is offline   Reply With Quote
Old 2nd May 2012, 16:28   #10  |  Link
Musafir_86
Lone Wanderer
-Thanks for taking your time in answering my questions.
-So, does the Platform Update & Platform Update Supplement for Vista include these binaries? Or Vista stuck with the older ones without any (official) way to upgrade?
-Sorry, I think I mixed it up with EVR (which found in .NET FX 3.0; not sure about 4.0) which adds EVR option for Windows XP (which originally only have WMR7/9).
-Hmm, is Microsoft not interested to open-source that VC-1 SDK? How about putting it on CodePlex? Maybe you could persuade them? IMHO, there's no harm by doing so (though I'm not sure about copyrights, patents, trade secrets, etc.; Microsoft Community Promise might be able to cover it), but all of the codes belong to Microsoft, right?
Thanks again & regards.
Old 10th May 2012, 01:50   #11  |  Link
benwaggoner
Correct. Updated DMOs are only available with an OS update.
Expression Encoder has the same VC-1 Encoder SDK lib on all platforms, so that's an easy way to 8-way threading and other improvements on XP and Vista. Plus you don't need to mess with registry keys to get access to advanced settings.
I can't imagine anyone at Microsoft caring enough to expend the resources to do an open source release.
Ben Waggoner
My Compression Book
Old 25th March 2013, 18:39   #12  |  Link
benwaggoner
Originally Posted by jq963152 View Post
Now that Windows 8 has been released: are there any differences between Windows 7 and Windows 8 regarding the VC-1 encoder?
Not that I'm aware of. Digital Media in general didn't see much new from Windows 7.
Ben Waggoner
My Compression Book
Old 26th March 2013, 21:33   #13  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
Probably just bug fixes and (maybe) some perf optimizations, but I doubt any development work went into quality improvements or new features. Most team seems to be focused on H.264 encoder these days. http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
Unless some other company decides to develop a better VC-1 encoder, I doubt we'll ever see a better VC-1 encoder than the Microsoft VC-1 encoder that shipped with Windows 7/8.
Note: I no longer work at Microsoft either, so I'm merely speculating about the above.
development, encoder, expression, vc-1, wmv
