23rd June 2005, 17:45 | #102 | Link | |
clueless n00b
23rd June 2005, 18:26 | #103 | Link |
clueless n00b
I've identified and fixed the audio bug. It doesn't happen if you switch between audio tracks and if a profile is selected, so this is why I never catched it.
I am VERY curious about your MeGUI logfile... can hardly wait.
23rd June 2005, 19:00 | #104 | Link |
I run new job with x264.exe and my log is as always (x264CLIReader.exe is in megui folder) but I had to close status window myself (no progress bar):
Next job job1 is a video job. encoder commandline: "E:\DIVX\PROGRAMY\x264\megui\x264.exe" --bitrate 700 --no-b-adapt --subme 4 --analyse p8x8,b8x8,i4x4 --progress --no-psnr --output "E:\DIVX\PROGRAMY\x264\megui\output.mp4" "E:\DIVX\PROGRAMY\x264\megui\input.avs" successfully set up video encoder and callbacks for job job1 Last edited by odyn1982; 23rd June 2005 at 19:03. |
23rd June 2005, 19:20 | #105 | Link | |
clueless n00b
23rd June 2005, 19:51 | #107 | Link | |
clueless n00b
And what windows version are you using... non NT based versions apparently are unaware of stderr.. at least when it comes to redirecting in the commandline.. perhaps that also applies to reading from stderr as well. @Pasqui: I hope you can run the x264clireader as well and report back, also let me know about your windows version.
23rd June 2005, 20:05 | #108 | Link |
Using MeGUI 0.1.9.9 on WinXP I still get no status bar.
The log window shows: Next job job1 is a video job. encoder commandline: "F:\Program Files\x264\x264.exe" --bitrate 700 --ref 3 --bframes 2 --weightb --analyse p8x8,b8x8,i4x4,p4x4,i8x8 --8x8dct --progress --no-psnr --output "H:\MATRIX_RELOADED_DISC_1\VIDEO_TS\video.mp4" "H:\MATRIX_RELOADED_DISC_1\VIDEO_TS\Matrix2.avs" successfully set up video encoder and callbacks for job job1 x264.exe processes the frame (CPU at 99%) then drops down to 0% (I guess the compression is over). But Status window stays open and x264 process is still displayed in the task manager. |
23rd June 2005, 20:10 | #109 | Link |
The command line
"C:\Documents and Settings\abs\Desktop\AV Tools\MencoderGUI\codecs\x264.exe" --bitrate 700 --no-b-adapt --subme 4 --analyse p8x8,b8x8,i4x4 --progress --no-psnr --output "C:\Documents and Settings\abs\Desktop\AV Tools\MencoderGUI\codecs\output.mp4" "C:\Documents and Settings\abs\Desktop\AV Tools\MencoderGUI\codecs\input.avs" >2 output.txt If I remove the "2" from the command line (i.e. > output.txt), then I do get an output.txt, and it's still empty. I just use plain ole Win XP (SP1) with an Athlon processor. Thanks for tryin', tho! -abs
The perfect browser is now completely free: Opera. Get it. Love it. |
23rd June 2005, 20:13 | #110 | Link |
clueless n00b
@pasqui: what about the x264cliencoder I posted in this thread.. could you run it and let me know the results please?
@absinthe: urgh.. it should be 2> output.txt, not >2 output.txt. Sorry about that.
23rd June 2005, 20:33 | #111 | Link | |
Odd. -abs
23rd June 2005, 20:54 | #112 | Link |
@Doom9
Here is the result of x264CLIReader: Code:
F:\Program Files\x264>x264clireader 21:51:54Started x264.exe and the stdout and stderr readers 21:51:54 line received: avis [info]: 640x272 @ 25.00 fps (201 frames) 21:51:54 line received: x264 [info]: using cpu capabilities MMX MMXEXT SSE 3DNow ! 21:51:54 line received: mp4 [info]: initial delay 0 (scale 25) 21:51:54 line received: encoded frames: 1/201 (0.4%), 9.09 fps 21:51:55 line received: encoded frames: 2/201 (0.9%), 9.85 fps 21:51:55 line received: encoded frames: 3/201 (1.4%), 10.10 fps 21:51:55 line received: encoded frames: 4/201 (1.9%), 10.67 fps 21:51:55 line received: encoded frames: 5/201 (2.4%), 10.66 fps 21:51:55 line received: encoded frames: 6/201 (2.9%), 11.30 fps 21:51:55 line received: encoded frames: 7/201 (3.4%), 11.48 fps 21:51:55 line received: encoded frames: 8/201 (3.9%), 11.63 fps ... Pasqui. Last edited by Pasqui; 23rd June 2005 at 20:56. |
23rd June 2005, 21:05 | #113 | Link | |
sidekick
here's my result:
I'm using windows XP Home SP2 on my P4 2ghz... I think this post apply for me too ... Quote:
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 23rd June 2005 at 21:21. |
23rd June 2005, 21:06 | #114 | Link |
clueless n00b
@pasqui: thanks. So we have two categories here:
1) status updates work but have no progress bar. This is due to the system's apparent inability to redirect stderr - both in cmd.exe and from within a .NET application. 2) status updates do not work (so there's no progress bar either, and the progress window has to be closed manually). However, stderr can be redirected and read from x264clireader (http://forum.doom9.org/attachment.ph...chmentid=4182). I think the next release will fix the problem for machines falling into that category as I've changed the way the x264.exe output is read to what I'm using in x264clireader. Now if anybody else has the problem, please perform the tests to find out in which category you fall, and if it's the first one, let me know about your .NET runtime version and Windows version. And if you do not have a progress bar using mencoder, besweet or mp4box, let me know, too.
23rd June 2005, 23:28 | #117 | Link | |
At least that's how it was in 0.1.9.9. Whoa! I just downloaded 0.2.0.0 and now, for the first time, the progress window does not close. This is definitely the first time this has happened. And it must be something in the new version as I'm doing the exact same little sample job I've been doing all day. -abs EDIT: Something definitely borked for me in 0.2.0.0. The progress window never closes, as I mentioned. A 1-pass job will output fine, tho. However, I can't do more than 1 pass at a time as the first will never "finish." So, interestingly, I rolled back to 0.1.9.9 and it works fine again (except no progress shown in the progress window). Could this be .NET weirdness? -abs
The perfect browser is now completely free: Opera. Get it. Love it. Last edited by absinthe; 24th June 2005 at 03:33. |
24th June 2005, 03:40 | #118 | Link |
Wow! Version 0.2.0.0 !! Cool!
So, I still get the fps reported incorrectly. Here is a screenshot from the the encoding window. Interesting, though, is that MeGUI still reports the encoding time correctly. I'm sure these are not spike fps, it stays about 1500fps all the time. Anyway, not a big problem. I believe you have more important things to do. I have also attached my log. By looking at the log it seems there are no problems. |
24th June 2005, 07:48 | #119 | Link | |
sidekick
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
24th June 2005, 08:30 | #120 | Link |
clueless n00b
If your progress window (it's called like that, let's all use the same terminology in the future to prevent confusion.. it's even called ProgressWindow in the code) doesn't close.. does it close when you're encoding using mencoder, audio encoding or mp4 muxing? I also need to see your logs from an x264.exe session.
@Rash: does the FPS fluctuate or does it always stay the same? And what is the decimal separator in your language settings in the control panel? Could you compare the percentage from the logfile (the one before the line "sending status update") with the percentage you get in the progress window? Could it be that in the window it's 100 times the value reported in the log? I suspect that your comma separator isn't a dot, so due to your locale 20.12fps is read and converted into 2012 fps. If you can confirm my suspicion I can force the locale to EN-us for the conversion and the problem will be gone. Please tell me any of you guys can handle a debugger.. I'm going crazy here.. it works for most people and at some point I have to stop questioning and blaming myself.. we're only dealing with a handful of people here having this issue, compared to the number of downloads it's a miniscule percentage.
