Old 4th June 2009, 17:17   #1  |  Link
sphere
DXVA not working with MS-VC1 decoder (Win 7, ATI)
MPC's H.264/VC1 DXVA Decoder works flawlessly for both codecs. So does MS's H.264 decoder. What doesn't work, however, is DXVA decoding with the MS WMV/VC1 decoder that is used by WMP and WMC.
When playing a VC1 file in DXVA Checker, no VC1 DXVA capabilities are reported for the MS codec (DShow or Media Foundation) - only for the MPC decoder.
My conf: Windows 7 RC, Radeon HD 3300 (AMD 790GX IGP) with Windows-supplied driver (8.612) [however, installing the Win7 driver from AMD's website doesn't help, I tried that]
Any ideas?
Thanks,
sphere
sphere is offline   Reply With Quote
Old 4th June 2009, 17:20   #2  |  Link
tetsuo55
MPC-HC Project Manager
You could try this VBS file first:
http://home.comcast.net/~exdeus/ati-hd2x00/
If that does not help follow the instructions in my signature and make sure to update to catalyst 9.5
Please let me know if this helps
EDIT:
Make sure you clean the old driver using driver sweeper Find at @ guru3d.com
tetsuo55 is offline   Reply With Quote
Old 8th June 2009, 13:01   #3  |  Link
littleD
littleD's Avatar
But is win7 WMP decoder supposed to work with DXVA for VC-1 files? I have the same as sphere when analyzing file by DXVAchecker. H.264 and MPEG-2 videos work great.
EDIT:
http://msdn.microsoft.com/en-us/libr...8VS.85%29.aspx
This filter decodes MPEG-1, MPEG-2, H.264 video
How is that video compression format (VC-1) promoted by Microsoft isn accelerated by its decoder while h.264 is?
littleD is offline   Reply With Quote
Old 8th June 2009, 19:03   #4  |  Link
MatMaul
hum I have a similar problem with a nvidia card.
on windows 7 rc1 64 bits, a check of the directshow decoder (WMVideo Decoder DMO) with dxva checker shows only DXVA1 support :
I tried to force the use of DXVA in dxvachecker with EVR (right click - play - EVR), it doesn't work (black screen). But it works with VMR9 !
anyone can try dxvachecker on vista to see the result ? if it supports dxva2 on vista I hope they will fix that before the release of Windows 7.
EDIT : I am using MPC 32 bits so I am talking about the 32 bits version of the decoder, I didn't try the 64 bits one (I don't really care ^^).
EDIT2 : perhaps someone can split my reply in a new thread. It is obviously not the same problem.
this one (with ATI cards) has already been explained I think : WMVideo Decoder DMO only support ModeVC1_IDCT, ModeVC1_MoComp and ModeVC1_PostProc while ATI drivers only support ModeVC1_VLD
MatMaul is offline   Reply With Quote
dxva, vc-1, vc1, wmp
