25th April 2014, 22:29 | #26221 | Link |
On 25p sources it shows cadence 2:2 too, I've never understood that. What can madvr do with 25p source? Can it decimate 25 to 24 or 20, 18, etc?
Is 25 -> 24 without blends common?
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
25th April 2014, 22:34 | #26222 | Link |
Any progressive movie is technically 2:2 if you force it through IVTC. The numbers basically means how fields belong together and in what patterns, and if you splice progressive into fields, you always have 2 fields that belong together exactly, hence 2:2.
25th April 2014, 23:25 | #26224 | Link |
Actually I wrote it in respect to madvr handling. Never really any need for a source like that as dvds and broadcasts aren't 24p and blurays accept 24p throughout the world. What I meant are 24p -> 25p sources common without blends?
Trying to figure out what madvr is trying to do with 25p. As far as I know it currently only decimates to 23.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 25th April 2014 at 23:29. |
25th April 2014, 23:48 | #26225 | Link | |
MadVR gets 578i25 50 fields with IVTC is should detect 2:2 and creates simple 25p and plays it back as this speed. there is simply nothing to decimate at all.
there is no decimation need because of this: 24 -> 25 is general speed up. they simple go and let the move run with 25 without changing anything at the frames. audio is done this way (i leave the 24000/10001 out for a good reason): 48000/24*25 =50000 so audio is now plays at 50000 hz a sec (this is lossless)and then simply resampled to 48000 hz (this is not lossless at all) to be DVD confirm. so decimation is totally useless. this changes the audio everything clearly sounds different and a DVD with 25 hz is roughly 5 min shorter in duration as it counter part BD with 23p. to get proper audio back you can use reclock plus madvr and slow it down to 23p again, this is yet again not lossless for audio but it shouldn't sound strange anymore. EDIT: Quote:
if the repeated flags are not used the put is 23p, this is not unusual at all! this is unusual for anime X-) Last edited by huhn; 26th April 2014 at 00:10. |
26th April 2014, 03:23 | #26226 | Link | |
26th April 2014, 06:21 | #26227 | Link |
huhn: I understand all that already. What I'm trying to figure out is what madvr is trying to do with a 25p file. It's not deinterlacing but it's trying to find a cadence. Madvr seems limited to decimating to 23/24 currently so is removing 1 out of 25 frames what it's looking for? Or is some pal content flagged progressive really interlaced?
Is there pal content that converts 24 -> 25 by adding 1 dupe frame every 25? I've heard of some dvd's adding blended frames instead of speeding up the framerate but never adding one duplicate frame out of 25.
26th April 2014, 08:04 | #26228 | Link | |
Stop forcing madVR into IVTC mode on progressive content, and you won't have to worry about what its doing. In general though, madVRs IVTC is pretty flexible, and if your 25p file was actually 20p with a couple of repeated fields, it would manage to detect that. (note: this example is not out of the real world, but just to illustrate what it could potentially do) AFAIK its not limited to decimating to 24p, it can handle various patterns - it previously just encountered a few issues if it has to decimate way too many frames (ie. to 24p from 60p).
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th April 2014 at 08:10. |
26th April 2014, 11:11 | #26229 | Link | |||
if MadVR finds a cadence doesn't mean it makes use of it... Quote:
or it should be able to. Quote:
if it is true 60 FPS nothing is happing and playback is fine, if it is 6:4 MadVR decimate it to 24hz and Thanks to SM every thing is fine too. WIN WIN situation BTW. this version is just a test for it. |
26th April 2014, 11:13 | #26230 | Link |
Nicolas Robidoux
Mathias:
(I am sure you are busy with other things, so I don't necessarily expect anything to happen as a result of what follows.) The current madVR Jinc4 (which I believe has a "deblur" set more or less like madVR's Jinc3) is a rather ordinary scheme compared to Jinc3. The exceptional 4-lobe Jinc scheme is the one I've been calling EWA LanczosSharpest, and last showed off in the context of pixel art resampling. It is only different from what you do already in the "deblur" that defines it, which is smaller and consequently makes it use a smaller disc. In other words, the better Jinc4 is actually a cheaper scheme than what I understand you are using now. In ImageMagick notation, it is defined by -define filter:blur=0.88451002338585141 which I would guess could be accomplished a minor modification of madVR, and would provide a Jinc4 different from Jinc3 in a worthwhile way. Some of the justification for the choice: http://www.imagemagick.org/discourse...f59ce7372d229d (To see the plots in the Luminous-Landscape post you unfortunately need to join. They make clear that EWA LanczosSharpest 4 is an exceptional passband filter. It's basically as good as tensor Lanczos without the latter's lack of damping of the checkerboard mode.) |
26th April 2014, 11:33 | #26231 | Link |
Nicolas Robidoux
Specifically, the full radius of the EWA LanczosSharpest 4 disc is
4.2410628637960699 * 0.88451002338585141 = 3.75126261284 which is not much larger than the full extent of the EWA LanczosSharp 3 you use, namely 3.2383154841662362 * 0.9812505644269356 = 3.17759889663. (I do understand that you chop off the disc a little. At 3 if I remember correctly.) |
26th April 2014, 12:11 | #26232 | Link | |
26th April 2014, 12:39 | #26233 | Link | |||
if you force 23 hz it will play the file fine as long as the cadence stays 6:4, but no IVTC detections is good enough to make this 100 % sure. you will run in problems sooner or later. 720p60 is usual TV broadcast and this makes things even more tricky, it is way harder to do this with a TV broadcast thanks to compression artifacts, on screen logos, scrolling text and a lot more.
and MadVR Decimation for higher frame rate than refresh rate is pretty bad right now too and makes even more problems. Quote:
and how do you get 720p23p out of 720p60 without MadVR modifications? Quote:
if you don't like it this is a difference thing i called some of the reason why it's a good thing, and i hope you see the benefits. |
26th April 2014, 16:27 | #26234 | Link |
Troubleshooter
Nvidia using OpenCL 1.1 AMD & Intel using 1.2
seidweise over on the KCP Codec forum put out a program that detects OpenCL on systems. Looks like AMD and Intel have the lead over Nvidia when it comes to the OpenCL version implemented on their devices. It makes me wonder if the Nvidia bug is related to Nvidia using the 1.1 version of OpenCL. Anyone feel like installing one of the old drivers that correctly functioned with OpenCL/NNEDI3, and then run seidweise's program to see if maybe the old drivers were using 1.0 compared to the new drivers which are using 1.1?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 26th April 2014 at 16:39. |
26th April 2014, 16:40 | #26235 | Link | |
26th April 2014, 21:58 | #26238 | Link | ||
The interop would report finished so madVR cleared the memory and started on the next frame but the interop wasn't really done. Not clearing the memory until later solved the black/green screen. This isn't something that would change in the specs between 1.0 and 1.1. I suppose it could be a bug present in Nvidia's implementation of OpenCL 1.1 that wasn't present in their implementation of OpenCL 1.0 but even if true I am still not sure what benefit knowing this would give us. Quote:
A new feature sets might offer a faster solution for a specific task compared to a previous version but the developer would need to implement them for them to do anything. |
26th April 2014, 22:47 | #26239 | Link | |
It's still a bug. nVidia's stance of "if there is a workaround, don't bother fixing" is bound to lead to this bug reapppearing somewhere else again.
AMD Phenom II X4 970BE | 12GB DDR3 | nVidia 260GTX | Arch Linux / Windows 10 x64 Pro (w/ calling home shut up) Last edited by Soukyuu; 26th April 2014 at 22:50. |
27th April 2014, 01:44 | #26240 | Link |
iGPU of an A10-7850K is performing remarkably well:
using Jinc as the upscaling algorithm, it can play any 1080 or below resolution flawlessly. Unfortunately, 48fps or higher content is out of question (at these settings), as well as any NNEDI upscaling or the smooth motion feature. Hopefully, it'll become e |
