25th April 2012, 17:13 | #761 | Link |
the new version crashes on first step (tsMuxer)
HybridDebugOutput.txt http://pastebin.com/FEibcTyw "Scooby-Doo şi echipa misterelor_20120424_07500815_19_07_09_151_Report.txt" Code:
Starting Main@19:07:12.588: "C:\8_Soft\Multimedia\#Video\Hybrid\tsMuxeR.exe" "C:\#EAC#\Scooby-Doo şi echipa misterelor\tsmuxer_19_07_09_151_01_0.meta" "C:\#EAC#\Scooby-Doo şi echipa misterelor" QProcess::Crashed finished after 00:00:00.029 with exitCode -2 Crash: 1 tsmuxer_19_07_09_151_01_0.meta Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr--cut-end=258s --vbv-len=500 A_MP3, "C:\#EAC#\Scooby-Doo ?i echipa misterelor\Scooby-Doo ?i echipa misterelor_20120424_07500815.ts", track=1001 |
25th April 2012, 17:16 | #762 | Link |
Old versions will crash the same way, since that is a bug in tsMuxeR.
-> it does not like anything but ASCII characters -> remoce the 'ş' from the filename and it should work update: made a version that checks for ASCII compatibility when tsMuxeR is used during processing Last edited by Selur; 25th April 2012 at 17:38. |
25th April 2012, 18:00 | #763 | Link |
I renamed the folder and filename and it almost worked
I mean the video was done as it should, but the audio was cut in the begining(as it should) but then continued to the end of the original file I tested with a 1min cut from 00:00:50 to 00:01:50, and the resulting video has 1min (2Mb) and the audio has 23min (24Mb) |
25th April 2012, 18:03 | #764 | Link | |
25th April 2012, 18:09 | #765 | Link |
new version gave me the warning about ASCII chars for this path, even thow it worked with the previous version
"C:\#EAC#\Scooby-Doo si echipa misterelor\Scooby-Doo si echipa misterelor_20120424_07500815.ts" debug in a few moments sorry, no debug as all paths do not work Last edited by pdanpdan; 25th April 2012 at 18:12. |
25th April 2012, 18:29 | #767 | Link |
debug: http://pastebin.com/3VkVXEL8
Starting Main@20:22:21.015: "C:\8_Soft\Multimedia\#Video\Hybrid\sox.exe" --guard --ignore-length --temp "C:\1" --buffer 2097152 -S -t raw -e signed-integer -2 -c2 -r48000 - -n stat finished after 00:00:13.601 finished... NeroAACEnc started... Starting Main@20:22:34.662: "C:\8_Soft\Multimedia\#Video\Hybrid\neroAacEnc.exe" -q 0.4 -ignorelength -if - -of "C:\1\1__aid_1001__20_20_36_931_09.aac" finished after 00:01:07.721 finished... deleted C:\1\1__aid_1001__20_20_36_931_05.mp2 x264 (1 pass) encoding started... Starting Main@20:24:14.656: "C:\8_Soft\Multimedia\#Video\Hybrid\x264.exe" --preset slow --crf 24 --profile high --level 4.1 --ref 10 --bframes 5 --sync-lookahead 15 --psy-rd 0.4:0 --aq-strength 0.6 --vbv-maxrate 62500 --vbv-bufsize 78125 --sar 16:15 --deblock 1:1 --colormatrix bt709 --fps 25 --input-res 704x492 --output "C:\1\1_20_20_36_931_13.264" - raw [info]: 704x492p 16:15 @ 25/1 fps (cfr) x264 [info]: using SAR=16/15 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.1 x264 [info]: frame I:15 Avg QP:21.50 size: 22084 x264 [info]: frame P:431 Avg QP:24.57 size: 6227 x264 [info]: frame B:1055 Avg QP:28.38 size: 1520 x264 [info]: consecutive B-frames: 6.3% 8.7% 19.8% 15.2% 11.3% 38.8% x264 [info]: mb I I16..4: 18.5% 78.7% 2.8% x264 [info]: mb P I16..4: 6.9% 9.0% 0.9% P16..4: 39.3% 9.1% 5.7% 0.0% 0.0% skip:29.2% x264 [info]: mb B I16..4: 0.6% 0.6% 0.1% B16..8: 24.9% 4.6% 0.9% direct: 1.6% skip:66.8% L0:36.7% L1:59.7% BI: 3.6% x264 [info]: 8x8 transform intra:56.6% inter:86.5% x264 [info]: direct mvs spatial:99.8% temporal:0.2% x264 [info]: coded y,uvDC,uvAC intra: 44.6% 69.5% 30.5% inter: 10.0% 20.0% 0.9% x264 [info]: i16 v,h,dc,p: 39% 30% 12% 19% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 18% 24% 5% 5% 7% 6% 6% 7% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 16% 14% 6% 8% 9% 6% 6% 5% x264 [info]: i8c dc,h,v,p: 43% 31% 19% 8% x264 [info]: Weighted P-Frames: Y:2.3% UV:1.6% x264 [info]: ref P L0: 63.0% 9.4% 13.5% 3.3% 2.8% 2.1% 2.1% 0.9% 1.0% 1.2% 0.6% 0.0% x264 [info]: ref B L0: 89.5% 6.3% 1.9% 0.7% 0.5% 0.4% 0.4% 0.2% 0.1% x264 [info]: ref B L1: 95.3% 4.7% x264 [info]: kb/s:615.48 encoded 1501 frames, 10.09 fps, 615.48 kb/s finished after 00:02:29.829 finished... deleted C:\1\encodingTempAvisynthSkript_20_20_36_931.avs deleted C:\1\1_20_20_36_931.d2v mkvmerge started... Starting Main@20:26:44.570: "C:\8_Soft\Multimedia\#Video\Hybrid\mkvmerge.exe" --ui-language en -o "C:\1\1.mkv" --clusters-in-meta-seek -d 0 --default-track 0:yes --default-duration 0:25fps --aspect-ratio-factor 0:16/15 --fourcc 0:MP4V --no-chapters --forced-track 0:yes --no-audio --no-subtitles "C:\1\1_20_20_36_931_13.264" --default-track 0:yes --forced-track 0:no -a 0 --no-video --no-subtitles --no-chapters "C:\1\1__aid_1001__20_20_36_931_09.aac" finished after 00:00:02.540 finished... deleted C:\1\1_20_20_36_931_13.264 deleted C:\1\1__aid_1001__20_20_36_931_09.aac Last edited by pdanpdan; 25th April 2012 at 18:32. |
25th April 2012, 18:38 | #768 | Link |
Got it! The problem is a missing space
the tsMuxeR call should include '--vbr --cut-end=110s' but according to the DebugLog it includes: --vbr--cut-end=110s (btw. the report and the normal log, really don't help me at all, there are just for normal 'user amusement') Cu Selur |
2nd May 2012, 12:54 | #772 | Link |
Hybrid rev. 2012.05.01.1
*changed*
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
3rd May 2012, 22:10 | #773 | Link |
Hybrid rev. 2012.05.03.1
*fixed*
Cu Selur |
5th May 2012, 09:48 | #774 | Link |
Hybrid rev. 2012.05.05.1
*fixed*
6th May 2012, 02:50 | #775 | Link |
Hello Selur,
thought of giving your tool a try and I gotta tell, it's pretty good There are a lots of options, selections, tools and I'm satisfied. It's the tool with a huge filesize huh? unlike other tools, it looks big I'll give it a try, encoding and will tell you more about the usage and all |
6th May 2012, 06:12 | #776 | Link |
it uses a lot of tools in the background and I dropped binary compression since it tends to cause false-positives from virus scanners,.. (-> if you run i.e. upx over the binaries they, most of the time, shrink to 30% of the current size)
6th May 2012, 06:46 | #777 | Link |
One more thing selur, I used a MeGUI profile earlier, like x264 Slower with 2599 bitrate, it took like, 4 hours for 1st pass and 6 hours for 2nd pass.
But in Hybrid, the first pass took only less than 1hour and 2nd is like 3 hours. Total time taken was only 4h 30 mins. But megui takes 12 hours :O I checked the quality and it's good too mate. Why is this? Both use 100% CPU and stuff. Last edited by meshaun; 6th May 2012 at 10:26. |
6th May 2012, 13:38 | #778 | Link |
post mediainfo report of those two files
6th May 2012, 14:59 | #779 | Link |
I'll put the video settings only
MeGUI : Code:
cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2559 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Code:
cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2599 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 |
6th May 2012, 17:20 | #780 | Link |
two things that are probably different:
1. Hybrid always sets the vbv-restrictions (unless you select: Profile->Unrestricted) but that should not cause any speed up 2. on a 64bit System Hybrid will use a 64bit x264 version, might be that MeGui is using a 32bit x264 version,... -> it's probably the difference between using a 32bit and a 64bit version, other than that Hybrid (for Windows) and MeGui both use the x264 binaries from http://www.x264.nl/ Cu Selur |
