11th June 2009, 23:31 | #5141 | Link |
Yes, you deliberately overlook that I wanted to be able to change THREE values not only the one "--crf 16".
The I reminded you that I cannot overwrite "2.0 Aften AC3 256 kbps [cbr]" and cannot find the equivalent for "--auto-chapters=3" in the GUI. You persistantly refuse or ignore to answer these questions. -> "Sure, would be easier to modify/set these values in the GUI! " ---> If it is not possible yet, add it to the wishlist, PLEASE! Have a good night! |
12th June 2009, 02:49 | #5142 | Link |
I have run into a problem with doing a mkv to mp4 conversion. I have some mkv files I created with RipBot264 and wanted to convert them down to iphone compatible mp4s. Well, when I go to load the file in RipBot264, RipBot demuxes the audio and then says "Please Wait While Gathering Info...." and then just hangs. I can adjust audio settings during this time, but video is not adjustable. Now, I am running Win7 x64 and had a similar problem when ripping VC-1 files, but that has since been rectified. Any ideas? I would really like to get some of these files converted for my son to watch...
12th June 2009, 04:20 | #5143 | Link |
Using 1.14.1, I'm getting the following error at the end of the demuxing process of a BluRay source:
"Er is onvoldoende geheugen beschkbaar" means: insufficient memory available I'm on WinXP SP3 with 4 Gb memory (3,5 Gb seen by OS 32 bits limitation) |
12th June 2009, 05:13 | #5144 | Link | |
I made an .m2ts file for Blade Runner, and then tried to use that as the input into RipBot to make an .mp4 file, but it jsut encoded the first 6 minutes or so of the film Log File from eac3to: eac3to v3.16 command line: "C:\Program Files (x86)\RipBot\Tools\eac3to\eac3to.exe" "D:\Hi-Def Movies\Blade Runner.m2ts" 1: "C:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 2: "C:\temp\RipBot264temp\job1\audio.1.w64" -down16 3: "C:\temp\RipBot264temp\job1\subtitle_1.sup" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 1 audio track, 1 subtitle track, 1:56:35, 24p /1.001 1: VC-1, 1080p24 /1.001 (16:9) 2: RAW/PCM, English, 5.1 channels, 24 bits, 48khz 3: Subtitle (PGS), English [s03] Extracting subtitle track number 3... [v01] Extracting video track number 1... [v01] Muxing video to Matroska... [a02] Extracting audio track number 2... [a02] Reading RAW/PCM... [a02] Swapping endian... [a02] Remapping channels... [a02] Reducing depth from 24 to 16 bits... [a02] Writing W64... [a02] Creating file "C:\temp\RipBot264temp\job1\audio.1.w64"... [s03] Creating file "C:\temp\RipBot264temp\job1\subtitle_1.sup"... [a02] The original audio track has a constant bit depth of 24 bits. [a02] The processed audio track has a constant bit depth of 16 bits. Added fps value to MKV header. Video track 1 contains 167708 frames. Subtitle track 3 contains 883 captions. eac3to processing took 5 minutes, 56 seconds. Done. But here is what the GUI says: Last edited by GamingDaemon; 12th June 2009 at 05:22. Reason: Adding log file. |
12th June 2009, 12:44 | #5145 | Link |
Atak, could you try and not act like a petulant child all the time? And could you please stop trying your darndest to live up to the 'totally unmannered former Eastblock kid with skills' stereotype? Because not a page goes by in this thread where I don't see your blunt rudeness flying by. And frankly, it's getting old very very fast. Over and Out.
Gorgeous, delicious, deculture! |
12th June 2009, 13:17 | #5146 | Link | |
12th June 2009, 14:50 | #5148 | Link | |
12th June 2009, 14:54 | #5149 | Link |
What is your current OS? Win XP , Vista or 7? What language did you set in OS?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th June 2009 at 15:03. |
12th June 2009, 15:45 | #5150 | Link | |
Thanks for your time and sorry for the false alarm. |
12th June 2009, 15:50 | #5151 | Link |
I do have a question regarding audio normalization. I have never been able to get it to work. Anytime I set it to either 100% or 200% with AAC audio and go to start the encode RipBot just hangs. It never starts the encode. Is there a secret I am missing?
12th June 2009, 15:58 | #5152 | Link |
You must wait longer.
12th June 2009, 17:27 | #5153 | Link |
Is that punishment for asking a stupid question previously?
I had waited before, but I guess not long enough. Thanks, works brilliantly. Last edited by Balthazar2k4; 12th June 2009 at 17:40. |
12th June 2009, 17:50 | #5154 | Link |
Normalize function must scan whole audio file in order to set maximum safe volume. It takes some time depending of movie duration and speed of your CPU.
12th June 2009, 17:51 | #5155 | Link |
Acid fr0g
coreavc freezes ripbot bt works!
There is a strange behaviour related to CoreAVC in conjunction to Ripbot: if I use hardware AVC decoding, after let's say 25% of 1st pass, the Ripbot window freeze and so does the tray icon. However, if you go with the mouse on the brown circle, it shows an increasing percentage and the encoding process goes on.
My system is Windows7 7100 RC x64, Nvidia 8600GTS and I7 920 OC to 3.33GHz. I know that FFDShow could be faster to decode AVC but having some CPU power left is useful..
@turment on Telegram |
12th June 2009, 18:50 | #5156 | Link |
It appears I was a little premature in my celebration. I just tried converting an mp4 with 6 channel aac to an iphone compatible mp4 with 2 channel aac with 200% normalize. When I start the encode Ripbot skips the audio and start encoding the video directly. The previous file I tried was an mkv with flac and that worked fine.
12th June 2009, 20:00 | #5157 | Link |
Show me log file from /Logs/ directory
12th June 2009, 20:20 | #5159 | Link |
Are you talking about DG NV tools?
12th June 2009, 20:24 | #5160 | Link |
yep, DGAVCDecNV from neuron2. I can use megui to create an avisynth and use nvidia hardware deinterlacing, which is great quality and may speed up the encoding process.
just wondered if that could be incorporated into ripbot in a similar fashion as im back to PSP encoding and want to convert my interlaced HD caps |
