Old 16th October 2007, 05:04   #1781  |  Link
sk11vengeance
Hi, im having trouble converting DTS-HD from a m2ts file to wav. Ive tried using xport from the m2ts file, then sox, then messing around in wavewizard. If I do it in that order, no matter what options i specify in xport and sox, wavewiz doesnt recognize the wav. If I split them up using tranzcode wavwiz recognizes them but I still get static, just like when I have the full wav file from converting it from .raw in sox. The most I know about the audio is its DTS-HD 5.1 48hkz (powerdvd) so ive tried those and all other format options from 2ch to 6ch and 16 to 32bit in sox for the wav. Ive also used tsremux to cut the file short so it doesnt take as long, I only want part of it which is at the very end anyway, and played around with that 195mb raw file which tsremux said was about 5.54mins worth. when I use sox on that file with options 48khz 6ch 16bit the wav length is 5.56 which is about as close as I can get it which hopefuly tells me im close but I dont know for sure. Another weird thing is wavwiz will recognize the file if I sox it to 96000khz 2ch 16bit but all I hear is static still no matter what I do.
Anyway Ive spent days on this trying to get it to work and trying this and that but I just cant figure out whats wrong. Any ideas?
sk11vengeance is offline   Reply With Quote
Old 16th October 2007, 08:23   #1782  |  Link
madshi
xport does only *demux* the audio, it doesn't *decode* it. That means the file you get from xport is still DTS-HD. Sox cannot handle DTS-HD. It doesn't have a DTS-HD decoder built in.
You can use the "eac3to" tool to convert the DTS-HD track (which you demuxed with xport) to WAV, AC3, DTS or FLAC.
Old 17th October 2007, 04:49   #1783  |  Link
sk11vengeance
Thanks for that info. I was beginning to think that. About the eac3to tool, Ive downloaded that now and try to decode the file but it says it needs:
For decoding DTS-HD files you need these filters:
(1) "Sonic HD Demuxer"
(2) "Sonic Cinemaster Audio Decoder 4.3"
(3) "Dump" filter
Ive been on the sonic.com website trying to figure out which programs include these things so I can purchase but its hard to figure out. Lastly what is the Dump filter? Is that included in the Sonic software stuff? Thanks.
Edit: Ive figured out the command lines in eac3to, its outputting a file but I dont know why im still hearing static. Im guessing because of the missing filters, I dunno. Here are my steps ive done so far:
1. demux the dts-hd track from m2ts file
2. rename extension to pcm
3. convert pcm to wav in eac3to
4. get unplayable wav.
Old 17th October 2007, 08:19   #1784  |  Link
madshi
The filter it part of Scenarist. But maybe you can also purchase it separately to save some (a lot of) money. You'd have to ask Sonic about that.
The Dump filter is shipping with GraphEdit. So you need to download GraphEdit and then register the Dump filter by executing "regsvr32 dump.ax".
Just because you rename a file to PCM doesn't make the file PCM. It's a DTS-HD file and not a PCM file. So renaming it to PCM doesn't make any sense. It only results in eac3to handling the file incorrectly.
Old 17th October 2007, 11:04   #1785  |  Link
sk11vengeance
Ok, I got the Graphedit and dump filter. One of my Irc buddies sent me the CinemasterAudio.dll and SonicHDDemuxer.dll file but when I try to register it I get an Error 0x80004005. Is there anyway to register this file? If not is there another way of decoding this DTS-HD track so I can convert it to wav? Also how do i graph the HDDemuxer? Its only got an input and no output?
Old 17th October 2007, 11:14   #1786  |  Link
madshi
I'm sorry but I won't help with pirating commercial software.
Not that I knew of. Of course most DTS decoders can decode the DTS Core just fine, but the additional DTS-HD information would be lost.
Old 17th October 2007, 11:19   #1787  |  Link
sk11vengeance
He actualy owns it, otherwise I dont think I could have gotten it. I just want to see if this actualy works before I spend money on the program. So I dont really consider it piracy. Too bad about the HD info being lost from the core.
Old 17th October 2007, 11:23   #1788  |  Link
madshi
Only if you use a conventional DTS decoder. It's not being lost if you use the Sonic decoder.
Old 17th October 2007, 11:37   #1789  |  Link
sk11vengeance
Edit: Ok. I got the Sonic dll's working finally I think. I created a graph m2ts > Sonic HD Demuxer > Sonic Audio Decoder 4.2 (4.3) > Dump. Im not sure what type of file it is when the dump is complete. The extension is .wav because I selected that in the file types when I typed a name for the dump but when I try to convert it in eac3to I get different errors like it has a bitdepth of 0 and has 0 channels. I tried renaming the file to .raw, dtshd, etc.. but no luck. The dump is DTS-HD 6ch 48khz 24bit though. So im confused on how to turn the file into a working wav. Whatever I do I just end up getting static again.
k I give up. I tried messing around more and I think all the dumping is doing is outputting a mpeg 1 2 channel file because when I go back and add that file I dumped in graph thats what sonic hd dmuxer says it is. On top of that it wont play and that would explain why I cant convert it into anything. I believe all of this is due to the .dll's not being registered correctly. So, if anyone is willing, could I just crop out the 5 or so minutes worth of the m2ts file and have someone demux the file for me thats able to do it? I can upload it to somewhere if someone can please let me know, thanks.
Old 18th October 2007, 20:35   #1790  |  Link
berndy2001
DVD-RB User
berndy2001's Avatar
How do I calculate the Subtitle Delay?
the first line (when i open the demuxed Subtitle in Supread) is 05:43:13,052 --> 05:43:15,578; there schould be a delay for about 5:43:00,000
I tried different ways, but i never come near the value it should be.
Opening file feature_300INT6LF1VC1_HD.EVO
Reading...
File size: 8811 Mbytes.
VOB number 0 contains 2 video , 4 audio and 5 subpicture streams.
PTM of first video frame = 6E19147E
PTM of last video frame = 800035FA
Duration = 0:55:37.334
VC-1 video stream 0 found!
First PTS = 2E19147E (+35791394ms)
Substream id = 55
Profile = Advanced
Level = 3
Chroma Format = 4:2:0
Size = 1920x1080
Display size = 1920x1080
Aspect ratio = 1:1 (square samples)
Frame Rate = 23,976 (24000/1001)
VC-1 video stream 1 found!
Substream id = 56
Profile = Advanced
Level = 2
Size = 720x480
Display size = 720x480
Aspect ratio = 40:33 (704x480 16:9)
Dolby Digital Plus audio stream 3 found!
First PTS = 6E19147E
Substream id = C3
Stream 3 is Dolby Digital Plus
frame size = 768 bytes, number of blocks per frame = 6
Sampling frequency = 48 kHz
Transmission bitrate = 192 kbit/s
Channel arrangement = L + R, bsid = 16
LFE channel = not present
Dolby Digital Plus audio stream 2 found!
Substream id = C2
Stream 2 is Dolby Digital Plus
frame size = 1280 bytes, number of blocks per frame = 3
Transmission bitrate = 640 kbit/s
Channel arrangement = L + R + C + Ls + Rs, bsid = 16
LFE channel = present
Dolby Digital Plus audio stream 0 found!
Substream id = C0
Stream 0 is Dolby Digital Plus
Dolby TrueHD audio stream 1 found!
First PTS = 2E191AF0 (+35791412ms)
Substream id = B1
Subpicture stream 4 found!
First PTS = 6E2754AB (+10377ms)
Substream id = 24
Format = 8bitRLE
Subpicture stream 3 found!
Substream id = 23
Format = 8bitRLE
Subpicture stream 2 found!
First PTS = 6E6A75CE (+59259ms)
Substream id = 22
Format = 8bitRLE
Subpicture stream 1 found!
First PTS = 6E7863DE (+69402ms)
Substream id = 21
Format = 8bitRLE
Subpicture stream 0 found!
Substream id = 20
Format = 8bitRLE
m00!
berndy2001 is offline   Reply With Quote
Old 19th October 2007, 10:22   #1791  |  Link
Darth Pinous
Darth Pinous's Avatar
Why not just :
1) Use xport to dump the DTS-HD file or build a graph like this : m2ts > Sonic HD Demuxer > Dump (no need for Audio Decoder here, but name your file .wav to obtain the dump).
2) Rename your dumped DTS-HD file with .dts extension
3) Pass it through Tranzcode. Tranzcode will read only the DTS core and give you a valid 32 bits WAV output (or less, if you want 16 or 24 bits output).
Darth Pinous is offline   Reply With Quote
Old 28th October 2007, 05:52   #1792  |  Link
saint-francis
too much lurking
saint-francis's Avatar
I have just encountered a situation which is entirely new to me with EVODemux. I have 2 video sources. One is h.264 and the other is VC.1. When I merge the two EVOBs I get a file that graphedit doesn't like. I can't connect the rebuilt EVOB to the WMVideo Decoder DMO. I have rebuilt the EVOB with both video streams and rebuilt them separately. When I only rebuild the VC.1 video I get a small (600 MB or so) file that I can connect with the graph. I also couldn't help but notice that the resolution of the VC.1 stream was 720/480 at 23.976 fps while the H.264 stream is 1920/1080 @ 60 fps. Naturally this is very confusing to me since I don't understand how one video can have two different resolutions and frame rates. This is a new HD DVD which I was just able to decrypt tonight after having it for about a week and not being able to watch it on my non HDCP compliant monitor; so maybe this is some new arrangement never before seen?
Opening file FEATURE_1.EVO
Reading...
File size: 12903 Mbytes.
VOB number 1 contains 2 video , 5 audio and 8 subpicture streams.
PTM of first video frame = 00001282
PTM of last video frame = 1723D82F
Duration = 1:11:53.559
H.264 (AVC) video stream 0 found!
   First PTS = 00002FD6  (+83ms)
   Substream id = E2
   Profile = High
   Level = 4.1
   Chroma format = 4:2:0  (l, c) = 8, 8 bit
   Size = 1920x1080
   Video format = Component
   Time scale = 0 MHz
   Frame rate = 60 fps
   First PTS = 00001282
   Substream id = 56
   Profile = Advanced
   Level = 2
   Size = 720x480
   Frame Rate = 23.976 (24000/1001)
   Substream id = C3
   Substream id = C2
   frame size = 1536 bytes, number of blocks per frame = 3
   Transmission bitrate = 768 kbit/s
Dolby Digital Plus audio stream 1 found!
   Substream id = C1
   Stream 1 is Dolby Digital Plus
   Substream id = C0
   frame size = 1024 bytes, number of blocks per frame = 1
   Transmission bitrate = 1536 kbit/s
Dolby Digital Plus audio stream 8 found!
   First PTS = 00001444  (+5ms)
   Substream id = C8
   Stream 8 is Dolby Digital Plus
   First PTS = 00489BD7  (+52819ms)
   Substream id = 24
   Format = 8bitRLE
   Substream id = 23
   Format = 8bitRLE
   Substream id = 22
   Format = 8bitRLE
   Substream id = 21
   Format = 8bitRLE
   Substream id = 20
   Format = 8bitRLE
Subpicture stream 7 found!
   First PTS = 004B5BAB  (+54821ms)
   Substream id = 27
   Format = 8bitRLE
Opening file FEATURE_2.EVO
Reading...
File size: 12761 Mbytes.
VOB number 2 contains 2 video , 5 audio and 8 subpicture streams.
PTM of first video frame = 1723D82F
PTM of last video frame = 2E2C5A3A
Duration = 1:11:33.706
   First PTS = 1723F582  (+4313642ms)
   Substream id = E2
   Profile = High
   Level = 4.1
   Size = 1920x1080
   Time scale = 0 MHz
   Frame rate = 60 fps
   First PTS = 1723A4C4  (+4313413ms)
   Substream id = C8
   First PTS = 1723AE42  (+4313440ms)
   Substream id = C2
   Substream id = C1
   Substream id = C0
   First PTS = 1723D82F  (+4313559ms)
   Substream id = 56
   Profile = Advanced
   Level = 2
   Size = 720x480
   First PTS = 1723D002  (+4313536ms)
   Substream id = C3
   First PTS = 1724A577  (+4314143ms)
   Substream id = 24
   Format = 8bitRLE
   Substream id = 23
   Format = 8bitRLE
   Substream id = 22
   Format = 8bitRLE
   First PTS = 1724B132  (+4314176ms)
   Substream id = 21
   Format = 8bitRLE
   Substream id = 20
   Format = 8bitRLE
   First PTS = 1773819A  (+4371567ms)
   Substream id = 27
   Format = 8bitRLE
Done.
5224 counted frames (0:03:37.884) in video stream 0.
206368 calculated frames in video stream 0.
6522 counted frames (0:04:32.022) in video stream 1.
206368 calculated frames in video stream 1.
Reading HVA00001.VTI
8 VTS_EVOB_ATRs found.
12 VTS_EVOBIs found.
Done.
saint-francis is offline   Reply With Quote
Old 28th October 2007, 12:24   #1793  |  Link
Thunderbolt8
look at the resolution of both video streams: the other stream with 720*480 belongs to the extras, it has nothing to do with the 1st stream, which belongs to the main movie
Old 28th October 2007, 14:33   #1794  |  Link
saint-francis
too much lurking
Makes sense. But when I rebuild the .EVO with only the avc stream I can't connect it in graphedit the normal way. Is there a separate procedure for loading h.264 streams? Could I just use DGavcdecode?
Old 29th October 2007, 13:48   #1795  |  Link
superx
is there a way to remove the flags from a AVC HD-DVD to make it complient with blu-ray. Trying to get the video to stream to my PS3 over the network. Thanks
superx is offline   Reply With Quote
Old 29th October 2007, 18:35   #1796  |  Link
saint-francis
too much lurking
I have tried ripping and re ripping this movie with no luck. I have found no way to decode the .EVO rebuilt with only the h.264 at all. I have tried to remux to .mkv with GDSmux and every time I try GDSmux crashes at 9.2%. If I render the rebuilt .EVO with graphedit it gives me .EVO -> Sonic HD Demuxer -> ffdshow video decoder. I tried to load that graph and that doesn't work either. All of the searching of this forum and all of the Googling I have done reveals nothing overtly helpful to me in this instance. Can anyone please help shed some light on this?
Old 29th October 2007, 19:00   #1797  |  Link
tomos
strange, works fine on mine with AVC vids - via the EVO or just raw AVC.
you tried whatever.h264 -> sonic demux -> sonic video decoder?
raw AVC is read fine by DGAVC for me also (most recently for transformers)
tomos is offline   Reply With Quote
Old 29th October 2007, 19:50   #1798  |  Link
saint-francis
too much lurking
It's not raw AVC. It's a rebuilt EVO. I don't know how to handle it. Can I extract the AVC from the .EVO somehow? I assume so. Using DGAVCDecode would be excellent.
Old 29th October 2007, 19:54   #1799  |  Link
tomos
of course, just use evodemux and just choose demux instead of rebuild.
evo's work fine too if you have haalis stuff installed.
in graphedit iirc its
haalis media splitter and choose your file. - link to whatever decoder you prefer. coreavc, ffdshow etc.
also works fine for me.
Old 29th October 2007, 20:11   #1800  |  Link
saint-francis
too much lurking
Sorry I must have spaced when reading your 2nd to last post. Transformers? The HD DVD? That's what I'm trying to tackle. I'm demuxing the AVC as I type (thanks for the tip btw). So you just loaded the AVC with DGAVCDecode in your AVS script?
