8th August 2011, 08:02 | #9182 | Link |
Nice alternative, focusing only on the screen capture features, you miss out on the repeat screen capture every x seconds option. The JPEG format is not recommended when comparing image quality between two images. The free capture to PNG option is nice but when you tend to delete the files after comparing them I find it really doesn't matter so choose whatever suits you.
8th August 2011, 14:07 | #9184 | Link | |
somehow, I cant capture the screen when in fullscreen. its captured, but in the wrong timeline and/or with a wrong aspect ratio. windowed mode works fine |
10th August 2011, 01:52 | #9187 | Link |
If I go to MPC-HC's external filters menu and add “madVR” from the list as prefer, then subtitles disappear - they work fine when using madVR “normally”, together with the internal decoders of madVR.
Furthermore, in the filters menu during playback, it reports “madVR” instead of “madVR renderer” - however, madVR is doing the decoding in both cases. I am certain of this because it displays “libav” in the OSD and not “H.264, 10 bit, 4:2:0 -> P010, 10 bit” or something like it would do with LAV/ffdshow/MPC-HC's internal renderer, also the internal renderer wouldn't even be able to decode Hi10P properly. Is this filter being misregistered somehow? I can't get “madVR Renderer” into the filters list either, even if I add the .ax file manually. Does MPC-HC interface with madVR uniquely in some way? Moreover, why does switching to “madVR” instead of “madVR Renderer” cause subtitles to disappear?
Forget about my old .3dlut stuff, just use mpv if you want accurate color management |
10th August 2011, 02:03 | #9189 | Link |
How recent are we talking, here? I'm using v1.5.2.3456, do you know in which version it was (approximately) fixed? (I'm asking because I'd like to compile this information elsewhere)
10th August 2011, 02:03 | #9190 | Link |
Sorry I don't remember the version. It was posted a few pages back I believe. If you look back a bit you should be able to find it.
10th August 2011, 02:05 | #9191 | Link | |
Found it for you:
10th August 2011, 02:14 | #9192 | Link |
Thanks. This is newer than the latest build advertised as stable, but I'll add it to the troubleshooting section nonetheless.
Still, the alternative is to work around the issue by blocking all filters you don't want to use, or setting their merit below madVR's. You can use madVR with MPC-HC just fine that way and retain OSD+subtitle functionality.
10th August 2011, 02:17 | #9193 | Link |
I use MC16, but, I routinely build MPC-HC with no internal filters. So I'm glad madshi fixed it. Still, your work around will suffice until people get a new build. I recommend getting the fixed version if possible.
10th August 2011, 21:32 | #9194 | Link |
Strange, seems my previous reply never made it out of the moderation queue...
Anyway, I just wanted to report a small issue. Using madVR 0.73 and Directvobsub 2.40.3300 + ffdshow as renderer and MPC-HC as player and Haali as splitter, I'm experiencing some strange color changes by switching between original resolution and doubled resolution subtitle rendering in Directvobsub: Original resolution: http://i3.imgkeep.com/i/00051/4c7pmgp5p7q2.jpg Doubled resolution: http://i3.imgkeep.com/i/00051/gv15s31ya54o.jpg This doesn't happen with other renderers, so I think it must be an issue with madVR, e.g. with Haali renderer: Original resolution: http://i3.imgkeep.com/i/00051/yobri8x0u1b6.jpg Doubled resolution: http://i3.imgkeep.com/i/00051/lfne1enoabe7.jpg There also seem to be some cropping differences here. The first screen from madVR has one more row of pixels at the top and one more column at the left while it has one row less at the bottom and one column less at the right in comparison to the second screen. And yeah, I'm 100% sure that the frames are identical. |
11th August 2011, 05:46 | #9196 | Link | |
As for the 0-255 issue, I've seen some people say that if you set the Dynamic Range in the Nvidia drivers, it only sets that for video... desktop remains compressed 16-235 when using HDMI. In order to get both to output 0-255, you have to create a custom resolution. Or something along those lines. Last edited by rahzel; 11th August 2011 at 05:50. |
11th August 2011, 14:11 | #9198 | Link |
The default settings give great quality. Beyond that it's up to your personal preference and what your system can handle. Some algorythm require more power than others. But there's no "best for everyone" settings otherwise madshi wouldn't have bothered giving us the choice now would he ?
11th August 2011, 19:26 | #9199 | Link | ||
11th August 2011, 19:48 | #9200 | Link | |
Add HKR,,SetDefaultFullRGBRangeOnHDMI,%REG_DWORD%,1 to each section of your driver inf before installing, lines that begins with [nv_miscBase_addreg_ eg [nv_miscBase_addreg__01] HKR,,SetDefaultFullRGBRangeOnHDMI,%REG_DWORD%,1 I often have to do a clean driver install, to make this take effect, if I had installed drivers previously without it. |
