Old 11th December 2019, 19:19   #58121  |  Link
Klaus1189
from madvr suggested timing details. It depends what you like best, I personally want to keep the filmlook like the filmmaker wanted it to look, so I use straight 23 Hz.
Old 11th December 2019, 19:31   #58122  |  Link
Morgin187
yeh ive managed to fix it. got it at 23.975 and it switched automatically when playing videos in madvr. thanks alot its made a huge difference matching the refresh to the source. also going to stop looking for things like this and then spending hours trying to solve them lol. thankyou very much for all your help i appreciate it loads
Morgin187 is offline   Reply With Quote
Old 11th December 2019, 23:10   #58123  |  Link
Asmodian
24 or 48 Hz are identical as far as the film look goes. There is no frame rate conversion or anything (assuming smooth motion is off, which is should be with a tuned refresh rate). All that happens is that the frame is displayed twice. This is not perceptible, it really is identical to watching at 23 Hz, so there is no downside to using 48 Hz if your display has trouble with 23 Hz or if you simply want your mouse more responsive when watching 23 fps content.
madVR options explained
Old 12th December 2019, 05:16   #58124  |  Link
Klaus1189
I know but why hassle if the TV can not display special framerates, the native do work at least. Maybe I was not clearly enough, I personally prefer 23 Hz over smooth motion at high refresh rate because this is not like the filmmaker wanted it to look.
I tried already some time ago twice refresh rates but only a very old Monitor did accept such a refresh rate, every TV I tried didn‘t supported it.
Old 12th December 2019, 10:09   #58125  |  Link
Siso
Soul Seeker
Siso's Avatar
What do you mean by smooth motion enabled with high refresh rates? Like 72, 96, 120, 144 Hz + smooth motion?
Siso is online now   Reply With Quote
Old 12th December 2019, 11:25   #58126  |  Link
ryrynz
ryrynz's Avatar
You can "personally prefer it" that's fine, I prefer it also but it's because the image is noticeably sharper on my current and previous set.
To say it's "Not as the filmmaker intended" is getting confused with the recommendation of filmmakers for disabling motion interpolation which I agree with as it actually presents the film quite differently from intended.
Smooth Motion actually attempts to display it actually as the filmmaker intended. Most purists would agree with matching refresh rates to source frame rates but for some there is not a noticeable difference between the two.
Also recall the calculations done by Asmodian not that long ago that show that the higher the refresh rate the better Smooth Motion performs with less blended frames.
Old 12th December 2019, 16:45   #58127  |  Link
mclingo
Hi, just wondering, why does doubling refresh rate make it look sharper?
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 12th December 2019, 17:22   #58128  |  Link
Klaus1189
On some TVs the picture settings can be adjusted according to refresh rates, at least on all my Samsung TVs and there is also in PC the difference that picture looks natural at 50 (0 ... 100) without any additional sharpening, but on 60 Hz in PC mode it has to be adjusted to 0 that no additional sharpening is done.
And why bother with double refresh rates for no benefit at all, despite that it might not work at all on most TVs because it doesn‘t allow weird refresh rates, at least weird for the TV.
I have a socalled 120 Hz panel and everybody tells me that it is much better, but I do not see any benefit at all compared to a good 60 Hz panel. I also don’t know why they call it that way, because these panels display can display 50 Hz also.
I can live with that that I am a „purist“, but if you have a 50fps video and watch it at 60Hz how can this be smooth especially at panning shots. This is another reason for me to use matching refresh rates.
But hey, everybody how he/she likes.
I mean using higher refresh rates which can not be a multiple for all major refresh rates like 23/24/50/59/60.
I dropped 25/29/30 because you loose the intention of interlacing if you use one of these three.
To come back to 144 Hz for example, how can that display all different framerates right without having changed the smear, I don‘t know if this is the right word, but if you do anything to watch it on another multiple than the native refreshrate matching for that framerate, you will change the picture to be clearer or more smeared. I mean for describing the motion speed, the filmmaker can choose the right settings in the cam. But using matching refresh rates doesn’t affect that sort of thing.
Every better hardware player can do it, but I like a software player best, for best future proof.
I bet that every Blu-ray player above 50 Euro does support 24Hz output when the movie starts. My good old ps3 does that also. I am not using it anymore but it did it already 10 years ago.
Old 12th December 2019, 17:24   #58129  |  Link
Asmodian
It isn't doubling the refresh rate that makes it look sharper, it is turning off smooth motion at 60 Hz and using a tuned ~24/48/96/120 etc. Hz refresh rate that is sharper (60Hz without smooth motion would be just as sharp but would have terrible judder). Smooth motion blends frames to present the source frame rate as accurately as possible on the display's refresh rate. It does not smooth the motion beyond avoiding terrible judder but the use of blended frames does reduce apparent sharpness to some degree.
At high refresh rates this becomes minimal and the experiance of a tuned 23Hz and smooth motion at 120+ Hz is effectively identical.
Edit: I don't know what issues your TV has but I am confused by your rant. I don't think anyone has ever suggested 50 fps on 60 Hz. That looks bad no matter what. You really want the refresh rate to be at minimum over double the frame rate before smooth motion is a decent option.
Smooth motion for any normal frame rate on a 144 Hz screen works very very well. Motion blur is still exactly as the movie was shot, there is nothing that changed or should be changed about the motion blur when using smooth motion at any refresh rate. madVR's smooth motion is not like your TV's or whatever motion interpolation. We are talking about how often the electronics update, not how often the image actually changes.
I am also not saying matching the refresh rate is not ideal, or that using double the frame rate is better; only that it is not worse.
Old 12th December 2019, 17:43   #58130  |  Link
Morgin187
I get ghosting when using smooth motion in madvr. So far matching the exact frame rate to the movie frame rate gives a smooth and film like experience with no judder or artefacts. This coupled with 10 judder and 5 smooth on my tv settings gives a almost perfect picture.
Old 12th December 2019, 17:46   #58131  |  Link
Asmodian
These seem suspect to me. What do they do and does it actually look better with them on? How does smooth motion look if you turn them off? You definitely cannot mix smooth motion with any of those options. Smooth motion is really intended for monitor like displays, displays that do not do any of their own image processing.
Why not just use a matched refresh rate? That or an exact multiple is always the ideal if you can get it.
Edit: Again, smooth motion is not trying to improve anything beyond a matched refresh rate. Smooth motion is for getting an experiance close to a matched refresh rate (assuming a high refresh rate display) without needing matched refresh rates.
Old 12th December 2019, 17:51   #58132  |  Link
Klaus1189
Asmodian, are you referring to me with post #58142? If so, I cannot see the connection. What did I wrote and must admit don't understand that. Please use easier words for a non-native english speaker
I did several tests in the past and the motion isn't that bad, but for example I get some parts of the image in scenes especially with detailed textures are getting flickering, but on native refresh rate it is fine. I stay where I am and all theoretically stuff cannot beat my own perception of the image, that it looks best to use always the matching refresh rate.
Here's an animation how I see the flickering, keep it mind, that it only looks that way, and got nothing to to with interlacing because the videos are progressive.
Old 12th December 2019, 17:55   #58133  |  Link
Asmodian
I think you misunderstood my entire point.
Nothing is better than a perfectly matched refresh rate, or a perfect multiple of the frame rate. Keep using your settings!
Old 12th December 2019, 18:01   #58134  |  Link
Klaus1189
That is very possible for me
Good to know
Old 12th December 2019, 18:21   #58135  |  Link
they are called 120 hz panel because they display 24p at 120 hz.
displays don't support refreshrate as 24p not even in cinema where 72 and 96 hz or even more are used to display 24p sources on refresh based technology.
a 60 hz panels usually can't do 24p at all they convert it to 60 using a 3:2 pullup which is clearly not the creators intend but what ever...
seem to be the same to you.
because an LCD is sample hold so the refreshrate doesn't matter in this cease the smearing is always the same.
to be absolutely clear here an LCD is not displaying content accurate because it takes to long to switch the pixel and OLED is still sample load based to the motion resolution is very low.
the number of TV that can't do 50 hz is quite big just so you know. pal support is not mandatory in NTSC countries.
good to have smoothmotion still far from optimal situation for it but better then nothing.
is obviously doesn't do that on a sample hold displays like an LCD or OLED. the image displayed on the screen is the same the pixel stay the same time in the same state.
on refreshrate based screens like plasma and CRT it lowers flicker but increases ghosting you have to choice one of them.
for 24p you have the ghosting anyway so higher doesn't hurt for 60 fps content it hurts motion resolution if displayed at 120 hz.
who cares if the screen can't do it.
typical result if your screen is motion interpolating with smoothmotion. so much about purist.
smoothmotion exist for device with problem in 24p mode or screens that simply can't do it like PC screens to keep the creators intent.
the motion interpolation on a TV is created to smooth the motion by creating fake frames which has nothing todo with the creators intent.
if you don't have that problem why should you use it?
just to give you an example samsung TV treat 24p source international wrong and create a 3:2 judder unless you set the motion interpolation setting correctly to custom 0 0.
LG usually needs real cinema to be enabled or they also do it intentionally wrong.
sony well i let you guess how they handle this situation to display 23p as the creator intent and what you need to setup to get true 23p.
just to show you how dumb TV brands are.
Old 12th December 2019, 18:34   #58136  |  Link
Klaus1189
But on the small TV with 60 Hz panel it does look different when I feed it with a 24fps video in 24Hz and with 60Hz. When 60 Hz is applied I see the judder. I did a blind test and when I checked it with OSD info I got always right. Strange, I think I must buy new eyes.
I disabled "Samsung smooth motion" on all my Samsung TVs.
Did you read it carefully what I wrote? Why should a slow pan on 50 fps video be showing at 50 Hz the same flickering like it does when set to 60 Hz while doing madVR to smoothmotion. Download some pan shots and compare for yourself.
I turned on smooth motion in Samsung TV and it got very smooooooooooth, so it was definitely off.
Why are again so challenging
This behavior doesn't make it easy for me to come back to help people.
Old 12th December 2019, 18:40   #58137  |  Link
how do you even know if a german TV is 60 hz? i know no one that test them.
and if you are so so sure about that tell that's testing sites and question the existent of these option and why rtings tests this if it it's doing nothing at all.
why are you so ignorant and only read the parts you like and ignore the rest.
Old 12th December 2019, 19:28   #58138  |  Link
Morgin187
keep helping people you helped me quite a lot
Old 12th December 2019, 19:38   #58139  |  Link
Morgin187
Blur reduction at 10 gives smooth image without any ghosting. Judder reduction at 5 stops the skipping look when the scene pans around. I've tried with them off and its just way better with them on. Still keeping the film look and no soap opera effect which i hate personally. Try it
Old 12th December 2019, 19:39   #58140  |  Link
Klaus1189
I don't get the question, do you mean displaying a 60 fps video or what exactly?
My main TV is a Q9FN and rtings tested it:
24p Judder
Judder-Free 24p <- this one is relevant for my usage
: Yes
Judder-Free 24p via 60p
: Yes
Judder-Free 24p via 60i
: No
Judder-Free 24p via Native Apps <- this one is also relevant for my usage
: Yes
The Q9FN is nearly judder free. When playing 24p content through a 60i source, like from a cable box, the Q9FN was inconsistent in removing judder. In a 24 frame test, there is judder in only 2 of the frames. This probably won't be noticeable to most people. Like other Samsungs we have tested recently, this result is unexpected and we will retest this with future firmware updates.
See full details here:
https://www.rtings.com/tv/reviews/sa...-q9f-qled-2018
IMPORTANT:
I think I made a mistake, the second TV, the small one I use with madVR is a UE43KS7590UXZG and I thought it has a 60 Hz panel, but it seems it has also a 120 Hz panel, so please forget the 60 Hz panel thing, because of this wrong info in my head I thought a 60 Hz panel is also capable of doing perfect 24p.
But if you look the the rtings page and hoover the mouse over the "?", there are lots of TVs which are rated "0.0" and if I look them up in the test they all use a 60 Hz called panel and can'T do 24p native.
SORRY for my mistake, but since I use 120 Hz panels there's nothing wrong with refresh rate changing, because on these two displays 24Hz looks good to me.
So if a user has one these TVs it will definitely be better to use smoothmotion at 60 Hz output as best usage with this TV. But if you have a 120Hz pnale in the TV the TV is able to do correct 24p? Correct me if I am wrong.
Can I download this sample video used here:
https://www.youtube.com/watch?v=CuEZ...ature=emb_logo
Or do I have to create my own with my NLE?
Source:
http://www.hifi-forum.de/viewthread-116-57040.html
https://www.zambullo.de/fernseher/datenblatt/UE43KS7590
I want to do that test on my own with my TVs as well since I have a DSLR and all that crap needed.
Thank you for opening my eyes, huhn
