Old 18th November 2016, 22:34   #40181  |  Link
VenomousNinja
Also in previous build I was able to preview settings on the fly - set picture on pause and changed various madVR settings - changes reflected immediately. Now any setting i'm playing with doesn't impact an image on the fly.
Win 10 x64 LTSC 1809, 16 GB RAM,
Nvidia GTX1080, AMD FX-8350
VenomousNinja is offline   Reply With Quote
Old 18th November 2016, 22:35   #40182  |  Link
sneaker_ger
Please check luma doubling. not chroma upsampling. The OSD is not conclusive for chroma.
Not working, I think.
https://www.sendspace.com/file/u97c7f
Old 18th November 2016, 22:37   #40183  |  Link
sneaker_ger
1) Do you have f.lux running?
2) Or GpuZ?
3) Or FRAPS?
4) Or any other similar software which might access the GPU?
5) Do you use Reclock? Does it work if you disable Reclock?
None of the above.
Radeon HD 5850
Driver: 15.200.1046.0 WHQL (Catalyst 15.7)
Win 7 x64 SP1
Aero off
Old 18th November 2016, 22:38   #40184  |  Link
aufkrawall
How does NGU high compare to NNEDI3 64 for you?
720p 60fps -> WQHD, everything else than ordered dithering disabled, bilinear chroma scaling, CPU decoding:
NGU High: ~11ms
NNEDI3 64: ~9ms
NNEDI3 64 + SR3: ~11.85ms
Everything tested with full GPU clock.
Old 18th November 2016, 22:40   #40185  |  Link
TheShadowRunner
TheShadowRunner's Avatar
Those of you with keyboard shortcuts (and probably NGU) not working:
2) Or GpuZ?
3) Or FRAPS?
1, 2, 3 & 4: No.
5: Yes I do use Reclock, I tried without it (default directsound device): no change.
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 18th November 2016, 22:41   #40186  |  Link
you know you can use the advanced render steps setting to get the ms used by NGU.
EDIT:
ShowRenderSteps all over rendertimes 32 ms and without 21 ms.
well that's interesting...
Old 18th November 2016, 22:45   #40187  |  Link
Vegekou
2) Or GpuZ?
3) Or FRAPS?
1) No
2) No
3) No
4) No. I tried to disable my AV but still no.
5) No
Vegekou is offline   Reply With Quote
Old 18th November 2016, 22:50   #40188  |  Link
VenomousNinja
Seems no scaler is working as IQ doesn't react to changes.
Old 18th November 2016, 23:00   #40189  |  Link
asmo42
Would be great to get performance comparison results from different GPUs and OSs, NGU vs NNEDI3.
Win 10, GTX 970. NGU medium is about the same speed as NNEDI3 32 and NGU high about NNEDI3 128.
asmo42 is offline   Reply With Quote
Old 18th November 2016, 23:00   #40190  |  Link
clsid
regsvr32 just hangs on Win10 (in VirtualBox).
Old 18th November 2016, 23:01   #40191  |  Link
Siso
Soul Seeker
Siso's Avatar
Is it only me or the Ctlr+J shortcut is not working?
Old 18th November 2016, 23:02   #40192  |  Link
aufkrawall
Forgot that this is possible, but I don't think it would show anything interesting in my case.
(a hotkey for it which would also listed in the hotkey list would be nice)
Old 18th November 2016, 23:07   #40193  |  Link
MariaX9
The Shortcuts are only working when the Video is running.
Performance:
R9 GPU
chroma and image doubling NGU High: 20s
chroma and image doubling NNedi 64: 22s
MariaX9 is offline   Reply With Quote
Old 18th November 2016, 23:08   #40194  |  Link
markanini
From my testing soften edges is a rewquirement for live action. NGU medium doubling seems manageable on my HD7770 for SD and 720p on a 1080 display as long as other settings are defaults. Very impressive and happy to replace SuperXR-AB+SR.
markanini is offline   Reply With Quote
Old 18th November 2016, 23:17   #40195  |  Link
looks like NGU doesn't like IVTC images and MPEG2 compression artifacts:
doubling into spline3 AR
NGU medium: https://img3.picload.org/image/rdwlpoao/ngu.png
XBR100: https://img3.picload.org/image/rdwlpoap/xbr100.png
nnedi3 256 SR4: https://img1.picload.org/image/rdwlwgdg/nnedi3sr4.png
source: https://abload.de/img/source2beugl.png
Old 18th November 2016, 23:17   #40196  |  Link
thighhighs
I try find suitable settings for me. Some answers will be helpfull:
med vs high quality difference big, or it like nnedi 32 vs 64?
Using NGU (med) for chroma upsampling (chroma upscaling section) add extra quality (vs bicubik 75, for example)? Or i just waste gpu resources?
In personal teste, these differences not obvious for me. Anyway, NGU looks great, even without SuperRes.
thighhighs is offline   Reply With Quote
Old 18th November 2016, 23:20   #40197  |  Link
JarrettH
Is doubling worth it for 720p content on a 1080p monitor?
Old 18th November 2016, 23:25   #40198  |  Link
cnckane
I noticed that AMD video color settings are not applied in fullscreen mode when 1080p video is playing on my 1080p screen. The only difference is that there is a "Crop 2" procedure applied during the render.
If I use MPC HC zoom feature and outzoom the color settings are applied. Is there any way to make it work ? I use a combination of Madvr and AMD video settings, works fine with all videos except 1080p.
cnckane is offline   Reply With Quote
Old 18th November 2016, 23:26   #40199  |  Link
madshi
For those of you with keyboard shortcuts and NGU not working, please try this test build:
http://madshi.net/madVR91b.rar
Does it fix the problem?
Old 18th November 2016, 23:26   #40200  |  Link
i recommend you to try it out and ask your eyes.
