1st December 2007, 23:50 | #301 | Link |
Could you try to encode something but without audio? (iphone profile + No audio + PSP resolution)
2nd December 2007, 00:43 | #302 | Link |
This small sample was encoded with neroAACenc instead of CT
iPhone http://www.mediafire.com/?eydy5d5jtz1
2nd December 2007, 00:58 | #303 | Link | |
Success!!!
2nd December 2007, 01:04 | #304 | Link |
Test also this one
http://www.mediafire.com/?bjezebdoxdb
2nd December 2007, 01:29 | #307 | Link | |
Success Again!!
Recognized by iTunes, plays perfect in iphone... |
2nd December 2007, 01:29 | #308 | Link |
Finally I found the problem with audio
enc_aacPlus ALWAYS saves aac stream in MPEG2 AAC format instead of MPEG4 AAC even if I don't use --mpeg2aac switch! Luckily it can be changed during muxing by adding -mpeg4 switch after audio stream. You cannot export because I didn't mux with -ipod switch. New version will be available tomorrow when I come back from work.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd December 2007 at 01:34. |
4th December 2007, 22:39 | #316 | Link |
Thanks for the great program! This makes it a lot easier to convert videos for my iPod touch. I am just having one small problem.
The program is unable to open x264 mkv files. I get the error "The video could not be decoded." I originally go this error for any video but then I re-installed Avisynth and avi files worked, but not mkv. At first I thought it couldn't handle a 4GB file, but it gives me the same error for a 90MB file. I just installed Haali Media Splitter today (always used VLC so I never needed it) so it should be the latest version. FFDShow is revision 1324. Any ideas as to what my problem is? Thanks a lot. |
5th December 2007, 00:31 | #317 | Link |
Uninstall FFDShow and then download new version http://sourceforge.net/project/showf...ease_id=439938
Also try to install older version of Haali Media Splitter. See first post. if you still get this error try to find getinfo.avs and open it in mpc. MPC should show you some error message.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th December 2007 at 01:54. |
5th December 2007, 04:22 | #318 | Link | |
Do you think I will have any problems since I'm not using the "stable" version of ffdshow anymore? Thanks again! |
5th December 2007, 10:58 | #319 | Link | |
I suggest to check both options (Don't use FFDshow and Use only in ...)
