12th August 2008, 20:23 | #1 | Link | |
Import Avisynth scripts in a new Blender build!
Apparently there is a Blender build out now which supports avisynth in the Sequence Editor. You can find it here!
And using Avisynth to import AVC in Blender here! Spamagnet: Quote:
DVD slideshow GUI(Freeware). |
12th August 2008, 20:57 | #3 | Link |
12th August 2008, 22:24 | #4 | Link |
Resize Abuser
Nice find tin3tin! This is quite an amazing development!
Found another link with more "behind the scene" details http://www.blender.org/forum/viewtopic.php?p=68387 What would be very cool is if Blender used Avisynth code for some of the editing that it does. This at it's current stage is highly unlikely since they use FFMPEG to load avs files. I wonder if they knew about AVFS? Either way, another win for Open Source! BTW does this mean that FFMPEG on linux can read avs files? Looks like I need to kill some time with blender and see what it's NLE is capable of in the near future. EDIT: Windows only as of right now
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 19th August 2008 at 00:22. |
12th August 2008, 22:48 | #5 | Link |
TheNut has added a lua processing script reader in the plugin folder - which can ex. fade in/out.
I guess if he can do this it is possible(for him?) to add Avisynth scripts for processing as plugins too? For Blender newbees (as myself). Here are a few tips:
DVD slideshow GUI(Freeware). Last edited by tin3tin; 12th August 2008 at 22:58. |
28th November 2008, 23:34 | #6 | Link |
all versions (2.46, 2.47, 2.48a) of those avisynth-enabled blender builds crash when loading any avs.script?
athlon x2, windows xp, latest avisynth 2.58 beta (2.57 crashed too). any suggestions on why this happens to me? avisynth scripts in blender would save my life!!! |
29th November 2008, 08:37 | #7 | Link |
Resize Abuser
option B for loading avs in blender is to use AVFS
http://www.turtlewar.org/avfs/
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer |
29th November 2008, 12:30 | #8 | Link |
thanks for the tip, mikeytown2!
however, there is a problem with avfs and blender! i cannot open a AVFS uncompressed rgb32 file! "the selected file is not a movie or FFMPEG-support is not compiled in" it seems that blender can only open the uncompressed YUV format. but rgb32 format is needed for its alpha-channel. Last edited by jemmel; 29th November 2008 at 12:32. |
