13th January 2010, 10:31 | #3021 | Link |
Derek Prestegard IRL
FANTASTIC program! I haven't used it in a long time, and am THOROUGHLY impressed with its batch encoding function. I'm very happy!
Transcode my season 1 backup of Penn and Teller to iPhone compatible H.264 and AAC in an MP4? At 200 fps using the fast preset?!? Sweet! <3 ~MiSfit
These are all my personal statements, not those of my employer :) |
13th January 2010, 18:05 | #3022 | Link |
@Blue_MiSfit
it surely is all thanks to the dedication, support & amazing coding skills of stax76 StaxRip continues to evolve after so many years welcome to StaxRip Nation Blue_MiSfit
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
13th January 2010, 21:19 | #3023 | Link |
Yeah the batch encoding is extremely useful! along with every other function in the programme I really hope Staxrip continues to evolve. Its continued support (instead of sporadical support) is vital to ensure the latest features are incorporated into the programme, whether its with new functions that become available or through new versions of programmes. I update some of the components myself (and just click through the new version dialogues), mostly x264. Although I have updates mkvtoolnix, dgindex, ffmpeg, mediainfo, projectx (using oozoon's latest), and yadif previously.
I've been using Staxrip for over 3 years now I reckon, its always been my choice for the command line x264 Keep up the great work! |
14th January 2010, 23:08 | #3024 | Link |
14th January 2010, 23:27 | #3026 | Link |
@neuron2
Windows Seven Ultimate Edition x64 (6.1.0.7600)
15th January 2010, 00:33 | #3028 | Link |
@neuron2
besides changing cli syntax thanks to you only thing i did was upgrade to StaxRip 1.1.4.1 and setup the settings like i posted
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 15th January 2010 at 00:57. |
15th January 2010, 02:31 | #3029 | Link | ||||||||||||
Thanks for the great feedback everybody.
I've prepared a new test built with some fixes and improvements: http://www.stax76.bplaced.net/files/...Rip_1.1.4.2.7z Quote:
Attachments should extract now btw. and it's possible to choose which streams to extract in case somebody want's just extract attachments or audio. Quote:
http://staxrip.wikispaces.com the old wiki was at http://stax76.wikispaces.com so pages have to be copied, it has only one page anyway. Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 15th January 2010 at 03:02. |
15th January 2010, 02:39 | #3030 | Link |
@stax76
thanks for the new build editing profiles bug fixed
15th January 2010, 02:54 | #3031 | Link |
@stax76
i included a patched build with the presets so all that would be needed to be done by the end user is replace bundled x264.exe
15th January 2010, 03:19 | #3032 | Link |
@stax76
MeGUI has a simple checkbox to add --nal-hrd to the commandline i included the switch with the presets but it should'nt be to hard to add the option in StaxRip
15th January 2010, 03:39 | #3033 | Link |
@stax76
could settings and templates be saved by default in the same directory as StaxRip.exe? can run different StaxRip builds with different settings easier also a different format like Settings.ini or Settings.xml so no path to settings in registry please add support for x264_x64 builds you can use this x264x64 Wrapper by alwa to accomplish this feat
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 15th January 2010 at 04:23. |
15th January 2010, 04:38 | #3034 | Link | |
a little info on howto use the wrappers
15th January 2010, 05:52 | #3035 | Link |
@StaxRip Nation
to use x64 builds of x264 in StaxRip follow this very simple workaround 1)download x264x64 Wrapper by alwa 2)rename vfw4x264.exe->x264.exe then place it in x264 folder 3)download x64 build of x264 from your favorite builder 4)rename build to x264_64.exe then place it in x264 folder as in step 2 DONE!
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 16th January 2010 at 15:57. |
15th January 2010, 05:56 | #3036 | Link | |||
I'll have to switch using patched build as it seems it's the only way to target Blu-ray.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 15th January 2010 at 06:00. |
15th January 2010, 06:04 | #3037 | Link |
@stax76
yes it does i posted a simple workaround for users who want to use x64 builds of x264 to you add it in
15th January 2010, 06:13 | #3038 | Link |
15th January 2010, 06:21 | #3039 | Link |
@stax76
switching to patched builds would be great users would have a GUI with the lastest greatest patches to play with if they desire
15th January 2010, 06:30 | #3040 | Link |
@stax76
i really like the lastest AutoVAQ patch New version of VAQ (AutoVAQ) comparsion Code:
--aq-mode <integer> AQ method [1] - 0: Disabled - 1: Variance AQ (complexity mask) - 2: Auto-variance AQ (experimental) - 3: New experimental AQ --aq-strength <float> Reduces blocking and blurring in flat and textured areas. [1.0] (May present in #1:#2 form. Where #2 is frame QP offset. Help with dark frames and fades. 1.0 is optimal)
gui, h.264, h.265, hevc, mkv, x264, x265 |
