2nd November 2009, 12:30 | #10322 | Link |
@Spec-Chum,
Sorry for not being clear, I mean in full screen mode but not D3D mode. I did get screen saver activated when playing .avi, but it did not happens on previous mpc-hc. I did not change any status, so I'm not sure what went wrong too. I will try out the previous version again before I report again. Thanks. Edit: Yes, I have confirm mpc-hc1326 kick-in screen saver in my case while mpc-hc1323 did not during full-screen (not sure about window mode as I did not check). Can any1 double confirm its just me or any1 else is getting it. Thanks. Last edited by boyumeow; 2nd November 2009 at 14:53. |
2nd November 2009, 13:14 | #10323 | Link | |
MPC-HC Project Manager
@Everyone about DXVA and subtitles.
DXVA and subtitles officially only works when you use the internal subtitle renderer in combination with an internal DXVA decoder. We know that for some people different combinations of subtitle renderer and DXVA do work, these combinations are however not officially supported. If anyone has any detailed information, on how to improve the internal subtitle renderer to further improve the DXVA/Subtitle compatibility please provide us with a patch or detailed technical description Quote:
At this time we are only developing EVR-CP and VMR9-renderless, both depend on drawing a DirectX surface directly to the videocard, if the surface can not be created it will give you the errors you have reported. It would be a good idea if someone could fix the cause of the crash in the old renderer (since its basically software based) and then applied a patch that would cause any failure of VMR9-R or EVR-CP to fall back to the old renderer.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 2nd November 2009 at 13:47. |
2nd November 2009, 15:06 | #10324 | Link |
Compiling news:
I have done some research, and it looks like MinGW64 can completely replace MinGW32. It works on 32 and 64 bit hosts and can compile both the 32 and 64 bit build of mpc-hc (and probably the same for ffdshow) It is already used to build a lot of other programs this way. Available here: http://www.cadforte.com/downloads.html it offers a choice between msys and cygwin, not sure which one is best for us? Also, for x64 hosts they offer x64native compiling which should speed up the compiling time considerably.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
2nd November 2009, 15:21 | #10325 | Link | |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
2nd November 2009, 15:25 | #10326 | Link | |
For example, if I select 'Subtitles -> 'Maximum texture resolution' as 'Desktop', it will renderer subtitles in full screen at 1280x800 even though the video is 1280x720, that would be fine, however, sometimes there is positional text (eg signs), which will only render correctly over the video if the subtitle canvas is rendered over 1280x720 pixels (ie exactly over the video), and so it ends up that the sign is positioned either too low or too high compared to if it were being rendered by for example, the DirectVobSub external filter. |
2nd November 2009, 16:15 | #10327 | Link |
the hedgehog
check the option "Position subtitles relative to the video frame" under "Subtitles - Default Style".
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
2nd November 2009, 16:54 | #10328 | Link | |
It's weird because in PowerDVD9, DXVA+Subtitles works, but it has a bug where some subtitle lines don't show up. Very annoying. I'm just asking these questions about DXVA because it's the only way I've found to get a PERFECT deinterlacing (using Ati Avivo). |
2nd November 2009, 17:23 | #10329 | Link | |
MPC-HC displays video track information incorrectly:
2nd November 2009, 18:40 | #10330 | Link | |
If a subtitling filter is connected between video decoder and renderer, DXVA cannot works. This limitation is caused by DXVA design, and cannot be changed. Only internal subtitle engine can works, because in this configuration subtitles are display by renderer (VRM9 renderless or EVR custom) and not by an intermediate filter.
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
2nd November 2009, 19:32 | #10331 | Link | ||
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 2nd November 2009 at 20:10. |
2nd November 2009, 21:02 | #10332 | Link | |
2nd November 2009, 23:20 | #10334 | Link | |
Maybe I should create an XP partition... |
3rd November 2009, 07:54 | #10335 | Link |
I hate when this sort of thing happens... and now it's not only limited to MPC, but other players as well.
Here's the situation: I tested the M2TS from one of CSI: LA (Blu-ray) episodes and MPC-HC is always using this filter to play those files which are using VC-1: How to stop using WMVideo decoder DMO? And worst than that, even if I disable those Windows filters, the M2Ts files will not run. I tried several combinations, and also tried to force the external/internal filters from MPC-HC, ffdshow, Haali, etc. Nothing seems to make those M2TS work (a black screen is what you get), except for adding the WMVideo decoder DMO as a new filter (that's right, we need to add) in the MPC-HC External Filter's section.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." Last edited by Lincoln Burrows; 3rd November 2009 at 08:22. |
3rd November 2009, 09:53 | #10339 | Link |
As far as I know, Haali can't display those subtitles, it's returning all sorts of errors, I don't know why. You need to activate VMR 7 or 9 renderless in the MPC-HC internal settings to display them.
Also, try to force MPC-HC to use ffdshow Video Decoder instead of Haali's, if that tip doesn't help. P.S. Regarding my previous post, this is the first time I am seeing a M2TS file that is requiring me to disable VC1 (ffmpeg) and only use WMVideo decoder DMO. I tested other movies and they played fine, even the ones who used VC-1. Is there something wrong with some of them? This is really strange. And TMT is the only player that is not having any lag while playing this BD project, even when displaying subtitles. I heard somewhere that enabling VMR 7/9 renderless is requiring too much from the video card? Mine is NVidia 8800 GTS 512 MB, plus a Q9450/2GB RAM/XP SP3 system.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." Last edited by Lincoln Burrows; 3rd November 2009 at 09:58. |
3rd November 2009, 10:05 | #10340 | Link | ||
