28th February 2015, 19:15 | #2441 | Link |
No, you can't reorganize categories and like I wrote before I like it the way it is.
-> doubt that I will change Hybrid any time soon + I prefer Tab-widgets instead of menus, which I why I only use them inside the Config-tab. So if you really don't like the layout, I can only recommend to use another GUI. |
28th February 2015, 20:08 | #2442 | Link |
I don't like the layout but i don't know any other gui with all the functionalities i need, Hybrid is the best gui i ever seen ! that's why i try to help.
I prefer Tab-widgets instead of menus too, this is a good idea, the main problem is the organisation, not your fault, but there is so much options ! very hard to organize this Nevermind i'll use css only for now. Selur |
28th February 2015, 21:29 | #2443 | Link | |
28th February 2015, 22:24 | #2444 | Link |
Kamenizer i don't speak about beauty, you can't use the word "pretty" if you understand what i'm trying to say.
I'm talking about scientific disciplines. http://en.wikipedia.org/wiki/Readability http://en.wikipedia.org/wiki/Human_f...and_ergonomics |
3rd March 2015, 01:52 | #2445 | Link |
What I would really like in design/usability of Hybrid is an ability to text-edit the Current output file!
Because for now you can either Generate it or manually click on button to the right and write full name. While in my dreams I can check and then uncheck box "Generate" for auto filling up full video name and then just simply add text like 1, 2, x264, x265 etc when I want to encode one video couples times with different settings. Because for now I have to use something like 0001, 0002, asdjf1 for any 2nd encode or browse for first encoded file in small explorer window, click it and then add text at the end. P.S. Could you tell me again how to trim in Hybrid? I remember that you disabled multiple trimcuts and left just 1 but I can't find where it is. |
3rd March 2015, 06:27 | #2446 | Link | |
Cutting is still 'experimental', since it: a. can't cope with vfr b. doesn't cut subtitles c. probably has some other downfalls. To enable the 'Cut Support' as it is go to: Config->Internals->Cut Support (and remember to read the tool-tips). About encoding one video multiple times: - Don't really like the idea of either making the input or output line edit editable. - I could probably add an option to add a timestamp to the current output as an additional 'Output filename Generation option', or something similar. (or add an option which adds the current 'video handling',....) - Also you can already add texts like 1, 2, x264, x265 when 'Generate' is enabled, by changing the suffix in the 'Config->Output->Filename Generation->Output Filename Generation' options. |
4th March 2015, 12:09 | #2447 | Link |
Expand the list of purses? The most convenient purses for the people of Kazakhstan and Russia:
https://money.yandex.ru/ https://qiwi.com/ |
4th March 2015, 19:20 | #2448 | Link |
qiwi doesn't seem to have an English website, but I'll look into yandex.ru
-> created an account and added a donation link on the main site of my homepage. Last edited by Selur; 4th March 2015 at 20:01. |
13th March 2015, 11:39 | #2451 | Link |
Dear Selur, or anyone else. There is one strange behavior I can't seem to solve. I encoded source mov file using Hybrid into both x265 and x264 and both resulted files looked with different color range. I take source file and set Levels in ffdshow to 16-235 and see exactly what show encoded files.
Furthermore I went to Filtering, Postprocessing, checked autolevels>Full range and got crashed encoding error after sstarting job. What am I doing wrong? Do you need source file and encoded? Both encodings were with a preset settings and I almost didn't change anything else. Also when I look at Avisynth preview it looks like on the encoded files. Is that artificial flag in the mov file? I just want it to be with less color lossy option, no matter what it is. I found a BUG. Lets say you go to Filtering>Avisynth>Line>Resize checkbox. Then you select Lancoz resize with default 4 tap. It is working fine. However if you change tap number to anything f.i. 3 then you will have error with Avisynth Preview because of Avisynth code: LanczosResize(taps=31280,720), where I asume coma (,) is missing between 3 and resolution. Also if you select gauss Resize and change sharpness from default 30 then you will get the same error. EDIT: Ha! I also found that if I add Toon filtering in Avisynth it will bring the exact color range as shows original. So I just added this as custom and that worked. Code:
LoadPlugin("C:\Program Files\Hybrid\avisynthPlugins\aWarpSharp.dll") LoadPlugin("C:\Program Files\Hybrid\avisynthPlugins\Toon-v1.1.dll") # line darkening Toon(Strength=0.00) Last edited by Ajvar; 13th March 2015 at 16:24. |
13th March 2015, 17:44 | #2452 | Link | ||
-> Settings + debug output + a sample to reproduce the problem are needed |
14th March 2015, 09:47 | #2453 | Link |
Sure. Lets do it one by one.
First bug I think I found about modifying default resize options like sharpness for gaussian filter and taps number for Lanczos and other. Here is a video. http://youtu.be/u6-v45zrlys Attached log file of such happening with gaussian filter. Last edited by Ajvar; 14th March 2015 at 10:00. |
14th March 2015, 14:09 | #2454 | Link |
Will look at the video later attaching stuff here in the forum is a bad choice since I can only look at the content once a moderator has approved of the attachment, and by then I probably forgot about it.
-> see the problem will fix for next release. |
16th March 2015, 13:08 | #2456 | Link | |
Original video: http://www.ex.ua/load/155742574 Encoded sample with juicy colors as original (Toon 0.000 aplied) http://www.ex.ua/load/155743319?fs_id=153 Encoded sample with duller colors than original http://www.ex.ua/load/155744220?fs_id=153 LOG FILE http://www.ex.ua/load/155742590?fs_id=153 I noticed that with full PC range video is bigger size with same CRF settings. I also found that on some computers both video files look the same but that should be due to their decoder settings for sure. Ideally I would prefer to keep full PC range even if it will be narrowed to TV while playing on some computers. For comparison of captured frames please go here http://screenshotcomparison.com/comparison/116511 ================================================================================================= And about AutoLevels Bug. Here is a debug log: http://www.ex.ua/load/156110209?fs_id=153 Last edited by Ajvar; 16th March 2015 at 13:23. |
16th March 2015, 21:06 | #2459 | Link |
Cool, so bug exists. But are you on autolevels crash or encoded color range?
P.S. Don't forget to fix typos in x264 CRF explanation: tying = trying quanity = quality and perhaps "who know the want" = "who want" Last edited by Ajvar; 16th March 2015 at 21:48. |
