Old 25th January 2019, 21:04   #1  |  Link
zn
Bitmap subtitles with non-text content,converting PNG+BDN/XML/TTML2 to PGS/VobSub/SUP
Is it possible to use graphical subtitles for non-textual visual information, to display simple graphics (series of png images, that I can turn on and off during playback)?
How I can encode series of png files into graphical subtitles?
zn is offline   Reply With Quote
Old 26th January 2019, 09:43   #2  |  Link
LowDead
Elit Amans
Try easySUP
https://forum.doom9.org/showthread.php?t=149160
//LD
LowDead is offline   Reply With Quote
Old 26th January 2019, 19:36   #3  |  Link
zn
easySUP use text input, but I want to use non-text graphics (png images) for input, like this:
PNG files to BDN (XML+PNG) or TTML2+PNG (or IDX+SUB or PGS or SUP ?)
So, it looks like I need do these steps:
1) make BDN XML file using avs2bdnxml (or manually make XML in text editor)
http://forum.doom9.org/showthread.php?t=146493
2) import PNG+BDN XML to BDSup2Sub
http://forum.doom9.org/showthread.php?t=145277
3) export to VobSub(SUB+IDX) and/or Blu-Ray-SUP (PGS) from BDSup2Sub
4) mux it to mkv using mkvmerge (PGS and VobSub support listed)
https://mkvtoolnix.download/doc/mkvm...erge.subtitles
Old 3rd February 2019, 12:56   #4  |  Link
LowDead
Elit Amans
Well, the only other I know of is SupConverter but I don't know if you must have the Pro version and that costs $199. The LE version is free.
bdn, pgs, sup file, ttml2, vobsub
