Old 9th January 2020, 18:04   #601  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Dolby Vision Viability
Hi Mosu,
I don't know if anybody else has mentioned it but I'm happy to confirm that if you have an .mkv file that contains an HEVC video stream (stream #1) and a Dolby Vision stream (stream #2) that was created using the newest version of your Matroska muxer, if you drag and drop your .mkv file into the new 'open-source' build of TSmuxer GUI the new .m2ts file contains a perfectly viable Dolby Vision stream, which works perfectly.
So what-ever you've done, you've done a great job
Many, many thanks
SeeMoreDigital is online now   Reply With Quote
Old 9th January 2020, 22:54   #602  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Interesting — as I actually haven't really changed anything in the HEVC code for quite a while apart from this one bug fix.
But I'll take it!
Latest MKVToolNix is v83.0
Mosu is offline   Reply With Quote
Old 9th January 2020, 23:32   #603  |  Link
SeeMoreDigital
Yep it's great news...
MKVmerge mux: -
General
Unique ID                                : 42601498193025875308533413168111364906 (0x200CC006DA67D85C7D4829D2B5FB2B2A)
Complete name                            : D:\Re-mux tests [short duration]\Paramount Logo in Dolby Vision [With AC3 only].mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 111 MiB
Duration                                 : 16 s 736 ms
Overall bit rate                         : 55.5 Mb/s
Encoded date                             : UTC 2020-01-09 22:20:19
Writing application                      : mkvmerge v42.0.0 ('Overtime') 64-bit
Writing library                          : libebml v1.3.10 + libmatroska v1.5.2
Video #1
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 16 s 725 ms
Bit rate                                 : 49.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.248
Stream size                              : 98.4 MiB (89%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 143 cd/m2
Maximum Frame-Average Light Level        : 41 cd/m2
Video #2
Format                                   : HEVC
Bit rate                                 : 5 570 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.112
Stream size                              : 11.1 MiB (10%)
Default                                  : No
Forced                                   : No
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 640 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Stream size                              : 1.28 MiB (1%)
Service kind                             : Complete Main
Default                                  : No
Forced                                   : No
TSmuxer GUI Re-mux 'Open Source' version: -
General
Complete name                            : D:\Re-mux tests [short duration]\Paramount Logo in Dolby Vision [TSmuxer re-mux]\AVCHD\BDMV\STREAM\00000.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 116 MiB
Duration                                 : 16 s 714 ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 58.2 Mb/s
Maximum Overall bit rate                 : 35.5 Mb/s
Video #1
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Codec ID                                 : 36
Duration                                 : 16 s 599 ms
Bit depth                                : 10 bits
Video #2
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Codec ID                                 : 36
Bit depth                                : 10 bits
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Bit rate                                 : 640 kb/s
If I have the time next week I'll re-mux a long duration movie (probably 2001: A Space Odyssey) to make sure everything remains in-sync and report back.
Cheers
Old 12th January 2020, 13:12   #604  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I have extracted chapters from an existing mkv file using InviskaMKVExtract. The extracted files work fine (drag and drop) in MKVToolNix GUI v41.0.0, but v42.0.0 doesn't accept them.
I pasted a sample chapter file here: https://pastebin.com/HHw12Z5X
Old 12th January 2020, 13:36   #605  |  Link
filler56789
SuperVirus
filler56789's Avatar
Overdue update...
Originally Posted by Mosu View Post
Originally Posted by Atak_Snajpera
I've just noticed that mkvtoolnix-gui.exe can't be compressed by upx without --force switch. This is first time I had to use that option on executable. I wonder what is so unusual in that executable?
I really have no idea. I've never used upx, I definitely don't purposefully do anything to make upx's life harder.
Very-probably it's QT's fault --- the same problem happens with the GUI of tsMuxeR.
filler56789 is offline   Reply With Quote
Old 12th January 2020, 16:20   #606  |  Link
mkver
Should have already been fixed (issues 2718).
mkver is offline   Reply With Quote
Old 12th January 2020, 21:00   #607  |  Link
73ChargerFan
73ChargerFan's Avatar
I used "split after specific timestamps" for the first time today. It rocks! A movie has 2min 27sec of music with no video at the beginning. I split it into two, and not only was that flawless, but it corrected the chapter marks also! Cool!
73ChargerFan is offline   Reply With Quote
Old 14th January 2020, 21:25   #608  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Well, that's a matter of perspective. As the original EXE is working perfectly fine while a program designed to mess around with a perfectly-fine-working EXE fails to produce another perfectly-fine working EXE, I'd argue that it's the messing-around program (UPX) that's at fault.
Old 26th January 2020, 15:38   #609  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v43.0.0 released
Hey y'all,
let's do a second release in January, fixing a couple of annoyances that crept in lately. Just a smaller maintenance release; nothing earth shattering. But see for yourself down below.
Nothing's changed for package managers.
Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code.
The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours.
Here are the NEWS since the previous release:
Version 43.0.0 "The Quartermaster" 2020-01-26
New features and enhancements
  • MKVToolNix GUI: using one of the command line options "--info", "--edit-headers" or "--edit-chapters" will make the GUI select the corresponding tool on startup even if no further file name is given. Implements #2723.
  • MKVToolNix GUI: multiplexer: added a setting in the preferences for changing the location of the MediaInfo executable for when the user accidentally selected the wrong one.
Bug fixes
  • mkvmerge: AVC/h.264 parser: the order of the NALUs before each key frame was sometimes wrong: mkvmerge wrote SPS & PPS after SEI NALUs. Now SPS & PPS NALUs are always written before the other NALUs. Patch by Torsten Hauska. Part of the implementation of #2709 and part of the fix of #2250.
  • mkvmerge: AVC/h.264 parser: when additional SPS or PPS NALUs (with IDs that haven't been seen so far) are found mid-stream, mkvmerge will prepend all following key frames with all current valid SPS & PPS NALUs (just like when SPS & PPS NALUs are overwritten mid-stream). Part of the fix of #2250.
  • mkvmerge: MPEG TS reader: fixed detection of MPEG-1/2 video tracks consisting of very few frames. Fixes #2732.
  • mkvmerge: Ogg Opus reader: fixed the handling of Ogg Opus streams that contain a just one Ogg page ("mkvmerge" aborted with an exception). Fixes #2722.
  • MKVToolNix GUI: multiplexer: dragging & dropping XML files with chapters or tags to the GUI's window was broken in v42. Instead of adding the file names to the appropriate input boxes the GUI was running mkvmerge for file identification purposes which then failed. Fixes #2718.
Have fun
Old 27th January 2020, 12:41   #610  |  Link
redbtn
redbtn's Avatar
Nice work Mosu! Thank you for release.
redbtn is offline   Reply With Quote
Old 27th January 2020, 12:49   #611  |  Link
chros
chros's Avatar
So, did it work well?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 27th January 2020, 16:42   #612  |  Link
SeeMoreDigital
As a matter of fact.... Yes it did. Perfectly
Old 29th January 2020, 12:54   #613  |  Link
Bozotheclown
UI suggestion
Hello,
Small suggestions:
job_output screenshot
Status line:
- if "Completed OK" - in green color
- if "Failed" - red color
It would help to quick check if job is finished successfully or not.
Also working indicator (on bottom right) even after job has finished is in frozen state. I think it should disappear after job is done.
Bozotheclown is offline   Reply With Quote
Old 29th January 2020, 20:42   #614  |  Link
zeropc
Why was MKVToolNix support for macOS High Sierra and below dropped?
zeropc is offline   Reply With Quote
Old 30th January 2020, 14:19   #615  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
If a job wasn't successful, the "errors" indicator in the status bar would blink red and show a number > 0.
Old 30th January 2020, 14:20   #616  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Because MKVToolNix now uses C++ features that Apple only supports on macOS 10.14 (Mojave) or newer.
Old 31st January 2020, 13:30   #617  |  Link
zeropc
I see. Thanks for the info
Old 5th February 2020, 23:08   #618  |  Link
saracas
I have three questions:
- How does one make the remux (destination file) the exact same name as the original (source file), and also automatically delete source file when finished?
- How can I set the default track flag to YES by default? "Determine automatically" sets it to no even though it's the only sub track with foreign language audio.
- I am using a webui version of MKVToolNix which doesn't support drag and drop, when I add multiple files via Add Sources button it adds them all under the same job. If I drag and drop on Windows, I can add them as seperate jobs. How do I add multiple files as seperate jobs without drag and drop?
Thanks
saracas is offline   Reply With Quote
Old 11th February 2020, 18:39   #619  |  Link
leon
Mosu can you please look into this?
https://www.reddit.com/r/mkvtoolnix/..._bug_with_v43/
leon is offline   Reply With Quote
Old 11th February 2020, 19:46   #620  |  Link
manolito
manolito's Avatar
+1, I have the same thing on 2 machines. Can get a little irritating...
matroska
