8th February 2015, 17:08 | #28181 | Link |
Hi guys, I have the following 2 different scenarios where I need your guidance on where the bottleneck is and what can I do to improve the situation (based on madvr's stats):
scenario 1: decoder queue 1-6/48 upload queue 1-2/24 render queue 1-2/24 present queue 0-1/8 scenario 2: decoder queue 44-48/48 upload queue 21-24/24 render queue 0-2/24 present queue 0-1/8 Thank you! |
8th February 2015, 17:39 | #28182 | Link |
Broadband Junkie
What kind of monitor is this? I think you are mistaking something, unless your monitor is over 20 years old. Modern display and GPUs from at least the past couple decades have supported 8bit color (32bpp) for the Windows desktop.
8th February 2015, 17:48 | #28183 | Link | |
not a lot to say without knowing your hardware/type of file in question. i could just guess. |
8th February 2015, 17:59 | #28184 | Link | |
Since I'm using software decoding, would it be correct to assume (1) cpu not powerful enough (2) gpu not powerful enough? Thank you. |
9th February 2015, 07:54 | #28186 | Link | |
EDIT: I indeed just found out that madVR is available to use in the decoder options of Stereoscopic Player for: - MPEG-2 Video Decoder - MPEG-4 AVC/H.264 Video Decoder - MPEG-4 MVC Video Decoder - VC-1 Video Decoder - But most important maybe: you can select an external ''Video Processor'' in Stereoscopic Player where madVR is listed as compatible. The only thing to find out now is if 1. it really works and 2. the loaded .3dlut file in madVR is part of the 'video processor'. EDIT2: Just downloaded Stereoscopic Player and selected madVR as Video Processor (it IS indeed listed in the list when I select ''show only compatible filters'' in the stereoscopic player) but when playing a movie madVR is not listed in the filters that are beeing used. Madshi, could you chime in on this maybe? Last edited by THX-UltraII; 9th February 2015 at 13:01. |
9th February 2015, 15:41 | #28187 | Link | |
see here
http://forum.doom9.org/showpost.php?...ostcount=27954 Quote:
the current version of madVr doesn't support frame packed 3d anyway. you can try to create a side by side version this may or may not work. there is simple little to no love for 3d. |
9th February 2015, 19:11 | #28188 | Link |
Been using madVR + PotPlayer + SVP on my HTPC and loving it... so a huge thanks for that.
Now for the (noob) question... is there an "updated" guide that goes through all the available options and settings? The few I've read seem to be old (my apologies if I'm wrong)... but case in point, I'm wondering what to choose in chroma upscaling? Nearest Neighbor seems to be the best setting, but all the guides I've come across use Jinc with 3 or 4 taps. I'm wondering if there is a guide that explains the differences between Nearest Neighbor and Jinc. I know quality or "best" is subjective at best... so I'm not going to be asking what are the best settings... but I'd love a guide that explains all the terminology and options so I can have a better understanding of what I'm choosing and why. PS - I've been using Nearest Neighbor for everything. Regarding h/w I'm having an NVIDIA gpu, running on an i7 with 16GB RAM. Usage is mainly as a HTPC, but specifically running PotPlayer + madVR + SVP for the soap opera effect. |
9th February 2015, 20:50 | #28189 | Link |
Nearest Neighbor is the worst scaler, it simply uses the value of the closest pixel without any interpolation. Jinc is a newish high quality method similar to lanczos or spline, if you want to understand how it works I believe it is the EWA Lanczos Sharp method in Image Magic. Nicolas Robidoux has been helpful to madshi on resize methods (from what I can see ) and active in this thread.
I have attempted to write an option guide, a draft is somewhere in my documents folder, but I never finished it. MadVR's options seems stable now so maybe I will try to finish it. |
10th February 2015, 00:24 | #28190 | Link |
Display Switcher 23.976 and 24.000
I have a question concerning the Display Switcher: I have made four custom resolutions by using CRU Utility to play videos with fps of 23.976, 24.000, 25.000 and 29.970. Windows is silly so there is no possibility to distinguish between the 23.976 and 24.000 preset (all of the four presets are doubled corresponding to 47.952, 48.000, 50.000 and 59.940 Hz refresh rate). The both presets in the 24p region (47.952 and 48.000) lead to ONE refresh rate named 48 in Windows when creating these two in CRU Utility. So my workaround was to create a 72.000 Hz preset which replaces the 48.000 setting. So i have refresh rates of 47.952, 50.000, 59.940 and 72.000 Hz. I donīt want to use Smoothmotion and it would be nice if the Displayswitcher could handle these settings because there are videos with framerates of 24.000 and 23.976. If entering all 4 presets in the Displayswitcher (in my case 720p48, 720p50, 720p60, 720p72) the 720p72 setting is ignored. Of course it is, because 720p48 and 720p72 both lead to a framerate of 24 (or 23.976).
What would help me is the implementation of this logic (C style): if (framerate == 23.976fps) display mode = 720p48; if (framerate == 24.000fps) display mode = 720p72; Of course there are more movies with a framerate of 23.976 and it doesnīt hurt me that much to use only the 720p48, 720p50 and 720p60 presets in the display switcher and in the rather rare case of a 24.000fps movie entering the 720p72 setting and removing the 720p48 setting (or disable the display switcher and choose the refresh rate within Windows), but from the perspective of using the PERFECT renderer (yes, madvr is ) this definitely should be possible. Or is there a possible workaround I missed by using profiles? Little offtopic question but is has to do with the problem mentioned: My projector can handle e.g 25Hz, 50Hz and 75Hz. It doesnīt convert to a fixed refresh rate internally, I can hear the color wheel spinning faster the higher the refresh rate is. What would be the "best" setting from a theoretical point of view (not the "choose what looks best to you - view") concerning e.g. motion blur and the rainbow effect (it is a DLP projector)? BTW time to convince madshi to accept donations so he can focus more on madvr, earning the money with this product - no more need to focus on other things - what could be more important like the perfect video renderer Hannes. |
10th February 2015, 01:09 | #28191 | Link |
Just a heads up for those using AMD cards. I'd been getting hard stutters for the past few days, the decoder queue dropped and all the queues down the lane followed, then both a few frame drops and repeats. Banging my head, changing madVR, ReClock and LAV settings, until yesterday I decided to time the interval of the stutters. Turned out to be every 15 minutes to the second. Apparently the current version of raptr (AMD Gaming Evolved) is doing something that causes that stutter every 15 minutes.
I got a 7790 with the latest WHQL 14.12 drivers on Win 8.1 64.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
10th February 2015, 04:03 | #28193 | Link |
@Asmodian - Thanks I'll read up on it and also play around and see what looks best.
Also, wondering if using the GPU (DXVA2) is a good option or not? I have an NVIDIA GPU and have the option of selecting processing to be done by DXVA2 in image upscaling and image downscaling, but the option is greyed out in chroma upscaling so I went with Jinc, 8 taps, activate anti-ringing filter checked. I'm wondering if DXVA2 is a better option or should I test more with Jinc for image upscaling/downscaling? Thanks for answering my noob questions... and I look forward to the guide. |
10th February 2015, 20:59 | #28194 | Link |
DXVA2 is probably similar to lanczos in terms of quality but is done on the GPU's hardware, it is different on AMD, Nvidia, or Intel and maybe even between different GPUs. I prefer Jinc3 (or NNEDI3) with my Titans.
8-Taps is too many! It might be a tiny bit sharper but if you want sharpness Lanczos 4 taps would be a better option. Stick to 3 or 4 taps (if your eyes really tell you more is better of course you can use them but understand (IMO) the maximum quality with fewest artifacts option is Jinc3). Of course this is debatable and NNEDI3 is an entirely different creature. |
11th February 2015, 00:05 | #28195 | Link |
/人 ◕ ‿‿ ◕ 人\
The problem with DXVA-scaling is that it drops precision to 8-bit, which results in banding and/or high size of dithering grain (it forces madVR to dither before scaling). IMO, it's useful only on low-power laptops.
11th February 2015, 19:48 | #28197 | Link |
cosmic entity
did/can someone with madvr please test if there are still artefacts when using NNEDI3 in chroma upscaling..
that is with the new nVIDIA GeForce 347.52 WHQL Driver.. if someone could test it, that would be very nice... greetz BetA Last edited by BetA13; 11th February 2015 at 20:01. |
11th February 2015, 22:53 | #28200 | Link | |
cosmic entity
i meant this one: http://forum.doom9.org/showpost.php?...ostcount=27880 http://forum.doom9.org/showpost.php?...ostcount=27912 http://forum.doom9.org/showpost.php?...ostcount=28155 it was fixed when moving to older driver, wich i use now.. But id like to upgrade and well, maybe someone tried it... Last edited by BetA13; 11th February 2015 at 22:58. |
