Old 15th September 2011, 22:55   #261  |  Link
TheFluff
Excessively jovial fellow
Originally Posted by DarkT View Post
Wait, so if you aren't using 2.6 for MT, what are the benefits then of 2.6 over 2.5.8?
It has a few new colorspaces. That's basically the only reason to use it right now.
Old 15th September 2011, 22:56   #262  |  Link
Groucho2004
Groucho2004's Avatar
Originally Posted by SubJunk View Post
I have found 2.6 to crash less than 2.5.8.
I have seen statements like this about MT Avisynth several times but it still seems bizarre to me.
It's like hearing something like "I have a car that only breaks down once a week instead of every other day."
Old 15th September 2011, 22:57   #263  |  Link
DarkT
I don't get it. What's good about moare colorspaces? You mean that yv12/yuy/rgb/whatever thingies? If you encode to h264, ain't you bounf to yv12 at the end anywya?
DarkT is offline   Reply With Quote
Old 15th September 2011, 22:58   #264  |  Link
TheFluff
2.6 supports YUV 4:4:4 which is like YV12 but without the chroma subsampling. x264 does support encoding that these days, too. Unfortunately, almost nobody actually uses 4:4:4, and the thing people actually do use (high bitdepth YUV, such as 10-bit YV12) is not supported.
Old 15th September 2011, 23:00   #265  |  Link
SubJunk
Official changelog between 2.6 and 2.5.8
SubJunk is offline   Reply With Quote
Old 15th September 2011, 23:00   #266  |  Link
DarkT
What's it good for? Does it take care of the color banding or something? Does it require more bitrate? More encoding time?
Old 15th September 2011, 23:01   #267  |  Link
SubJunk
No, I run encoding every day and it never, ever, ever crashes.
The only exception to that statement was 2011.07.19 caused crashing but that was fixed with 2011.09.13
Old 15th September 2011, 23:02   #268  |  Link
TheFluff
It has full chroma resolution. It does not really solve problems with banding the way high bitdepth does, but it does provide "sharper" colors, I guess. It requires a lot more bitrate, takes a lot longer to encode and has quite bad decoder support still.
Old 15th September 2011, 23:04   #269  |  Link
Groucho2004
Also, the resizers are much faster (at least on more recent CPUs).
Old 15th September 2011, 23:06   #270  |  Link
TheFluff
That's cool, I suppose, but I've never really felt I've been bottlenecked on the speed of a resizer...
Old 15th September 2011, 23:16   #271  |  Link
junh1024
I use MT all the time. I found 2.6 may be faster, but more unstable than 2.58.
With 2.58, I don't need to use setmemorymax. With 2.6, I baisically need to use setmemorymax(768) all the time.
Also, I only enclose the bottlenecks in my script, like fft3d, hqdering, or mdegrain 2 in MT(""" """)
junh1024 is offline   Reply With Quote
Old 15th September 2011, 23:19   #272  |  Link
DarkT
So... you are pro using 2.5.8 mt- in 32bit mode I am guessing? or 64?
Old 15th September 2011, 23:27   #273  |  Link
Groucho2004
and if you have to use so many filters that you run out of memory, the source was probably so bad that it wasn't worth encoding anyway.
Good point.
Old 15th September 2011, 23:29   #274  |  Link
junh1024
I usin 2.6 on Windows 7 Professional 32bit.
Old 15th September 2011, 23:29   #275  |  Link
DarkT
Good point.
I wanted to use 64 bits coz I saw that on set's page, where he links to many filters, like, masktools works 25% faster or something, I figured, that's extra speed gains...
Infact, I'd rather use 32 bits, because there's more filters... Some of my favourite filters, no 64bit version
Old 15th September 2011, 23:32   #276  |  Link
TheFluff
Do I really have to quote myself from the bottom of last page? Let me try one last time:
It is basically meaningless to make any statements about the relative stability of different multithreaded Avisynth variants (this includes the MT() filter).
A script and environment that is rock solid for one user may crash every time for another, due to the inherent nondeterministic behavior of using a non-threadsafe application in multithreaded mode. There are simply way too many variables that can affect how the application behaves in different scenarios to make any reliable predictions about what might crash and what might not.
Old 15th September 2011, 23:35   #277  |  Link
DarkT
If many people get it to work consistantly... or semi consistantly... I'd say that puts your idea of why it sux outta business tbh...
Old 15th September 2011, 23:36   #278  |  Link
SubJunk
TheFluff, we're just talking about our experiences. If it's so upsetting for you to "let" us talk to eachother then just go away, I assure you no one will care either way.
Old 15th September 2011, 23:38   #279  |  Link
TheFluff
But you're not asking many people. You're asking two people, and their findings are different.
Old 15th September 2011, 23:40   #280  |  Link
DarkT
i am asking many people. As many as read this particular page. Out of those who do, and chose to reply, I'd say the percentage is quite high . Nattttttttturally, this ain't no poll - which I think is actualyl quite a good idea... To make a thread where people would contribute their experience with MT... Hmmm...
Edit:
P.s. Greetings to all our friends at DarkHold .
