Old 21st November 2014, 00:20   #1  |  Link
How do you tell how big a file is ?
Concerning Large File Support, How do you tell how big a BIG file is in Visual CPP 6.0 (1998) ?
I know that fpos_t is 8 bytes in size in VS6 without any kind of configuration (at least with 2003 Platform SDK
1st in include paths), and I know that I can use fsetpos and fgetpos both using fpos_t.
But, as I cannot use fseek (4 byte offset) with it's SEEK_SET, SEEK_CUR, SEEK_END, but I do need to seek to the end of file,
how can I find out how big a BIG file is, so I can seek to the end of file (equivalent to SEEK_END) when I dont know
how big the file is.
Can anybody assist here ?
I want to be able to write RT_Stats DBase and Array files bigger than 2GB.
Perhaps fseek SEEK_END actually does work on big files, can anybody clarify.
Old 21st November 2014, 00:28   #2  |  Link
Groucho2004
This also works for files > 4GB:
WIN32_FIND_DATA fd;
unsigned __int64 iSize = 0;
char szFind[MAX_PATH];
//copy file name to szFind
HANDLE hFind = FindFirstFile(szFind, &fd);
if (hFind != INVALID_HANDLE_VALUE)
 iSize = (((unsigned __int64)fd.nFileSizeHigh) << 32) + (unsigned __int64)fd.nFileSizeLow;
FindClose(hFind);
As for seeking, writing and reading large files I suggest you search google. I don't think that the good old fseek can handle it.
Old 21st November 2014, 00:38   #3  |  Link
Thanx Groucho, I'm sure that will come in handy, but,
Is there any way using FILE * (pointer to FILE), is needed to be used in conjunction with read/write using file pointer,
I am under the impression that fwrite() and fread() work OK with big files (just limited to 2GB chunk max at a time).
Old 21st November 2014, 00:55   #4  |  Link
Groucho2004
Have a look at "_lseeki64", "_write" and "_read".
Old 21st November 2014, 01:10   #5  |  Link
mariush
Open the file using CreateFile (windows api function) : http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx (note, there's also CreateFile2 but it's not required for your particular needs)
CreateFile can create files or open existing files, it all depends on the parameters you pass to it. Read documentation at link above.
Use GetFileSizeEx to get the 64 bit file size : http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
Use SetFilePointerEx to position yourself in the file... http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
As the documentation says, you can also use this function to determine where you are in the file [ex setfilepointerex( filehandle, 0, variable_for_current_position, file_current) ] or to determine the file size by saying setfilepointerex(filehandle,0,variable,file_end) but then you'd have to reset the point to read from beginning.
There's also GetFileInformationByHandle function that could be useful... you need to pass a structure to it and it populates that with info based on a file handle you give it. See http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
mariush is offline   Reply With Quote
Old 21st November 2014, 01:14   #6  |  Link
Groucho2004
Most of the APIs you mention like GetFileSizeEx() are not available in VC6.
Old 21st November 2014, 01:24   #7  |  Link
mariush
They're Windows API functions ... just #include <windows.h> and if needed download the windows sdk from microsoft, it's free.
As a suggestion to see how others do it, download Virtualdub's source code and browse the source code. It's not perfect (or modern in some instances) but it's readable and interesting.
Old 21st November 2014, 01:43   #8  |  Link
TheFluff
Excessively jovial fellow
jesus christ upgrade to a compiler from this millennium already, it won't even cost you anything
_fseeki64() and _ftelli64() are what you want but who knows if they're available in your ancient runtime
(looks like they're not, VS2005 or newer I think)
Old 21st November 2014, 02:26   #9  |  Link
I'm not altogether happy about mixing eg file handles and FILE*, but will investigate all things suggested.
Thanx guys, I guess I'll also try dredging VirtualDubMod source (From TwriteAVI plug as I cant find the full source).
Sleep well my friends.
EDIT: Does anybody know, does fseek SEEK_END actually work for big files ?
Old 21st November 2014, 02:42   #10  |  Link
Groucho2004
Good point, the latest platform SDK that is compatible with VS6 does indeed support these functions.
Old 21st November 2014, 03:06   #11  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Are you trying to take the mantle from IanB for supporting the most out-of-date development environment? I can't think of a single good reason to use VC6, when newer ones are free; even IanB finally upgraded after a couple of 2.6 alphas proved how limited it was. VC6 has crash bugs you can drive a truck through.
Old 21st November 2014, 03:28   #12  |  Link
NO, so far as I am concerned, IanB has not (As Yet) been declared dead (I see him sometimes lurking about, like something dead),
but seems to be quite alive. Twould be nice if the big man could speak from the grave (Or wherever) and declare to the world
whether he has or has not abandoned the world that is avisynth.
Foxy, you clearly like to take the easy path in life, some of us like the struggle against adversity, we do it just because it's there.
(EDIT: Some people like to climb moutains, WHY)
EDIT: Final Plugs are compiled with VS TK 2003. (Because generally faster, sometimes faster than VS2005/2008 but sometimes VS6 faster)
@TheFluff, Some things that I used to use more than 20+ years ago on Atari and Amiga machines are not implemented well into the future
(present being 1998) on MS machines, I really cannot understand how the MS PC prevailed when the system is/was so lacking.
Old 21st November 2014, 10:46   #13  |  Link
Groucho2004
Since he uses VC6 mainly for Avisynth plugin development and the latest official Avisynth Alpha is built with VC6, I guess he's following your advice from this post.
Old 21st November 2014, 14:08   #14  |  Link
HeHe, hoisted by his own petard.
I have in the past tried both VS 2005 and VS 2008 and found that I got a performance hit of something like 20% when compared to
VS TK2003, and I think even VS6 was faster (No alterations to standard optimization config in 2008 or VS6, TK3).
Doing time test comparisons between Avisynth Standard AverageLuma and RT_AverageLuma, I was getting something like 4200FPS (STD) and 5000FPS (RT) in
VS6, some of that would be down to the fact that it would locate RT (external plug) quicker in the name lookup table.
On TK3, was something like 7083FPS(RT) on my lowly dual core Core Duo 2.4GHz.
Actual timing for RT_AverageLuma TK3 7083FPS and 4200FPS for STD in VS6.
TK3 seems to quite efficiently compile these type of loop implementations (more efficient in TK3 than VS6, some processors can handle the --x>=0 and
loop in a single instruction eg Motorola M68K family although x would need to be 16 bit int)
    for(x=width; --x>=0;) {
rather than this
    for(x=0; x < width; x++) {
or this (better than prev on some compilers/processors EDIT: No real difference in either VS6 or TK3)
    for(x=0; x < width; ++x) {
On tight loop, can have a significant performance boost simply by using the --x>=0 thing.
I also did time test in Avisynth+, not much difference in speed between A+ and RT for eg YPlaneMin equivalent and other non AverageLuma functions, but,
A+ blew my socks off with 30,000FPS for AverageLuma using 2008 (I think) intrinsics.
Old 21st November 2014, 14:41   #15  |  Link
TurboPascal7
TurboPascal7's Avatar
People like you are the primary reason why we can't have nice things.
Me on GitHub | AviSynth+ - the (dead) future of AviSynth
TurboPascal7 is offline   Reply With Quote
Old 21st November 2014, 16:25   #16  |  Link
TheFluff, I think turbo must be addressing you.
Old 21st November 2014, 16:39   #17  |  Link
TheFluff
Only someone reading my posts like the devil reads the bible could come to that conclusion. Obviously nobody sane would get the idea to use VC6 in 2014. The point of the post was to a) point out that C++ API's are dumb, Jeroi is delusional and that you probably shouldn't be using Avisynth, and b) remind people about the things you have to keep in mind when developing Avisynth plugins (using a modern compiler, natch).
loop in a single instruction)
While it is true that if you translated this verbatim into asm, testing for sign inversion or overflow would save a comparison, that's almost certainly not what happens. Fix your benchmarks, check what asm is actually generated and stop writing code like it's 1985. I also wonder what kind of tight loops you're writing that are significantly impacted by the loop counter.
Old 21st November 2014, 17:18   #18  |  Link
Your other post was only 1 Year + 4 days ago, how things have changed.
Any kind of tight loops are faster, especially with TK3 7083FPS(RT)" for pretty much the same code in standard
avisynth (4200FPS VS6) and the --x>=0 in RT_AverageLuma.
I dont speak i86 so examining it would be pointless. EDIT: 2 of my compilers on M68K compiled the --x>=0 thing to a single instruction.
Nah, I like to write efficient code I'll leave the alternative to you.
Old 21st November 2014, 19:22   #19  |  Link
Here output of timer, I stopped it early as I have to go out
00000006    0.47205281      RT_DebugF: RT_Stats Timing Test
00000007    0.47207168      RT_DebugF: Timing 13x5(65) runs on 100000 Frames (Total Frames=6500000)
00000008    26.10106659     RT_DebugF: RT_YankChain       5.122Secs :19524.66FPS :: Basic GetFrame() [ADJUSTMENT]
00000009    496.45959473    RT_DebugF: YPlaneMin         94.071Secs : 1063.02FPS :: ADJUSTED88.950Secs 1124.23FPS
00000010    868.93853760    RT_DebugF: RT_YPlaneMin      74.495Secs : 1342.37FPS :: ADJUSTED69.373Secs 1441.48FPS
00000011    1339.47485352   RT_DebugF: YPlaneMax         94.110Secs : 1062.59FPS :: ADJUSTED88.988Secs 1123.75FPS
00000012    1711.73962402   RT_DebugF: RT_YPlaneMax      74.452Secs : 1343.15FPS :: ADJUSTED69.330Secs 1442.38FPS
00000013    2197.82421875   RT_DebugF: YPlaneMinMaxDif   97.216Secs : 1028.64FPS :: ADJUSTED92.094Secs 1085.85FPS
00000014    2571.29956055   RT_DebugF: RT_YPlaneMinMaxDif74.694Secs : 1338.79FPS :: ADJUSTED69.573Secs 1437.34FPS
00000015    3036.29052734   RT_DebugF: YPlaneMedian      93.009Secs : 1075.16FPS :: ADJUSTED87.888Secs 1137.82FPS
00000016    3407.98608398   RT_DebugF: RT_YPlaneMedian   74.338Secs : 1345.20FPS :: ADJUSTED69.217Secs 1444.74FPS
00000017    3551.94287109   RT_DebugF: AverageLuma       28.930Secs : 3456.65FPS :: ADJUSTED23.808Secs 4200.26FPS
00000018    3648.14013672   RT_DebugF: RT_AverageLuma    19.239Secs : 5197.90FPS :: ADJUSTED14.117Secs 7083.76FPS
The figures are adjusted by subtracting time taken for basic GetFrame ie removing timing for sourcefilter, script etc and so are timing only
the functions themselves.
Does five timings on each routine and throws away fastest and slowst times then averages remaining 3.
The non AverageLuma functions are slower due to them using a count array rather than single accumulator.
Here the script:
TITLE="RT_Stats Timing Test"
RUNS   = 5          # Number of runs of each function, slowest and fastest discarded, timed on average of remainder
NFRAMES=100000      # Number of Frames to use from Source Clip
#AVISource("D:\avs\TEST.avi")
Colorbars(pixel_type="YV12")
Trim(0,NFRAMES-1).KillAudio()
# Function names for Display only
Names="
    RT_YankChain
    YPlaneMin
    RT_YPlaneMin
    YPlaneMax
    RT_YPlaneMax
    YPlaneMinMaxDif
    RT_YPlaneMinMaxDif
    YPlaneMedian
    RT_YPlaneMedian
    AverageLuma
    RT_AverageLuma
    Avisynth_ALL
    RT_Avisynth_ALL
    RT_ALL
TESTS=13    # Total number of test incl RT_Yankchain # EDIT: Should read 'not including RT_Yankchain'
GSCript("""
    Function Test_00(clip c){c for(i=0,framecount-1){current_frame=i RT_YankChain(Last)} return c}
    Function Test_01(clip c){c for(i=0,framecount-1){current_frame=i YPlaneMin(Last)} return c}
    Function Test_02(clip c){c for(i=0,framecount-1){current_frame=i RT_YPlaneMin(Last)} return c}
    Function Test_03(clip c){c for(i=0,framecount-1){current_frame=i YPlaneMax(Last)} return c}
    Function Test_04(clip c){c for(i=0,framecount-1){current_frame=i RT_YPlaneMax(Last)} return c}
    Function Test_05(clip c){c for(i=0,framecount-1){current_frame=i YPlaneMinMaxDifference(Last)} return c}
    Function Test_06(clip c){c for(i=0,framecount-1){current_frame=i RT_YPlaneMinMaxDifference(Last)} return c}
    Function Test_07(clip c){c for(i=0,framecount-1){current_frame=i YPlaneMedian(Last)} return c}
    Function Test_08(clip c){c for(i=0,framecount-1){current_frame=i RT_YPlaneMedian(Last)} return c}
    Function Test_09(clip c){c for(i=0,framecount-1){current_frame=i AverageLuma(Last)} return c}
    Function Test_10(clip c){c for(i=0,framecount-1){current_frame=i RT_AverageLuma(Last)} return c}
    Function Test_11(clip c){c for(i=0,framecount-1){current_frame=i \
            YPlaneMin(Last) YPlaneMax(Last) YPlaneMinMaxDifference(Last) YPlaneMedian(Last) AverageLuma(Last)} return c}
    Function Test_12(clip c){c for(i=0,framecount-1){current_frame=i RT_YStats(Last,flgs=$1F)} return c}        # As Test_11
    Function Test_13(clip c){c for(i=0,framecount-1){current_frame=i RT_YStats(Last,flgs=$7F,lo=0,hi=255)} return c}
    # As Test_12 + RT_Stdev+RT_YInRange
    Assert(RUNS>=3,"RUNS MUST be at least 3")
    Frames=FrameCount()
    YankAve=0.0                                             # Adjustment, will be subtracted from timings of non YankChain fns
    PStr=RT_String("%s\nTiming %dx%d(%d) runs on %d Frames (Total Frames=%d)",TITLE,TESTS,RUNS,TESTS*RUNS,NFRAMES,TESTS*RUNS*NFRAMES)
    RT_debugF("%s",Pstr)
    TStart=RT_TimerHP()                                     # Total Runtime Start
    For(Test=0,TESTS) {
        EStr="Test_"+RT_NumberString(Test,10,2)+"()"        # Func to EVALuate
        Times=""
        for(Run=1,RUNS) {
            s=RT_TimerHP()  Eval(EStr)  e=RT_TimerHP()  t = e-s     # Time Function
            Times=RT_TxtAddStr(Times,String(t))
#           RT_DebugF("%s %d] S=%6.2f E=%6.2f Time=%6.2f",EStr,Run,s,e,t)
        Times=RT_TxtSort(Times,9)                               # Sort Float strings ascending
        Ave = 0.0                                               #
        for(i=1,RUNS-2) {Ave=Ave+Value(RT_TxtGetLine(Times,i))} # excluding slowest and fastest run
        Ave=Ave / Float(RUNS-2)                                 # Get Average Time, discarding slowest and fastest run
        FPS=Frames / Ave                                        # Ave FPS
        Title = RT_StrReplaceMulti(RT_TxtGetLine(Names,Line=Test+1)," "+Chr(10)+Chr(9),Chr(10)+Chr(10)) # Remove any SPACE + TAB
        Title = RT_StrPad(Title,18)        # Align
        OStr=RT_String("%s%6.3fSecs :%8.2fFPS",Title,ave,FPS)
        if(Test==0) {
            YankAve=Ave                                         # Average of basic GetFrame() ONLY time
            OStr=OStr+" :: Basic GetFrame() [ADJUSTMENT]"
        } else {
            AdjustedTime = Ave-YankAve
            AdjustedFPS = Frames / AdjustedTime
            OStr=RT_String("%s :: ADJUSTED%6.3fSecs %7.2fFPS",OStr,AdjustedTime,AdjustedFPS)
        RT_DebugF("%s",OStr)
        PStr=RT_TxtAddStr(PStr,OStr)
    TEnd=RT_TimerHP()                                               # Total Runtime End
    TTime=RT_String("Total Runtime = %6.2fMins",(TEnd-TStart)/60.0)
    RT_DebugF("%s",TTime)
    PStr=RT_TxtAddStr(PStr,TTime)
#   RT_DebugF("%s",PStr)
    SStr=RT_StrReplace(PStr,Chr(10),"\n")                       # Convert Chr(10) to '\n' for correct Subtitle display
    SubTitle(Sstr,font="Courier New",size=16,lsp=0)
EDIT: The 'Tight Loop' in question from RT_AverageLuma on Planar Y
for(y=0 ; y < hh; y += ystep) {
    for (x=ww ; --x>=0 ; ) {
        sum += srcp[x];
    if(sum & 0x80000000) {acc += sum;sum=0;} // avoid overflow (big frame support, not available in AverageLuma)
    srcp += ystride;
Old 23rd November 2014, 13:20   #20  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Loop unrolling would be dramatically more beneficial than bashing one byte at a time here, so it's no wonder that isn't particularly well optimized for anymore. Hell, accessing the pointers as ulongs (or ulong longs in 64-bit) would be a great improvement, without having to get into intrinsic/ASM/OpenMP territory.
file system, large file support
