Old 16th June 2018, 21:32   #1  |  Link
henryperu77
Convert HEVC 2160p 10 bits HLG to 2160p 8bits with HLG/HDR using ffmpeg
I have this World Cup sample in 4k HEVC 4:2:0 HLG 10bits and i want to convert it to 4k HEVC 8bits HLG/HDR using ffmpeg but maintaining the correct colors
https://transfer.pcloud.com/download...3TCb5VnyMDbagV
I tried this that i found on another site, but the color results are horrible
ffmpeg -i "d:\Descargas\NPO1 UHD.ts"
-c:a copy
-c:v libx265
-tag:v hvc1 -crf 22
-pix_fmt yuv420p10le
-x265-params "colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc" "d:\Descargas\NPO1_UHD_mkv.mkv"
Any help is appreciated...
henryperu77 is offline   Reply With Quote
Old 16th June 2018, 22:04   #2  |  Link
videoh
Useful n00b
Why do you think it is HDR HLG? It doesn't look like it to me. Looks like plain old UHD.
Old 16th June 2018, 22:13   #3  |  Link
henryperu77
Video
Menu ID : 20901 (0x51A5)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
Codec ID : 36
Duration : 53 s 280 ms
Bit rate : 24.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.059
Stream size : 155 MiB (93%)
Encryption : TPS-Crypt or Viaccess
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG / BT.2020 (10-bit)
Matrix coefficients : BT.2020 non-constant
Old 16th June 2018, 22:57   #4  |  Link
videoh
Useful n00b
Assuming that is MediaInfo output, I'll have to look into how it detects HLG (there is no metadata for HLG). It may just be 2020 UHD, as the "HLG / BT.2020" could be ambiguous with the "/" meaning "or" rather than "and". If I decode this as simple UHD, then it looks fine. Investigating...
Old 16th June 2018, 23:11   #5  |  Link
nevcairiel
Thats one of the "features" of HLG, if you ignore it, it still looks mostly fine.
HLG-encoded streams usually have one extra SEI message that tells the player that the stream is HLG, but if you ignore that SEI message then it would just look like ordinary BT.2020 SDR.
For the OP, you should definitely not set the transfer to 2084 since thats not HLG but HDR10/PQ. I don't know if x265 can properly set the double transfer characteristics that HLG uses (ie. BT.2020 in main header, HLG in SEI header).
Old 16th June 2018, 23:27   #6  |  Link
henryperu77
So what do you suggest i can use?
Old 17th June 2018, 01:24   #7  |  Link
videoh
Useful n00b
Interesting! Can you tell me the details on the SEI message, or point to a spec? Thank you.
Old 17th June 2018, 02:15   #8  |  Link
videoh
Useful n00b
Found this:
HEVC HDR UHDTV Bitstreams using HLG10 shall also contain the alternative_transfer_characteristics SEI message. The alternative_transfer_characteristics SEI message shall be inserted on the HEVC DVB_RAP, and preferred_transfer_characteristics shall be set equal to “18”, indicating Recommendation ITU-R BT. 2100 [45] HLG system.
Old 17th June 2018, 02:30   #9  |  Link
MGarret
I don't have a clue about HDR but in x265 docs there is this:
--atc-sei <integer>
Emit the alternative transfer characteristics SEI message where the integer is the preferred transfer characteristics. Required for HLG (Hybrid Log Gamma) signalling. Not signalled by default.
I encoded your sample to elementary stream with the command you posted but added atc-sei=18 and mediainfo reports HLG / BT.2020 for transfer. However I don't know if this is correct output or if it's possible to encode it like this to 8bit.
MGarret is offline   Reply With Quote
Old 17th June 2018, 02:54   #10  |  Link
videoh
Useful n00b
I will add HLG support to DGDecNV and DGHDRtoSDR.
Old 17th June 2018, 03:25   #11  |  Link
henryperu77
Please upload it, to check it out!
thanks
Old 17th June 2018, 03:27   #12  |  Link
henryperu77
I will add HLG support to DGHDRtoSDR.
What is that??
Old 17th June 2018, 11:22   #13  |  Link
MGarret
thanks
Why don't you try it yourself?
https://www.mediafire.com/file/z7y5lqczufsqbxn/NPO_TEST_x265.hevc
It's only few seconds
Old 17th June 2018, 15:15   #14  |  Link
videoh
Useful n00b
What is that??
It's an Avisynth filter for converting HDR10 to SDR. It runs at 100fps+ for 2160p on a recent nVidia card. It also can run in software mode but is very slow that way. Don't look to download it right now as I have it in the shop for changes. Will be available again in a few days. I will also add the HLG SEI detection to DGDecNV.
Old 17th June 2018, 17:29   #15  |  Link
excellentswordfight
Lost my old account :(
-c:a copy
-c:v libx265
-tag:v hvc1 -crf 22
Ideally you wanna use the "alternative_transfer_characteristics" but its not supported by x265, but this mostly to keep fallback compatibility with SDR devices. But the transfer function you are after is arib-std-b67 (its the same transfer as used by HLG so it also uses 18 as value).
With that said, I cant see any reason for the 8bit transcode, that is out of the HLG specc. What should be done is to convert it to SDR, then transcode it.
excellentswordfight is offline   Reply With Quote
Old 17th June 2018, 18:19   #16  |  Link
henryperu77
Ok what i need to convert it to SDR adding the color changes
Old 17th June 2018, 20:09   #17  |  Link
excellentswordfight
What is the target for the encode? Cause first you asked to keep the HDR intact, but I cant I imagine a decoder that can handle HDR but not 10bit.
When I looked at this the last time the options were limited and I ended up doing it with ffmpeg and a LUT with acceptable results (but definitely not great). Cant share the LUT though so cant help you with that unfortunately. Maybe someone else here know of another solution.
I've seen some people doing the convert with just ffmpeg (without a lut), I guess that it would look something like this:
"ffmpeg.exe" -i "input.ts" -vf zscale=tin=arib-std-b67:min=bt2020nc:pin=bt2020:rin=tv:t=arib-std-b67:m=bt2020nc:p=bt2020:r=tv,zscale=t=linear:npl=100,format=gbrpf32le,zscale=p=bt709,tonemap=tonemap=hable:desat=0,zscale=t=bt709:m=bt709:r=tv,format=yuv420p -an -c:v libx265 -preset slow -x265-params level=51:crf=22:keyint=500:min-keyint=50:rc-lookahead=50:bframes=8:no-sao=1:colorprim="bt709":transfer="bt709":colormatrix="bt709":range="limited" "out"
Dont have any HLG samples atm to test with, but I guess that you can start with that, but be prepaird to tweak it.
Old 19th June 2018, 20:58   #18  |  Link
Revan654
Revan654's Avatar
Video
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
The sample you Uploaded is not HLG from what my editing software is reading out. Mediainfo been hit or miss when it comes to HDR content.
I'm a little fuzzy when it comes to HLG, shouldn't the transfer be something other then BT.2020? HDR10 uses ST.2084, I would think HLG uses ARIB STD-B67.
Revan654 is offline   Reply With Quote
Old 19th June 2018, 22:36   #19  |  Link
nevcairiel
HLG uses a separate SEI element to indicate a secondary transfer function, which allows fallback to SDR with non-HLG aware players. So the main transfer function entry would be an SDR one, and the extra SEI element would indicate the HLG transfer. If your analyzer does not understand that separate SEI, then it would show as SDR.
Old 19th June 2018, 22:40   #20  |  Link
videoh
Useful n00b
That stream does contain the SEI message discussed. Next slipstream of DGDecNV will show it in the DGI file.
10bits, 2160p, hevc
