30th March 2010, 08:58 | #11221 | Link |
Hi there,
I too are having some trouble with MediaControl and ffdshow DXVA. In short, with DXVA enabled I can't switch audio streams or subtitles by using MediaControl. MediaControl detects and displays all streams and subs, but nothing happens when i click them. I can still right-click the ffdshow tray icon and switch. This only happens when I use DXVA. With "regular" ffdshow MediaControl works as intended. running x64 and MPC-HC splitter (haali gives me DTS-HD bitstreaming issues), MediaControl 6.0.4 x64 and the latest x64 ffdshow from xvidvideo.ru (build 3336). Any ideas...? |
30th March 2010, 11:35 | #11222 | Link |
ffdshow_rev3337_20100329_sse_icl11 from xvidvideo.ru flickers while decoding AVC. It looks like the deblocking at edges does not work correctly and differently for most frames. Happens with both libavcodec and ffmpeg-mt decoder.
ffdshow_rev3304_20100304_sse_icl11 does not show this effect. Look at the following images (they are carefully web-optimized JPEGs, compression doesn't harm the effect too much), especially compare the borders around the cyan color bar, the near-bottom left blue field and the bottom-center dark blue field. http://www.ligh.de/pics/ffdshow/50p_Frame0000.jpg http://www.ligh.de/pics/ffdshow/50p_Frame0001.jpg http://www.ligh.de/pics/ffdshow/50p_Frame0012.jpg http://www.ligh.de/pics/ffdshow/50p_Frame0025.jpg http://www.ligh.de/pics/ffdshow/50p_Frame0026.jpg The MP4 file contains all relevant details about the x264 encoding. http://www.ligh.de/pics/ffdshow/50p.mp4 (160 KB). |
30th March 2010, 12:27 | #11223 | Link | |
30th March 2010, 13:11 | #11224 | Link |
Oh crap...i'm so stupuid i shouldn't be allowed to live. Well, thanks a lot, mate :-)
Ah, just one question...is there a way to set prefered stream/sub languages either in MediaControl or the MPC-HC splitter - like you can in Haali? |
30th March 2010, 18:49 | #11225 | Link |
Media Control author
Yes, I have to fix this
@Ikarad : here is a test build with better management of bluray subtitltes Thanks to supread author I was able to do a better implementation. Issue #3 may not be fixed yet (I haven't tested it) http://damienbt.free.fr/ffdshow_rev3...libs_beta9.exe |
30th March 2010, 20:11 | #11226 | Link | |
When it works subs are not displayed. In the first 35 secondes the only sub displayed is "abandon ship" at 29 second. I can't test if the problem that I speak before are corrected Quote:
30th March 2010, 21:10 | #11227 | Link |
Interference with programs that do not work with ffdshow
ffdshow is coupled with other applications except PowerDVD, then
launching PowerDVD because I see this message? THANKS
my PC with Ryzen 7950X |
30th March 2010, 22:20 | #11228 | Link |
I shall add powerdvd10.exe to the default blacklist.
Choose "Don't use ffdshow (always)".
MPC-HC 2.2.1 |
30th March 2010, 23:10 | #11229 | Link |
4:2:0 hater
Sure: http://www.mediafire.com/?jmyyddtm0mi (153MB)
It'll start with the AC3 track if you use Haali. With r3334 and previous you can change to the THD track and hear it perfectly fine, but if you change back to AC3 you will get silence. After r3334 if you change to the THD track you'll get silence, but if you change back to the AC3 track you'll hear it. Tested with r3338. |
31st March 2010, 08:01 | #11231 | Link | |
I activated the list does not use
31st March 2010, 11:51 | #11232 | Link |
@Ikarad
@Stargazer I have finally fixed this blackscreen problem with new ffmpeg libraries. The CPU optimizations weren't correctly taken into account and could cause weird issues (such as this one) This build fixes it and fixes also the stability problems with bluray subs |
31st March 2010, 13:06 | #11233 | Link | |
31st March 2010, 14:21 | #11235 | Link |
@LigH
I don't see those artifacts with the generic build. Could you test that?
MPC-HC 2.2.1 |
31st March 2010, 14:47 | #11236 | Link | |
The file is corrupt on my side ? i have down twice. And you ? Thx Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
31st March 2010, 15:01 | #11237 | Link | |
31st March 2010, 15:57 | #11238 | Link | |
But I have the same bug with 3336: many subs are not displayed. For example in the first 35 secondes the only sub displayed is "abandon ship" at 29 second. With 3326 there wasn't this problem. |
31st March 2010, 18:15 | #11239 | Link |
I think it is time to get rid of some useless algos under Deinterlace section
Screenshots -> http://www.mediafire.com/file/zhm3it...ed_pictures.7z You will see that most of them provide poor quality. The best in my opinion is TomsMoComp + Vertical . However it does not deinterlace to full frame rate. Second would be Yadif.
31st March 2010, 18:16 | #11240 | Link | |
I know that rev 3326 displayed the first subs but it did not respect the PGS format In the new revision I have to wait for the next subtitle to know if the current one is really finished to parse which explains why you can't see it during the first seconds of the video. But after the first subs it should be fine Also note that the MPC splitter is buggy and does not detect the PGS streams early enough. But once the stream is detected and you have selected it, you can go back to the beginning of the video and the first subs should be displayed Maybe this new behaviour could be improved but I would like to confirm first that the implementation is correct (YUY2 colorspace apart) I'll take a look on it tomorrow. Don't hesitate to remind me it if I forget Last edited by albain; 31st March 2010 at 18:19. |
