15th June 2012, 07:12 | #182 | Link |
You could just use software mixing, blend the menu in software onto the image. That shouldn't take all that much performance.
As an alternative, madVR already supports custom OSD overlays, would just have to write an adapter to send the menu data to its OSD interface instead of on separate pins.
19th June 2012, 00:56 | #184 | Link |
Thanks to the devs for all the work on this, but can someone educate me on if this is to the point where it can be added as a filter in MPC-HC then used to open Blu-Ray discs and have fully functional menus?
Or is the only option still to use something like PowerDVD or WinDVD?
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
19th June 2012, 20:44 | #185 | Link | |
It needs to be paired with a decoder that'll handle mpeg2/4/ and VC1. So the internal mpc-hc decoder should do the trick. For renderer support it'll work out the box with EVR, but to get the custom presenter to work will require a few small changes. Ie to make it thread safe for direct 3d. And maybe check a few states. The interface closely resembles that of the DVD navigator. It might change somewhat in the future. But for basic functionality all you need to do is pass key presses to it. The rest could be ignored. |
21st June 2012, 03:00 | #186 | Link |
Hey guys. Thank you all for working on this.
I'm having a problem. I downloaded the latest build and followed the readme.txt instructions. The menus and movies in the demo_plyer play but are very choppy. I don't have this kind of problem when I read a blu-ray with any commercial player or even mpc-hc. |
22nd June 2012, 10:43 | #189 | Link | |
Also try this http://www63.zippyshare.com/v/27242529/file.html Are they choppy using the same decoder in MPC too ?
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 22nd June 2012 at 10:45. |
22nd June 2012, 11:25 | #190 | Link | |
My OS is Win 7 x64, running a Geforce GTX 570 with drivers 301.42 The latest directX runtime is installed. So far I've tried the BDs of Kingdom of Heaven DC and The Last Samurai. Like I said above no. Playback in MPC-HC is smooth, no matter what decoder I use. In fact I would be using it if it could play blu-ray menus. I downloaded the file you linked me and replaced the original with it but it had no effect. Last edited by Wile-E-Coyote; 22nd June 2012 at 11:30. |
22nd June 2012, 16:50 | #194 | Link | |
EDIT AFAIK both BDs are VC-1 no ? Try changing the decoder for VC-1 in ffd or try to use LAV But VC-1 it's still not quite finish
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 23rd June 2012 at 16:06. |
16th July 2012, 18:09 | #195 | Link |
This looks very promising ! I tested the 120 Build.
Would it be possible to use dslibbluray in the near future with WMP12 ? I guess there is still the need of an DS Source Filter, and that one is not available today. Who would be able to write this filter ? And how much work would this be for someone that now this stuff ? |
13th August 2012, 23:20 | #198 | Link |
No (ATI card).
But thanks to your confirmation that it worked for you I played around with the settings some more and was able to get it to display properly if I set YUY2 as the only enabled output format in the LAV decoder settings. Edit: NV12 was the offending format. With that disabled, it plays perfectly. Absolutely awesome job on this guys! Last edited by whurlston; 13th August 2012 at 23:24. |
14th August 2012, 11:58 | #200 | Link |
Looks like a problem with the pitch negotiation, which i suppose would be the mixers job.
This is why i don't think this approach is the right one, implementing a custom mixer just to blend the menu graphics onto the video is way too complicated and limiting design. I should really find the time to go about this with a more flexible approach and a clean design. Considering this project is rather dead itself, guess i don't have to work too fast.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 14th August 2012 at 12:19. |
