27th January 2009, 21:35 | #582 | Link | |
27th January 2009, 21:48 | #583 | Link |
Programmer (or just 教务长)
I did this already.
Nero Showtime will show Language IDs properly, but Playstation will show just "Other". It shows "English" only with the "eng" tagged subtitles in MKV. I tried with French (fre), English (eng), Bulgarian (bul) and only English ones are shown as such. Playlist files and mts files seems ok, but it doesn't show. I'll do some tests later. p.s. No need to go thru multiAVCHD. Try tsMuxer and you will see non 'eng'-tagged subs will show as "Other". Today I was playing with some m2ts files with 10 subtitles and they showed language IDs. I think subtitles need to be PGS, not UTF8 (srt). Let me test some more. Last edited by deank; 27th January 2009 at 21:58. |
27th January 2009, 23:33 | #586 | Link | |
Now I can stop sending you requests on your personal mail box. I'm the French guy who's tried so many times burning multiBR with custom menus and it is true that I'm looking forward to seing feature completed since I tried to create backgrounds equal to the occasion. As you asked me compilation without using the custom menu option still works great. Good luck and don't die before you get the work done. |
27th January 2009, 23:48 | #587 | Link | |
Dude you're the fucking man! I was trying to catch up on season 3 of Dexter and out of the first four eps, three of these I get an error in tsMuxer ("Some tracks not recognized, ...") and multiAVCHD just skips over them. At the very best I got video and no sound. That works like a charm At first I thought the process was just a big headache, but it's just a bit tedious. Perfect timing posting that, thanks. Great info for this thread. Ultimately I would like to fix the original mkv, but I guess that's for another time and another thread. |
28th January 2009, 00:33 | #588 | Link | |
Peas. |
28th January 2009, 10:32 | #589 | Link | ||
Build 270: * Added movie-name.LID.srt detection. * Information in media tab (item count / size) * Progress information on output size. |
28th January 2009, 11:56 | #590 | Link |
Is that bug?
Hi Dean,
sorry if bothering you again, but for the last few builds, last tested 271, multiAVCHD ignores files (CLPI, M2TS and MPLS transfer after tsMuxering), which used to be acceptable and processed fine. Please find attached log file. IMHO it would be very nice if already Media folder could reject (with explanaition) not usable NC files. |
28th January 2009, 12:01 | #592 | Link |
Sure,
[10:57:13] Your multiAVCHD.exe was just updated! [10:58:07] Log started for multiAVCHD v2.0 (build 271) [10:58:07] Processing 3 input files/folders . [10:58:07] Converting mkv file to AVCHD (f:\video\bd5\tdk720ppart-001.mkv). [10:58:07] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x720 23.976fps (AR:1.78) [10:58:07] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: eng [10:58:07] Detected subtitles: ID#3:S_TEXT/UTF8 Language: slv [10:58:07] Generating meta file for tsMuxer... [10:58:07] M2TS stream split set at 3999MiB... [10:58:08] Searching for original chapters (mediainfo)... [10:58:08] None found. Inserting 5 min chapters... [10:58:08] Detected frame reference count: 3 (max:9). [10:58:08] Compliant with L4.1 for 1280x720p. [10:58:08] Creating BluRay folders (tsMuxer)... [10:58:18] Done! [10:58:18] CLPI transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-1058082007\BDMV\CLIPINF\00001.clpi -> F:\Video\BD5\AVCHD_TDK\BDMV\CLIPINF\00000.clpi [10:58:18] M2TS transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-1058082007\BDMV\STREAM\00001.m2ts -> F:\Video\BD5\AVCHD_TDK\BDMV\STREAM\00000.m2ts [10:58:29] MPLS transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-1058082007\BDMV\PLAYLIST\00000.mpls -> F:\Video\BD5\AVCHD_TDK\BDMV\PLAYLIST\00000.mpls [10:58:29] Old pointer to 00001.m2ts in 00000.mpls now set to -> 0 [10:58:29] Converting mkv file to AVCHD (f:\video\bd5\nst.mkv). [10:58:29] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x544 23.976fps (AR:2.35) [10:58:29] Video height not AVCHD compliant (480/576/720/1080)! Final output may be distorted. [10:58:29] Fixing clip and playlist info. [10:58:29] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: rus [10:58:29] Detected audio: ID#3:A_AC3:audio (48000Hz/6ch) Language: eng [10:58:29] Generating meta file for tsMuxer... [10:58:29] M2TS stream split set at 3999MiB... [10:58:30] Searching for original chapters (mediainfo)... [10:58:30] None found. Inserting 5 min chapters... [10:58:30] Detected frame reference count: 5 (max:12). [10:58:30] Compliant with L4.1 for 1280x544p. [10:58:30] Creating BluRay folders (tsMuxer)... [10:59:58] Done! [10:59:58] Applying new vertical resolution ID to video (720p). [10:59:58] Converting mkv file to AVCHD (f:\video\bd5\ttr.mkv). [10:59:58] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x528 23.976fps (AR:2.42) [10:59:58] Video height not AVCHD compliant (480/576/720/1080)! Final output may be distorted. [10:59:58] Fixing clip and playlist info. [10:59:58] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: und [10:59:58] Generating meta file for tsMuxer... [10:59:58] M2TS stream split set at 3999MiB... [10:59:59] Searching for original chapters (mediainfo)... [10:59:59] None found. Inserting 5 min chapters... [10:59:59] Detected frame reference count: 5 (max:12). [10:59:59] Compliant with L4.1 for 1280x528p. [10:59:59] Creating BluRay folders (tsMuxer)... [11:00:53] Done! [11:00:53] Applying new vertical resolution ID to video (720p). [11:00:53] Preparing authoring information... [11:00:53] Copying 1 sec blank video data. [11:00:53] Creating static/lite top PAL menu. [11:00:53] Authoring custom titles menu (PAL). [11:00:53] Encoding menu page #1 (x264). [11:01:32] Encoding menu page #2 (x264). [11:01:43] Muxing h264 stream for menu page #1 (tsMuxer). [11:01:44] Muxing h264 stream for menu page #2 (tsMuxer). [11:01:45] Populating menu structure... [11:01:45] Authoring custom menu completed. [11:01:45] Authoring custom welcome screen (PAL). [11:01:45] Encoding welcome screen (x264). [11:02:33] Muxing h264 stream for welcome screen (tsMuxer). [11:02:34] Populating welcome screen structure... [11:02:35] Authoring custom welcome screen completed. [11:02:35] Setting menu for 1 titles... [11:02:35] New offset for m2ts#1 -> 0 [11:02:35] New offset for mpls#1 -> 00000 [11:02:35] Setting titles #2 to #40 to point at top menu. [11:02:35] Setting custom titles menu... [11:02:35] Processing clip (CPI/CLPI) files... [11:02:35] Completed. [11:02:35] Done! [11:02:35] F:\Video\BD5\AVCHD_TDK folder created! [11:02:35] Burn its CONTENTS to DVD-UDF 2.50... |
28th January 2009, 12:53 | #593 | Link |
I think I found what could be wrong.
The problem could manifest itself if a slower computer is used to run multiAVCHD.exe Can you update to build 274 and try again with these two files? Last edited by deank; 28th January 2009 at 13:12. |
28th January 2009, 13:41 | #594 | Link |
Hi Dean,
thank you for pointing me in the right direction. I think, the problem was in badly split test sample. tsMuxer finished with the error unnoticed by multiAVCHD log: "Matroska parser: read error at pos 665553987". Nevertheless tsMuxer produced the m2ts file but not the clpi and mpls. Would be possible to catch tsMuxer`s error messages and quote them in your log? tsMuxer meta file for problematic file: MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "F:\Video\BD5\NSt.mkv", insertSEI, contSPS, track=1, lang=und A_AC3, "F:\Video\BD5\NSt.mkv", track=2, lang=rus A_AC3, "F:\Video\BD5\NSt.mkv", track=3, lang=eng |
28th January 2009, 14:18 | #600 | Link |
Only warnings was the same ones as before regarding AVCHD compliancy.
In temp folder are only present clpi/mpts of the first unproblematic file (tdk). latest log: [13:51:28] Your multiAVCHD.exe was just updated! [13:52:36] Log started for multiAVCHD v2.0 (build 274) [13:52:36] Processing 3 input files/folders . [13:52:36] Converting mkv file to AVCHD (f:\video\bd5\tdk720ppart-001.mkv) ..... [13:52:52] Done! [13:52:52] CLPI transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-135237-2349\BDMV\CLIPINF\00001.clpi -> F:\Video\BD5\AVCHD\BDMV\CLIPINF\00000.clpi [13:52:52] M2TS transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-135237-2349\BDMV\STREAM\00001.m2ts -> F:\Video\BD5\AVCHD\BDMV\STREAM\00000.m2ts [13:53:03] MPLS transfer: F:\Programs\multiAVCHD_1.5_PAL_LITE\_TEMP\20090128-135237-2349\BDMV\PLAYLIST\00000.mpls -> F:\Video\BD5\AVCHD\BDMV\PLAYLIST\00000.mpls [13:53:03] Old pointer to 00001.m2ts in 00000.mpls now set to -> 0 [13:53:03] Converting mkv file to AVCHD (f:\video\bd5\nst.mkv). [13:53:04] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x544 23.976fps (AR:2.35) [13:53:04] Video height not AVCHD compliant (480/576/720/1080)! Final output may be distorted. [13:53:04] Fixing clip and playlist info. [13:53:04] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: rus [13:53:04] Detected audio: ID#3:A_AC3:audio (48000Hz/6ch) Language: eng [13:53:04] Generating meta file for tsMuxer... [13:53:04] M2TS stream split set at 3999MiB... [13:53:05] Searching for original chapters (mediainfo)... [13:53:05] None found. Inserting 5 min chapters... [13:53:05] Detected frame reference count: 5 (max:12). [13:53:05] Compliant with L4.1 for 1280x544p. [13:53:05] Creating BluRay folders (tsMuxer)... [13:54:34] Done! [13:54:34] Applying new vertical resolution ID to video (720p). [13:54:34] Converting mkv file to AVCHD (f:\video\bd5\ttr.mkv). ..... |
