Old 12th October 2008, 01:13   #21  |  Link
Greif
like what you see with the stream grid. but you would see the feature's main details. you would be able to click on the feature and its streams would be presented in a hierarchical grid format.
Feature 1
... Stream 1
... Stream 2
Feature 2
this would replace the feature dropdown, stream button and stream grid. As you expand the feature rows, its streams would be retrieved.
Greif is offline   Reply With Quote
Old 12th October 2008, 01:18   #22  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Greif, that sounds excellent.
I suggest that next to the playlist number you place some simple details like the AR and running time to help clarify what is where. There are some disks that have many playlists that are all about the same length and it can be pretty confusing trying to deal with them.
saint-francis is offline   Reply With Quote
Old 12th October 2008, 01:25   #23  |  Link
Greif
In the meantime you can click 'details' beside the feature button to view some of that information.
Old 12th October 2008, 15:49   #24  |  Link
saint-francis
too much lurking
Right. There seems to be a little bug with that feature:
It listed it all twice. This doesn't happen with every playlist.
Old 12th October 2008, 16:29   #25  |  Link
Greif
I'll need to track that down.
I also need to parse out the m2ts file(s) for each playlist.
Old 12th October 2008, 23:30   #26  |  Link
Greif
BTW, progress bars are not showing properly. this will be fixed in the next release. coming soon...
Old 13th October 2008, 19:12   #27  |  Link
Greif
Updated:
- ADD: Feature DataGridView
- BUG: Progress bar values not showing proper
- ADD: eac3to link to http://forum.doom9.org/showthread.php?t=125966
The file(s) dropdown in the features grid may not be working 100% so let me know if you run into any issues.
Old 13th October 2008, 19:38   #28  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I am still geting error now on Blu-Ray too
This happend when i press feature button, and progress goes to 100%
shon3i is offline   Reply With Quote
Old 13th October 2008, 21:07   #29  |  Link
Greif
Is there anything in the detail of the error to shed some light on the problem?
Can you run the command using eac3to and show me the output? (Just get a feature listing of your movie)
I need to verify the output that is getting parsed correctly from the StdOutput.
Old 13th October 2008, 21:17   #30  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
i usually extract with eac3to 0000.m2ts (or feature1.evo+feature2.evo) output.mkv and everything work fine.
here is when i use same cmd from HDDVD/Blu-Ray extractor
C:\Documents and Settings\Nenad>"C:\eac3to\eac3to.exe" "F:\HD\The.Transporter.Blu-Ray.1080p.MPEG2.DTS-HD\89279477_TRAN
SPORTER" 1) -progressnumbers
analyze: 1%
analyze: 2%
analyze: 3%
analyze: 97%
analyze: 98%
analyze: 99%
analyze: 100%
M2TS, 1 video track, 4 audio tracks, 4 subtitle tracks, 1:32:09
1: Chapters, 33 chapters
2: MPEG2, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
4: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
5: AC3, Spanish, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
6: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB
7: Subtitle (PGS), English
8: Subtitle (PGS), Spanish
9: Subtitle (PGS), Spanish
10: Subtitle (PGS), French
Old 13th October 2008, 21:24   #31  |  Link
Greif
Can you run the following and show me the results?
"C:\eac3to\eac3to.exe" "F:\HD\The.Transporter.Blu-Ray.1080p.MPEG2.DTS-HD\89279477_TRANSPORTER"
Old 13th October 2008, 21:31   #32  |  Link
saint-francis
too much lurking
Just a suggestion:
Right now as this tool is stand alone from MeGUI it makes sense that there is a progress bar on it. But once it's integrated into MeGUI are you planning on using the normal MeGUI progress indicator window?
P.S. It's crashing for me too now, and at no precisely reproducible place..
Old 13th October 2008, 21:36   #33  |  Link
Greif
In MeGUI, the progress bars will still be used for when the features/streams are collected, but the "heavy duty" processing will be done using the job queue.
Ok, it seems I may have introduce a few bugs... I will try to track them down.
Old 13th October 2008, 22:50   #34  |  Link
spida_singh
I receive the above error when it has finished analyzing at 100%. I selected my BD folder, clicked features, works it's way up to 100%, then stops.
spida_singh is offline   Reply With Quote
Old 13th October 2008, 23:50   #35  |  Link
Greif
Ok, I need to do some regression testing... Give me a day or so to get an update out.
Old 14th October 2008, 09:12   #36  |  Link
hubblec4
Matroska find' ich toll
yes i have the same problem. and then crash the prog.
hubble
hubblec4 is offline   Reply With Quote
Old 14th October 2008, 11:03   #37  |  Link
idbirch2
Just tried this on The Hulk BluRay and its working great, just a couple of cosmetic issues:
1) I can't resize the window. I get the double-ended cursor but can't resize.
2) The progress bar doesn't work for me and instead I get
"Unknown line: "progress: 28%"
"Unknown line: "progress: 29%"
"Unknown line: "progress: 30%"
etc. Great work so far though, thanks very much.
Edit: Also, I've noticed that HDBrStreamExtractor.exe uses a lot of CPU time for a GUI, its currently using between 30 and 40% of a Core2Duo 2.4GHz, seems too high.
idbirch2 is offline   Reply With Quote
Old 14th October 2008, 12:29   #38  |  Link
Greif
1) the window is not meant to resize
2) that will be fixed in the next release
Do you see the same CPU usage when using eac3to on its own?
Old 14th October 2008, 13:52   #39  |  Link
idbirch2
Regarding CPU usage, eac3to uses the same amount of CPU whether I run it manually or through HDBrStreamExtractor. I was trying to say that the HDBrStreamExtractor executable is using a lot of CPU. Is the monitoring of your StdOutput possibly a little too intense? How often is it polling the command prompt window?
Old 14th October 2008, 15:58   #40  |  Link
Greif
Everything is done asynchronously. What that means is that every time eac3to writes to StdOutput/StdError the associated event is fired. There is no polling of the process.
If HDBrStreamExtractor is using a lot of CPU while on standby, then that is something that needs to be addressed. It could be possibly due to the .NET garbage collector cleaning up resources?
eac3to, hdbrstreamextractor
