1st April 2023, 18:35 | #321 | Link |
BlockDetect: determines blockiness of frames.
https://github.com/Asd-g/AviSynthPlus-BlockDetect |
13th May 2023, 08:43 | #322 | Link |
DecodeYV12toRGB (only interleaved RGB32 currently, planar RGBP8 possible) - https://github.com/DTL2020/ConvertYV12toRGB
Some faster and simple quality (point-resize UV) colour-space convert filter, mostly for UHD frame size and draft/preview quality (for monitoring ?). AVX2 minimum CPU required. Should work close to ConvertToRGB32(chromaresample=point) in quality. Last edited by DTL; 15th May 2023 at 09:03. |
19th May 2023, 01:47 | #323 | Link |
BlurDetect: Determines blurriness of frames by adding the relevant frame property.
https://github.com/Asd-g/AviSynthPlus-BlurDetect |
8th June 2023, 21:24 | #324 | Link |
CacheTest(), https://forum.doom9.org/showthread.php?t=184920
Debug Filter. Writes Messages to DebugView window. Requires DebugView. Writes repeat frame requests and Out Of Sync frame requests [requested not previous requested frame + 1] to Debugview. Some results for manually jumping about a bit Code:
00001691 0.22455139 [10788] CacheTest_0001: 0] *** Initialized to frame 0 {RepeatCnt=0, oSyncCnt=0} 00001692 1.09279370 [10788] CacheTest_0001: 0] *** REPEAT REQUEST (ReSeek to 0, Player starts to play ???), {RepeatCnt=0, oSyncCnt=0} 00001693 4.92930794 [10788] CacheTest_0001: 89] *** OUT OF SYNC REQUEST, Previous=122 {RepeatCnt=0, oSyncCnt=1} 00001694 4.93385696 [10788] CacheTest_0001: 2582] *** OUT OF SYNC REQUEST, Previous=89 {RepeatCnt=0, oSyncCnt=2} 00001695 10.90573597 [10788] CacheTest_0001: 2722] *** OUT OF SYNC REQUEST, Previous=2755 {RepeatCnt=0, oSyncCnt=3} 00001696 13.87600136 [10788] CacheTest_0001: 14400] *** OUT OF SYNC REQUEST, Previous=2722 {RepeatCnt=0, oSyncCnt=4} 00001697 16.37423706 [10788] CacheTest_0001: 0] *** Rewind to frame 0, Previous=14400, Counts RESET {RepeatCnt=0, oSyncCnt=0} 00001698 46.82066727 [10788] CacheTest_0001: 674] *** OUT OF SYNC REQUEST, Previous=707 {RepeatCnt=0, oSyncCnt=1} 00001699 47.55070114 [10788] CacheTest_0001: 708] *** OUT OF SYNC REQUEST, Previous=705 {RepeatCnt=0, oSyncCnt=2}
20th October 2023, 19:57 | #326 | Link |
DualSynth-madVR - VapourSynth/AviSynth madVR wrapper
https://github.com/Irrational-Encodi...ualSynth-madVR PolyphaseResize - AviSynth filter for scaling pixel-perfect sources (no binary, just source) https://github.com/djrideout/PolyphaseResize |
21st October 2023, 13:26 | #328 | Link |
This is builds of PolyphaseResize with VS2019 - https://drive.google.com/file/d/1aMC...ew?usp=sharing . Looks like a not finished version - it uses not clear conversion from float to int and at main processing looks like unbiased conversion from float to byte (compiler warnings). So may have more quantization noise left. It works without crashing (x64 tried) but looks close to PointResize ?
21st October 2023, 13:46 | #329 | Link |
Thanks DTL. I'm not sure what it is supposed to look like but in the source it says it uses the coefficients from here: https://github.com/MiSTer-devel/Filt...%20(Sharp).txt
13th November 2023, 01:25 | #330 | Link | |
5th February 2024, 21:24 | #331 | Link |
intellibravs - Intelligent Brightness plugin for AviSynth+
https://github.com/thedeemon/intellibravs |
9th February 2024, 12:26 | #334 | Link | |
11th February 2024, 06:59 | #337 | Link |
Since first development build. It was designed as simple and fast solution as working tech demo of moving pictures data processing at the era of AVX2 and later SIMD capable CPU chips in 202x years. The first end-users AVX2 chips is something about beginning of 201x years (Haswell in 2013 ?).
11th February 2024, 10:51 | #338 | Link | |
Acid fr0g
Wait me! I am waiting for Arrow Lake or Zen 5!
@turment on Telegram |
