15th June 2020, 14:42 | #21 | Link |
I'm not sure but it seems that the filter is processing (width*height) bytes of input, instead of (pitch*height) bytes?
Avisynth internally works with 64-byte alignment, and provides buffers as such. The structures passed to the filter contain pitch and even a modulo (pitch-rowwidth) number. Artifacts on top of RGB32 means that the last X bytes are left unprocessed (packed RGB is top-bottom) |
15th June 2020, 14:54 | #22 | Link | |
It does though work in x64 Vdub2 [EDIT: direct load of AVI]
EDIT: I've given Shekh a poke, maybe he enlightens us soon. EDIT: I've also tried with AVs script Code:
AviSource("D:\Parade.avi") ConvertToRGB32 EDIT: Quote:
# FIX VDubFilter.dll Weird BUG, but not the x64 bug # XMOD=16 YMOD=1 # OK XMOD=1 YMOD=16 # BAD, Prob in XMOD Crop(0,0,Width/XMOD*XMOD,height/YMOD*YMOD)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2020 at 15:32. |
15th June 2020, 15:23 | #23 | Link |
It's just a feeling, I see that depending on the horizontal crop (starting from mod16, then crop(0,0,-1,0) .. crop(0,0,-15,0) filter is giving bigger and bigger unprocessed area at the frame end (visible on top).
Note that -1 is 4 bytes, and a horizontal crop of -15 is 60 bytes. VDub filter can hint that it requires a buffer with a specific minimum alignment, which request is surely fulfilled by avisynth by having 64 byte aligned NewVideoFrame. Can you test it with avs 2.6 and width -1, -2 and -3 crop values (it has 16 bytes alignment)? |
15th June 2020, 15:38 | #24 | Link | |
15th June 2020, 15:51 | #26 | Link |
Hmmm, 32 bit looks ok here.
This is weird [AVS std 2.60 x86] Code:
# 64 bit VDF fails with error 0xC1, but filter works OK in VDUB2 x64, possible AVS+ VDubFilter.dll problem. # VDub GUI "Show Noise" and "Disable" args not available external to VDUB, ie not usable in Avisynth. # VDF accepts only RGB32 Function VD_CCD(clip clip, int "threshold", bool "multithreading",bool "ShowNoise",Bool "Amp",Int "preroll") { threshold = Default(threshold,30) # Default 30 as in Vdub multithreading = Default(multithreading,true) # Default true ShowNoise = Default(ShowNoise,False) # Simulated Amp = Default(Amp,True) # Amplify if ShowNoise preroll = Default(preroll,1) # We've given default of 1 frames pre-rolled, maybe only 0 needed. Assert(clip.IsRGB32,"VD_CCD: Need RGB32") LoadVirtualdubPlugin("D:\VDUB\ccd_32bit.vdf", "_VD_CCD", preroll) # Change Path to VDF # LoadVirtualdubPlugin("D:\VDUB\ccd_64bit.vdf", "_VD_CCD", preroll) # Change Path to VDF ## Getting Error OXC1 for 64 bit VDF plugin result = clip._VD_CCD(threshold,multithreading?1:0) return (!ShowNoise) ? result : (!amp) ? result.Subtract(clip) : result.Subtract(clip).Levels(126-8,1.0,126+8,0,255,coring=false) } THRESHOLD=30 SHOWNOISE=false AMP =false AviSource("D:\parade.avi") ConvertToRGB32(matrix="rec601") # FIX VDubFilter.dll Weird BUG, but not the x64 bug #XMOD=16 YMOD=1 # OK #XMOD=1 YMOD=16 # BAD #Crop(0,0,Width/XMOD*XMOD,height/YMOD*YMOD) # Here, 488x360 Crop(0,0,-1,0) # FINAL result still shows 488x360 ??? [EDIT Oops, 488 not 448] VD_CCD(threshold=THRESHOLD,shownoise=SHOWNOISE,amp=AMP) info EDIT: If Switch on SHOWNOISE, then fails at subtract due to different size frames. EDIT: Avs+ v3.61 test 8 x86 returns width 487 as it should, so looks like Avs 2.60 std has bug in VDFilter.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2020 at 16:08. |
16th June 2020, 08:56 | #27 | Link |
Not sure what you expect, surely a filter can have bugs. We dont know if x64 version was built from same source
VirtualDub2 |
16th June 2020, 10:20 | #28 | Link | |
OK Shekh, was hoping that you might have some magic words to say, thanks for taking a look.
I had to go back and read thread from start to figure out what the problem was/problems were. The 64 bit problem that I am having is that I cannot load x64 plugin, with error 0xC1. x86 problem is the weird stuff at top of frame. Also, I had gotten it into my head that VDFilter.dll calls VDub/VDub2 when it just has some kind of emulation layer for VD. Anyways, had some sleep now and hopefully have un-confused myself, a bit.
16th June 2020, 10:51 | #30 | Link | |
Also found out why I had problems with x64, I was trying to load x64 plug into x86 app,
Anyways, tried Code:
THRESHOLD=30 SHOWNOISE=false AMP =false AviSource("D:\parade.avi") ConvertToRGB32(matrix="rec601") # Here, 488x360 Crop(0,0,-1,0) # Now 487x360 VD_CCD(threshold=THRESHOLD,shownoise=SHOWNOISE,amp=AMP) info # FINAL result still shows 488x360 ??? Quote:
16th June 2020, 11:05 | #31 | Link | |
Can you load Avisynth+'s vdubfilter dll into classic Avisynth? |
16th June 2020, 11:31 | #32 | Link | |
v2.60,2.61, Seems to Work OK, prev error script returns 487x360 as it should. [and also same rubbish at top of frame for the bugged vdf filter]. So in v2.60/2.61 standard, LoadPlugin on Avs+ VDFilter.dll, Installs AVS+ LoadVirtualDubPlugin() and fixes the erroneous 488x360 bug [produces correct 487x360], and seems to work just fine.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th June 2020 at 12:13. |
17th June 2020, 08:50 | #33 | Link |
I talked with the author of the filter, informed him that we were going to create a remake of this filter under AVISynth+, and asked him to share the filter’s algorithm and / or sources, he said that he would send me some specific information in a couple of days when he returned from the trip.
18th June 2020, 09:04 | #34 | Link |
Here are the filter sources:
[URL deleted] The author of this filter Sergey Stolyarevsky kindly provided them to us. And he promised to join our discussion on this topic in a few days. ================== Updated fixed version here: https://forum.doom9.org/showthread.p...25#post1916925 Last edited by zybex; 27th June 2020 at 19:10. |
18th June 2020, 10:24 | #35 | Link | |
27th June 2020, 19:09 | #36 | Link |
Updated fixed version CCD V1.9 (Sources + Binaries)
https://mega.nz/file/GsYlQayQ#LO7qq8...KuQRCamtUe0lO4 |
27th June 2020, 20:05 | #37 | Link |
Cheers Sergey Stolyarevsky and Zybex.
1st July 2020, 09:51 | #39 | Link |
Hi, Sergey.
Glad to see you on the forum. pinterf now on vacation until about July 11: https://forum.doom9.org/showthread.p...64#post1916864 |
1st July 2020, 15:50 | #40 | Link |
Hello and welcome to the forum Sergey 1400
