6th November 2019, 12:58 | #81 | Link |
In case anyone is wondering why there haven't been any binaries produced so far it's primarily because how long it has taken for me to produce a build pipeline.
I wanted to use dockcross and osxcross Docker containers but ran into all sorts of issues getting them set up to build the project. After a while I had to scrap the whole effort and start over. I set things up in a VM to get Linux, Windows and MacOS builds all being produced successfully, I'm now transferring that setup over to a new, clean Docker container. Once that's all completed and tested I'll use GitHub Actions to get builds created automatically on each push. It's taking a while I know but the upshot will make things a lot easier to manage going forward! |
8th November 2019, 15:11 | #82 | Link | |
SuperVirus
Namely, on winpthreads, seh and libstdc++. Because when I use the winpthread-ed GCC from the MinGW-w64 project with MSYS2, the 64-bit .EXE is not linked statically to those libraries; and when I used the "toolchain" provided by pacman, even zlib could not be linked statically. Last edited by filler56789; 8th November 2019 at 15:12. Reason: clarity |
9th November 2019, 00:51 | #83 | Link |
-DCMAKE_EXE_LINKER_FLAGS="-static-libstdc++ -static -pthread" when configuring resolves it with vanilla MSys2 with default repo packages.
Comparison with ldd: 'plain' build without the additional linker flags: Code:
$ ldd tsmuxer-plain.exe ntdll.dll => /c/WINDOWS/SYSTEM32/ntdll.dll (0x7fff09500000) KERNEL32.DLL => /c/WINDOWS/System32/KERNEL32.DLL (0x7fff09400000) KERNELBASE.dll => /c/WINDOWS/System32/KERNELBASE.dll (0x7fff065f0000) GDI32.dll => /c/WINDOWS/System32/GDI32.dll (0x7fff07910000) win32u.dll => /c/WINDOWS/System32/win32u.dll (0x7fff072f0000) gdi32full.dll => /c/WINDOWS/System32/gdi32full.dll (0x7fff07350000) zlib1.dll => /mingw64/bin/zlib1.dll (0x62e80000) msvcrt.dll => /c/WINDOWS/System32/msvcrt.dll (0x7fff08d10000) msvcp_win.dll => /c/WINDOWS/System32/msvcp_win.dll (0x7fff07510000) ucrtbase.dll => /c/WINDOWS/System32/ucrtbase.dll (0x7fff06490000) USER32.dll => /c/WINDOWS/System32/USER32.dll (0x7fff07b40000) gdiplus.dll => /c/WINDOWS/WinSxS/amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.18362.418_none_17b1a56c6d9fd02b/gdiplus.dll (0x7ffed5a00000) libgcc_s_seh-1.dll => /mingw64/bin/libgcc_s_seh-1.dll (0x61440000) libwinpthread-1.dll => /mingw64/bin/libwinpthread-1.dll (0x64940000) libstdc++-6.dll => /mingw64/bin/libstdc++-6.dll (0x6fc40000) combase.dll => /c/WINDOWS/System32/combase.dll (0x7fff089d0000) RPCRT4.dll => /c/WINDOWS/System32/RPCRT4.dll (0x7fff08000000) bcryptPrimitives.dll => /c/WINDOWS/System32/bcryptPrimitives.dll (0x7fff06af0000) Code:
$ ldd tsmuxer.exe ntdll.dll => /c/WINDOWS/SYSTEM32/ntdll.dll (0x7fff09500000) KERNEL32.DLL => /c/WINDOWS/System32/KERNEL32.DLL (0x7fff09400000) KERNELBASE.dll => /c/WINDOWS/System32/KERNELBASE.dll (0x7fff065f0000) GDI32.dll => /c/WINDOWS/System32/GDI32.dll (0x7fff07910000) win32u.dll => /c/WINDOWS/System32/win32u.dll (0x7fff072f0000) gdi32full.dll => /c/WINDOWS/System32/gdi32full.dll (0x7fff07350000) msvcp_win.dll => /c/WINDOWS/System32/msvcp_win.dll (0x7fff07510000) ucrtbase.dll => /c/WINDOWS/System32/ucrtbase.dll (0x7fff06490000) USER32.dll => /c/WINDOWS/System32/USER32.dll (0x7fff07b40000) msvcrt.dll => /c/WINDOWS/System32/msvcrt.dll (0x7fff08d10000) gdiplus.dll => /c/WINDOWS/WinSxS/amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.18362.418_none_17b1a56c6d9fd02b/gdiplus.dll (0x7ffed5a00000) combase.dll => /c/WINDOWS/System32/combase.dll (0x7fff089d0000) RPCRT4.dll => /c/WINDOWS/System32/RPCRT4.dll (0x7fff08000000) bcryptPrimitives.dll => /c/WINDOWS/System32/bcryptPrimitives.dll (0x7fff06af0000) |
9th November 2019, 23:18 | #84 | Link |
You should be able to set the CMake flag "TSMUXER_STATIC_BUILD", which should generate a static build automatically.
For the Docker container specifically the Windows builds produced only use static dependencies and don't have any sort of external dependencies - I checked with Dependency Walker. Last edited by justdan96; 10th November 2019 at 11:44. Reason: forgot to mention that is for Windows builds in Docker container |
10th November 2019, 18:23 | #86 | Link | |
SuperVirus
https://github.com/filler56789/RV-tsMuxeR |
16th November 2019, 20:38 | #87 | Link |
I've started creating the GitHub actions to create the builds for all 3 platforms. I haven't quite finished yet but if people could test the builds produced I'd really appreciate it!
https://github.com/justdan96/tsMuxer/actions Just check the "Artifacts" on the latest run of "Build for Linux", "Build for Windows" and "Build for Mac". |
16th November 2019, 21:11 | #88 | Link | |
SuperVirus
(I know, XP should be dead and buried, but don't forget tsMuxeR had been a 32-bit-only application since its zer0th day...) P.S.: ¿¿¿ where is the new GUI ??? |
17th November 2019, 14:15 | #89 | Link | ||
Long story short, I'll get it sorted but it could take some time. Last edited by justdan96; 17th November 2019 at 14:16. Reason: formatting error |
17th November 2019, 18:27 | #90 | Link | |
That means either having a separate i686-w64-mingw32 toolchain that needs to be invoked, or the existing toolchain needs to be multilib-enabled (in which case it's just a matter of throwing in some -m32 flags and telling it where the /lib directory is for i686, sometimes it might require overriding the CMAKE_SYSROOT, but not often). What would be a showstopper specifically for XP is if MXE builds its toolchain with Secure API support turned on in MinGW-w64, as that will restrict everything it builds to Vista+. |
17th November 2019, 19:22 | #91 | Link |
Bug with aac
Hi all,
Another bug for aac muxing. In brief, the aac frame size is written on 13 bits (bits 31-43 in the frame), however tsMuxeR takes into account only the first 11 bits. So when the aac frame size is above 2048 bytes, tsMuxeR incorrectly reports a bad frame and discards it. In aac.cpp, replace line 52: Code:
int AACCodec::getFrameSize(uint8_t* buffer) { return buffer[4]*8 + (buffer[5] >> 5); } Code:
int AACCodec::getFrameSize(uint8_t* buffer) { return ((buffer[3] & 0x03) << 11) + (buffer[4] << 3) + (buffer[5] >> 5); } Last edited by a5180007; 17th November 2019 at 19:49. |
17th November 2019, 19:57 | #92 | Link |
Life's clearer in 4K UHD
18th November 2019, 00:20 | #94 | Link | |
Also @a5180007 thanks for the bug reports, I'll get those created in GitHub as issues so we can take a closer look at them. Additionally I've taken a close look at tsMuxerGUI and there aren't any actual code dependencies on tsMuxer - so a drop-in replacement could be created. Qt is pretty heavyweight for a simple application. My preference would be an application that can be made cross-platform with ease that doesn't depend on large GUI frameworks. I don't think we can swap out Qt for something like Nuklear that easily within the existing application so it may even be easier to rewrite it (if someone out there can prove me wrong I'd be very thankful!). I'll create an issue for it so we can track it. Last edited by justdan96; 18th November 2019 at 17:30. Reason: mention bug reports + GUI |
22nd November 2019, 17:20 | #95 | Link |
Also tsMuxeR cannot demux correctly mp4 aac 5.1 : the problem seems to be linked to a bug from ffmpeg. tsMuxeR takes the channel count from 'mp4a' atom (cf. movDemuxer.cpp line 1252), but as noted here ffmpeg sets the channel count to 2 in 'mp4a' atom even for aac 5.1, and the correct channel count has to be taken from 'esds' atom.
The following should correct the bug, could anybody please test and report: In movDemuxer.cpp add line 186 as follows: Code:
if (isAAC) { m_aacRaw.m_channels = m_sc->channels; // added line m_aacRaw.buildADTSHeader(dst, frameSize + AAC_HEADER_LEN); memcpy(dst + AAC_HEADER_LEN, buff, frameSize); dst += frameSize + AAC_HEADER_LEN; } Code:
if (st->parsed_priv_data) { ((MovParsedAudioTrackData*)st->parsed_priv_data)->isAAC = true; st->parsed_priv_data->setPrivData(st->codec_priv, st->codec_priv_size); st->channels = (st->codec_priv[1] >> 3) & 0x0f; // added line: copy channel count from 'esds' AudioSpecificConfig } |
22nd November 2019, 17:34 | #96 | Link | |
The following should do the trick, could anybody please test and report: In mpegStreamReader.cpp at line 130: Code:
//if (m_bufEnd - m_curPos < MAX_AV_PACKET_SIZE) { // remove condition : size of frame is now checked for all frames uint8_t* nextNal = NALUnit::findNALWithStartCode(min(m_curPos + 3,m_bufEnd), m_bufEnd, m_longCodesAllowed); if (nextNal == m_bufEnd) { storeBufferRest(); return NEED_MORE_DATA; } //} Code:
avPacket.size = m_tmpBufferLen; //changed from min(MAX_AV_PACKET_SIZE, m_tmpBufferLen); } /*if (m_tmpBufferLen > MAX_AV_PACKET_SIZE) { LTRACE(LT_ERROR, 2, "Too large last buffer (" << m_tmpBufferLen << " bytes). Truncate buffer to " << MAX_AV_PACKET_SIZE << " bytes. It does not have to be!"); } */ Last edited by a5180007; 22nd November 2019 at 17:49. |
25th November 2019, 17:19 | #99 | Link |
To go back a step and sorry if I missed it...
Were binaries produced that would be “like” V2.6.12 so we can compare results to the long exiting binary files. This would provide a great starting point for enhancements to 3D and HEVC 4K images. Excellent that TSMuxeR has been released to community. I’ll jump in at some point. |
26th November 2019, 19:41 | #100 | Link | |
Sorry I didn't update fully here, here is the quote from the readme:
Yes the binaries will be similar to 2.6.12, you can test the CLI now and use the older GUI if you can't (or don't want to) compile it yourself. Once I get the automated builds in GitHub working with tsMuxerGUI as well you can use the official binaries for that as well. It would be fantastic if people can compare the older versions to the latest, you can post the results to this forum thread or if you encounter a specific issue with what you think is the root cause you can create an issue on GitHub. |
