25th March 2004, 20:10 | #222 | Link |
Retired
Sounds like GDI+ is not installed. This shouldn't be related to EclCCE. What happens when you just drop the file(s) to be encoded into CCE directly? Get GDI+ here: http://www.microsoft.com/downloads/d...DisplayLang=en
25th March 2004, 21:53 | #225 | Link |
Tried that to no avail. Move takes the cursor to the top right corner of the screen, and no matter where I move it too, it doesn't show up.
EDIT: That is regardless of desktop size. EDIT2: Fixed! Last edited by CeanD; 25th March 2004 at 21:57. |
27th March 2004, 07:23 | #226 | Link |
RB
When I try to open or save an ecl my CCE windows just closes down. The EclCCE.exe file goes away in my task manager also. When I save an project I get a .ecl file but it has a 0kb size. I have tried 2.66 and 2.67 trial versions with 1.7b and now 1.8. Is there anything else I need to do? Thanks Brik |
28th March 2004, 21:12 | #227 | Link |
@RB
Hi I downloaded your latest version 1.18 but now when I run CCE 2.50 the Cancel button is always visible, also when I use -nocancel (cmdline) or HideCancel=1 in your ini-file. When I use CCE 2.67 the Cancel button is hidden. In version 1.17 the Cancel button of CCE 2.50 was also hidden with these options. Can you tell me why that is? Thanks.
The Mask Developer of The FilmMachine An easy to use, wizard-like, AVI/MP4/MOV/RMVB/MKV to DVD conversion utility |
29th March 2004, 00:25 | #228 | Link |
RB
I have 2.66 trial installed and was trying to use it with DVD Rebuilder. When DVD Rebuilder brought up CCE I couldn't see the window at all like CeanD. But CCE looked like it was encoding. I uninstalled CCE and deleted the registry entrees then reinstalled it. Now when ever I try to open or save an ecl file CCE just shuts down. The CCE and EclCCE exe files go away in the task manager. Has anyone else had this problem? I have tried to uninstall and reinstall and still get the same problem. |
29th March 2004, 16:30 | #229 | Link |
Retired
@TFM_TheMask:
Sorry for that, will be fixed in 1.8a which I'm already working on. @brikin: I'll fix the "invisible CCE" issue. It's actually a bug in CCE-SP versions prior to 2.67.00.13, which version are you using? However, I cannot reproduce the issue with opening and saving ECLs here. Tried 2.66.01.07 and 2.67.00.23. What OS are you running? Do you get the file open/save dialogs at least? What kind of video files were loaded into CCE and how (drag-drop or added from File -Add menu)? |
29th March 2004, 18:22 | #230 | Link |
I wish I would have never un-installed CCE the first time because it looked like it was working I just couldn't see the window.
I am using CCE 2.66.01.07 trial with EclCCE 1.8. I am using Windows XP. I am trying to use this with DVD Rebuilder. If I have any file in CCE and try to save the project CCE closes down. I get a 0kb .ecl file. If I try to open an .ecl file CCE closes down. This happens not matter if I use the menu to open the file or drag and drop method. I have tried to open the .ecl files from DVD Rebuilder. I can't understand why it wasn't doing this before and after a re-install these issues popped up. If you need any other info let me know. Thanks RB Last edited by brikin; 29th March 2004 at 18:25. |
29th March 2004, 21:11 | #231 | Link |
Retired
Hmmmm, very strange. I just cannot replicate this here. I'm using XP, too. So you are saying that when you click the little disk icon in the toolbar to save an ECL, it immediately shuts down, no additional dialogs like the common "Save As" Windows file dialog?
30th March 2004, 15:10 | #237 | Link |
Author of D2SRoBa
@RB, thanks a lot for doing the new minimize feature (I suggested). It works just perfect for D2SRoBa now!
A very minor request for version 1.8a: I notice that the checkbox "Shutdown after encoding" seems to be a default button (DEF_BUTTON), which makes the mouse pointer jump to that button when you restore it with a single click in the icon tray (that is if mouse 'Smart move' is enabled - very common). A double click in the tray will therfore often toggle shutdown! Could you make it non-default? Also, a shorter label and width of the button would make it less likely to be checked by mistake. /Add: Removing the shortcut (&Shutdown = Alt-s) would help in that respect too. /OT: Also thanks for the M2VRequant port you did. FYI, I now bundle it with D2SRoBa (source also). Did a fix, and a few mods: - made output file non read-only - added support for streaming (std in and out). Last edited by tylo; 31st March 2004 at 08:04. |
31st March 2004, 15:44 | #238 | Link |
Retired
Version 1.8a is out
31/03/2004 v1.8a - Fixed: Cancel button could not be hidden via command line or INI option for CCE-SP 2.50/2.62/2.64. - Fixed: under rare circumstances, CCE unexpectedly closed when loading or saving ECL. - Added: Fix for "invisible CCE window" issue with CCE-SP versions prior to 2.67.00.12 (see CCE-SP HISTORY.TXT). - Added: sanity check on ECL files to display a reasonable error message when trying to load an unsupported ECL format (CCE Basic). - Added: -hideshutdown command line option. Global option to hide the Shutdown checkbox in progress dialog, press Ctrl-Shift-S to hide/unhide at any time. Hope you like the new feature About M2VRequant: did you actually build upon my original release? It's heavily outdated, Makira since released several updates to the engine and of course, Nic transformed it into ReJig, including Makira's updates. Maybe you should better simply use ReJig. |
