Old 7th November 2017, 09:36   #22301  |  Link
LigH
LigH's Avatar
I guess you could try to unpack the installers with 7-zip (did not test).
New German Gleitz board
Old 7th November 2017, 09:54   #22302  |  Link
nevcairiel
Nightlies are only available as installers.
Old 7th November 2017, 10:52   #22303  |  Link
wushantao
I've tried 7zip unpack and can't get the related files
If don't take up too much your time, can you release a zip version pls?
wushantao is offline   Reply With Quote
Old 7th November 2017, 10:52   #22304  |  Link
nevcairiel
There are no plans to do that.
Old 7th November 2017, 11:01   #22305  |  Link
sneaker_ger
innounp should be able to extract the installers.
Old 7th November 2017, 13:38   #22306  |  Link
wushantao
Anyway, thanks for the software you developed
thx, i will try it
Old 7th November 2017, 14:29   #22307  |  Link
wushantao
thank you,it works perfect
Old 7th November 2017, 16:43   #22308  |  Link
wushantao
hi nevcairiel
maybe there is a bug for h/w decoder
lav 0.70.2.80 with evrcp
i set output format only RGB24(beacuse evrcp only 8bit)
play a 10bit file, D3D11&DXVA2(native) is NG, can not play
other decoder is ok
my gpu is iris 5200
Old 7th November 2017, 17:02   #22309  |  Link
nevcairiel
Don't disable any output formats. Also, 10-bit decoding requires quite new hardware, don't think a 2013 chip would be able to do that.
Old 8th November 2017, 18:40   #22310  |  Link
VictorLS
Thank you very much - innounp extracts great.
VictorLS is offline   Reply With Quote
Old 19th November 2017, 16:17   #22311  |  Link
cremor
Small thing I noticed:
The LAV Splitter configuration GUI refers to http://1f0.de for advanced subtitle selection reference documentation, but the page on that site seems to be older than the information in the README. E.g. there is no mention of the ! operator and instead of comma and space it mentions semicolon and space as separators.
cremor is offline   Reply With Quote
Old 19th November 2017, 21:06   #22312  |  Link
Major_Dick
Thanks for this, worked perfect.
Major_Dick is offline   Reply With Quote
Old 23rd November 2017, 19:06   #22313  |  Link
clsid
Hi nev, can you add options to configure probesize and analyzeduration?
Old 25th November 2017, 12:15   #22314  |  Link
Klaus1189
I use LAV Filters for watching MXF-Files, but in MXF files the audiochannels are stored as single mono streams. My NLE detects the files correctly as stereo.
How do I configure LAV Filters to use left and right mono streams as one stereo stream?
Old 3rd December 2017, 17:57   #22315  |  Link
robl45
hi guys, after something wonky happening with the computer where it would play nothing but dolby digital sound, I reinstalled all pieces with updated versions. Madvr, lav filters, mpc-be, intel video drivers, reclock. Now I was wondering with the latest lav video, what is the best hardware acceleration to pick? I have intel HD 530 graphics.
Specifically, I see these two lines in the change log
LAV Video
- NEW: D3D11 hardware accelerated decoding (native mode with madVR, Copy-Back otherwise)
- NEW: Support for hardware accelerated H.264 MVC 3D decoding on Intel GPUs
So what do I pick to be able to make use of that since I watch a lot of 3d and I use Madvr
robl45 is offline   Reply With Quote
Old 3rd December 2017, 18:01   #22316  |  Link
robl45
Originally Posted by mclingo View Post
maybe so, I never checked, the main thing is you dont have to manually mount it first so it plays straight from MPC-BE, havent tried with with KODI-DS though.
I'm think of switching back to ISO instead of ripping all mine to MVC MKV files, its much more convenient to keep the full bluray ISO even if it is a few gigs larger.
This works for me too, problem is if I don't rip to MKV, then I get no subtitles. Do you get subtitles?
Old 3rd December 2017, 19:50   #22317  |  Link
el Filou
el Filou's Avatar
LAV Video
Depends on what madVR features you use. If you use black bars detection/zoom control or ivtc, those won't work with DXVA Native. If you don't use them then try D3D11 Native for the best performance.
Old 3rd December 2017, 22:34   #22318  |  Link
Soulnight
I posted this message today in the Madvr thread but I noticed afterwards that this is actually off-topic for madvr and that it should be posted here. I apologize still for the double post.
Nevcairiel, I need you lights ;-)
Both random and ordered 10bits to 8bits dithering from Lavvideo generate very visible noise/structure, where Madvr "ordered" dithering is invisible to my eyes! But I can't use it. Here is why:
Originally Posted by Soulnight View Post
would it be possible to make dithering in Lavvideo Decoder as good or close to the one in Madvr?
I am asking because currently I use Bluesky FRC with AMD Fluid Motion to use frame interpolation of 4K 10bits 4:2:0 24p signal to 60p.
And the output of bluesky FRC in Madvr is only 8bits, as it seems that AMD Fluid Motion itself does NOT support 10bits.
BlueskyFRC convert P010 to NV12 using driver's function, BEFORE entering AMD Fluid Motion.
My target would be to have a high quality dithering BEFORE entering AMD Fluid Motion: for example in LAVVideo Decoder.
Right now, I can see random noise generated by the dithering method used by BlueskyFRC.
I also tried to deselect 10bits output in LAVvideo decoder in order to dither before in LAVvideo decoder before even entering Blueksy FRC.
However, the result is still not near as good, as when I feed the 10bits 24p signal directly to Madvr with ordered dithering selected there.
Thanks for the help.
Florian
Thx!
Soulnight is offline   Reply With Quote
Old 3rd December 2017, 23:00   #22319  |  Link
nevcairiel
Dithering is as good as its going to get, more complex dithering on the CPU would be too expensive and far too rarely useful to warrant the complexity.
There is several reasons why dithering in madVR would look better, for one dithering as late as possible is always better, if you do it far earlier in the decoder already, you have added noise all the way through the processing chain, which only gets amplified.
Old 3rd December 2017, 23:31   #22320  |  Link
Soulnight
Thank for taking time to answer me.
Why should dithering happen on the CPU?
Is it not GPU based?
Here a few Dithering algorithm:
http://www.tannerhelland.com/4660/di...s-source-code/
What I don't really get is why "ordered dithering" from madvr looks perfectly clean while "ordered dithering" with Lavvideo looks very blocky with clear patterns.
I get that the further in the chain the better, but here the chain is very short --> lav-->madvr with no extra sharpness processing whatsoever.
Thx,
Florian
