23rd October 2017, 14:28 | #15241 | Link | |
23rd October 2017, 14:53 | #15243 | Link |
That option is useful if you use heavy single threaded filters like MDegrain or QMTC deinterlacer.
Here is example 1920x1080 + MDegrain2 on my 16 thread CPU. MT DISABLED MT ENABLED
24th October 2017, 01:30 | #15244 | Link | |
I actually don't use MDegrain all that much...so what I'm thinking now is, for "normal" encodes, disable MT, and for MDegrain, etc, turn it on.... I will definitely give that a go !!. See, sometimes it pays to ask a "noobie" question edit:-...OK, well that's done the trick alright....it's good to have good speed back on "normal" encodes. I also did a MDegrain run on a pretty "dirty" 1080p Blade Runner, that was approx 18Gb, and after the encode down to 720p, with a fair bit taken out, it was only 1.5Gb, and took just over an hour to do. Last edited by burt123; 24th October 2017 at 03:34. Reason: more info |
24th October 2017, 12:22 | #15245 | Link |
According to my tests MDegrain2 can reduce bitrate in constant quality mode by factor of ~1.7x! I'm using it even on relatively clean movies.
I really like how it mainly removes those "dancing dots" without hurting too much real details.
24th October 2017, 12:30 | #15246 | Link | |
If MDegrain does such a good job by itself, why add the others ??? I mean, KNLmeans is sooooooooooo slow, and is GPU dependent, I haven't used it expect for a couple of times, when you first introduced it. If you haven't got several high end GPU's, whats the point. |
24th October 2017, 12:44 | #15247 | Link | |
Example
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th October 2017 at 12:49. |
24th October 2017, 13:19 | #15248 | Link | |
OK, well, maybe for particular encoders/users, and would save multiple runs thru Ripbot, using different filters. I generally use HQDN3D, but MDegrain2 seems to work well on most, and it seems to determine what it needs to do, "all by itself" Don't have any old anime, but might work well on old DVD rips, which I have a LOT of. |
24th October 2017, 13:28 | #15249 | Link |
I mainly use just MDegrain2 for regular movies and combo variant when I need that extra cleaning. Be careful to not overuse it.
24th October 2017, 16:34 | #15250 | Link | |
ByteShare
typical values I use with HQDeringmod: Code:
HQDeringmod(nrmode=2,Y=3,U=3,V=3,lsb=False,thr=255.0,darkthr=255.0) |
25th October 2017, 20:12 | #15251 | Link |
Hi Atak_Snajpera, just curious about 1.21.0 compared to 1.19.6 that I was using before. I notice that ffmsindex.exe indexes the video file now when it is first added, and then the video file is indexed again once encodingclient.exe opens before the distributed encoding starts.
26th October 2017, 16:08 | #15252 | Link | |
ByteShare
https://www.videohelp.com/software/R...tory#changelog |
26th October 2017, 19:25 | #15253 | Link |
Thanks byteshare. I was just curious about the added video indexing step. ffmsindex.exe indexes the *.mkv file when it is first added in Ripbot264 GUI to produce *.mkv.ffindex and *.mkv.ffindex_track00.kf.txt files. When encodingclient.exe opens it copies the video.mkv file to the shared folder and then ffmsindex.exe reindexes that file again to create video.mkv.ffindex and video.mkv.ffindex_track00.kf.txt. It just seems redundant.
30th October 2017, 11:55 | #15255 | Link | |
https://www.virustotal.com/#/file/c3...be88/detection
30th October 2017, 20:03 | #15257 | Link |
Batch Question
I'm sorry if this has been asked before, I did a search and didn't find results here.
I'm still using version 1.19.3, I had some issues with distributed encoding and subtitles on 1.21. Is there any way to add the ability to batch process m2ts files? Its not a recognized filetype at least in 1.19.3. If I change the files to mts, ripbot will import successfully, but it will not use distributed encoding. I use it to compress blu-ray tv episodes, lots of files to compress. Thanks for all your work. |
31st October 2017, 14:55 | #15258 | Link | |
31st October 2017, 16:30 | #15259 | Link | |
ByteShare
As for your Distributed Encoding (DE) issues, we'd need more info as I personally am not having issues with using DE. |
31st October 2017, 18:30 | #15260 | Link |
Issues I had
Issues,
was getting random avs2yuv.exe crash errors on client machines used to run the encoding server. Sometimes they would work for a full movie or two, sometimes not, and the incomplete chunks would still get written to the movie file, causing skips and such. the second issue was subtitles would sometimes flash sporadically even though they were proper srt files with good timing. Both issues went away when I reverted back to 1.19.3 |
