Old 6th February 2020, 00:43   #7381  |  Link
qyot27
qyot27's Avatar
Originally Posted by LigH View Post
The x265 source repo will migrate to Git and move to https://bitbucket.org/multicoreware/x265_git/ (Bitbucket will drop Mercurial support until June 2020).
Previously I used the combo of "hg pull" and "hg update" to keep a local working directory up to date. Which would be the recommended Git commands?
Easy:
git pull (like was mentioned above)
More exact (like when following more than one upstream HEAD):
git fetch <remote>
git merge <remote>/<branch>
which would look like:
git fetch origin
git merge origin/master (to update the master branch to its current remote state)
If you don't care about being able to recover the file or commit history and just want raw download speed:
git clone --depth 1 https://bitbucket.org/multicoreware/x265_git
Git is, as others have noted elsewhere, basically a time-based file system that happens to work great as a DVCS. Mercurial is just a DVCS.
Old 6th February 2020, 02:00   #7382  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by MeteorRain View Post
I don't understand the point of mentioning the size of the repository.
I use Git not for saving 200MB of space, but for managing the source code.
I'd happily trade a few gigabytes of my "precious?" hard drive space for a tool that works better to me.
Because the size of the hg repository is much smaller than the git one?
Because I'm old and therefore much more impatient than you?
Because I think that "huge and cheap" storage space is not an excuse for inefficiency?
To answer your previous question, git object pack is a compressed package of all kinds of objects used by git, including histories, files, deltas, etc.
Then it compresses much worse than hg, or at least it seems so...
If network activity is a real concern to you, you can limit the depth of repository to download. You can choose to only download and store the most recent 500 commits, for example, and still work on that as long as you don't need access to history more than 500 commits back.
Yes, my interest in x265's source-code is only to download and compile its most recent stuff, I have no use for a 300 MB """compressed""" archive that is not the code that I intend to compile.
filler56789 is offline   Reply With Quote
Old 6th February 2020, 06:15   #7383  |  Link
MeteorRain
結城有紀
Then do a shallow clone like we posted.
We are developers and functionality is much more important for us than a few hundred megabytes.
No, huge and cheap storage is not an excuse for inefficiency, however this is not inefficiency, this is only "space" inefficiency.
You don't say ffmpeg is garbage because it's a 60MB binary.
BTW, compared to a few seconds of downloading, the actual compiling is much more time consuming.
I'm too impatient but each time I compile my x265 mod it will take a good 2 hours on a Xeon E5 server.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 7th February 2020, 14:00   #7384  |  Link
LigH
LigH's Avatar
Since the media-autobuild suite switched to the x265 Git repository, I have trouble retrieving the sources. It seems like git receives all the expected data, but then suddenly handles the closing connection as if it was interrupted in an error. Here from an interactive MSYS2/MinGW console:
$ git clone https://bitbucket.org/multicoreware/x265_git.git x265_git-git
Cloning into 'x265_git-git'...
remote: Counting objects: 88154, done.
remote: Compressing objects: 100% (88115/88115), done.
remote: Total 88154 (delta 2853), reused 85263 (delta 0)
error: RPC failed; curl 56 OpenSSL SSL_read: Connection closed abruptly, errno 0 (Fatal because this is a curl debug build)
Receiving objects: 100% (88154/88154), 277.47 MiB | 1.58 MiB/s, done.
Resolving deltas: 100% (2853/2853), done.
Retrieving Git repositories from other sources works without error. So I wonder if Bitbucket may handle little details differently. If so ... I may not be able to report this issue to Bitbucket, as I am not the Atlassian customer responsible for the x265 repo.
New German Gleitz board
Old 7th February 2020, 15:03   #7385  |  Link
LigH
LigH's Avatar
I'll see if this Windows 7 hotfix has any impact...
Oh, it has been discontinued. I need Windows 10 to solve it.
Or it is a different one? It's errno 0, not SysCall 10054.
Cloning x264 and dependent ffmpeg/ffms2/lsmash works without abort.
After x264 was retrieved (I deleted build/x264-git), now x265 was retrieved too? ... Strange technology.
Old 7th February 2020, 16:20   #7386  |  Link
Barough
Barough's Avatar
No issues with the change to x265 git. Just running smooth here.
Sent from my SM-G975F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 8th February 2020, 00:19   #7387  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Git is an abominable piece of trash IMHO, but it's what we're stuck with, since hg is rapidly disappearing. (I'm going to have to convert all of my repos, too.) 99% of all git problems are best solved by just deleting the entire folder and cloning from scratch. Sometimes a hard revert will also do the trick, but not as reliably. If you have changes, just try to pull a patch and reapply after.
Old 10th February 2020, 09:05   #7388  |  Link
LigH
LigH's Avatar
Cloning was just the problem. Or handling the HTTPS connection.
Old 11th February 2020, 18:26   #7389  |  Link
MeteorRain
結城有紀
Try ssh protocol instead?
Projects
Old 12th February 2020, 12:59   #7390  |  Link
LigH
LigH's Avatar
Well, it suddenly worked once (when I let it clone x264 before x265). Maybe just something on my PC was out of sync.
Old 14th February 2020, 09:11   #7391  |  Link
filler56789
SuperVirus
x265.exe 3.3_RC1+2-e386d3a8a713
(64-bits, multilib, GCC 9.2, Win32-threads)
regression: fix analysis-save/load commands
http://www.mediafire.com/file/qnc7l7...8a713.rar/file
Old 15th February 2020, 13:16   #7392  |  Link
nakTT
Any interesting changes from version 3.2?
nakTT is offline   Reply With Quote
Old 16th February 2020, 05:58   #7393  |  Link
Greenhorn
Against the last 3.2x nightly builds, or against 3.2 release?
Against the former, just what's mentioned. Against the latter: --hist-scenecut to enable a different method of selecting scenecuts, --scenecut-aware-qp to apply an offset to the qp of keyframes and the frames immediately after them, and a more or less total overhaul of how the analysis-save/load feature works. Probably more that I'm not remembering.
Greenhorn is offline   Reply With Quote
Old 17th February 2020, 04:37   #7394  |  Link
nakTT
Thanks for the reply. My question was against 3.2 release, sorry for not being specific. BTW, was there any changes related to improved compression? Thank you in advance.
Old 17th February 2020, 22:19   #7395  |  Link
benwaggoner
Yes, the improved scene detection and optimized QP around scene transitions will both improve compression efficiency. The quality of frames around edits will be better at the same bitrate.
Sent from my SM-T837V using Tapatalk
Ben Waggoner
My Compression Book
Old 18th February 2020, 15:55   #7396  |  Link
filler56789
SuperVirus
x265.exe 3.3+3-c2769ac5fa9d
Release notes: https://bitbucket.org/multicoreware/...leasenotes.rst
download: http://www.mediafire.com/file/op10k0...c5fa9d.7z/file
Old 18th February 2020, 16:09   #7397  |  Link
nakTT
Thanks for the reply. Glad to know they are still improving the compression efficiency even after years of develoment.
Thanks, will give it a try.
Old 18th February 2020, 16:51   #7398  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Have you made any tests concerning the new functionalities? They once again appeared without any use cases etc.
Old 18th February 2020, 18:13   #7399  |  Link
benwaggoner
Not myself yet. I'm currently at the HPA tech retreat. I should have some physical and CPU time to run some tests next week.
I didn't mention the Adaptive frame duplication feature. This promises some significant efficiency savings and also faster random access for content where there are identical frames. Credits, screen activity, and anime/cel animation seem particularly likely to get improvements.
I wish there was an optional flag that can allow --keyint to limit total encoded frames, so --keyint 240 would mean 240 unique coded frames. Thus, with 24 fps where the animation is at 8 fps (so three duplicate frames in a row), --keyint 240 would yield a GOP covering 30 seconds instead of 10. Not great for adaptive streaming, but could save space for a file without impacting random access.
Ben Waggoner
My Compression Book
Old 18th February 2020, 18:15   #7400  |  Link
benwaggoner
Encoders are never done; we're still seeing improvements to MPEG-2 encoding after all these years. Particularly as long as Moore's Law keeps happening, we'll always find ways to take advantage of more MIPS/pixel.
With a codec as complex as HEVC, I would expect we'll be seeing material year-on-year encoder improvements for at least another five years.
Ben Waggoner
My Compression Book
