30th September 2015, 16:35 | #33261 | Link |
Disabling d3d11 did fix the frame glitching, thanks. But could it be it also brought down the performance notably? I can't run adaptivesharp now without getting what seems to be underperformance. Gpu-z stopped reading sensors again so I have to look into it a little closer in a while...
30th September 2015, 16:57 | #33262 | Link |
I could never notice a real performance advantage of one render path over the other, what was too much with D3D9 was also the case with 11 and vice versa.
But that doesn't have to mean that there wouldn't be such cases. Could you double-check? What is your GPU? |
30th September 2015, 17:16 | #33266 | Link |
I don't even have optimus or anything. This thing is as big a ripoff as it gets and supports nothing fancy whatsoever. I don't even understand nvidia and their products, it's all just one big pile of numbers that don't line up and features that go unexplained and unmarked.
30th September 2015, 18:23 | #33268 | Link |
I found strange bug.
When i playing any 1080p 60fps movie in window - madVR show "image < DXVA". Playback is very smooth, without drops and skips. When i switch to full screen "image < DXVA" disappear and playback is poor with drops and skips. Why??. On EVR everything is ok. I have NUC5PPYH (Braswell CPU), Windows 10 Home, last version MPC-HC, Lav filters and madVR. madVR all scaling option set to DXVA2. |
30th September 2015, 19:01 | #33269 | Link | |
madVR options explained |
30th September 2015, 20:00 | #33271 | Link |
"image < DXVA" means image downscaled using DXVA. It does not show that in fullscreen because then no scaling is needed (if you have 1920px screen width).
MPC-HC 2.1.7.2 |
30th September 2015, 20:27 | #33272 | Link | |
automatic refresh rate change on exclusive mode
Maybe important to say that the 23.976 fps (doubled with Avisynth in FFDShow to 47.952) remains stable and on the same memory bank even in fullscreen exclusive mode: it changes only with the 25fps (doubled to 50fps in the same way) to the 60Hz memory bank. And now I discovered another little issue: some subtitle from .MKV tv series are displayed in the center of the screen (in the middle of the image, to be clear), when with the 89.2 build were correctly displayed at the bottom of it. It doesen't happend with the DVD or BD subtitles (it may depend from the type of subtitle used in the .MKV? But I got no problem with them before this "subtitles manager version"...). Could this be helpful to find a solution?
Best Regards! Leo! |
30th September 2015, 22:10 | #33273 | Link |
Posts: n/a
Damn, the stutter-after-pause is still not fixed and occurs no matter what I try. Its quite annoying having to:
- close the video file - experience screen-flash refresh rate change from 23Hz to 60Hz (Desktop is @ 60Hz and video files are @ 23Hz) - open the file again - experience another screen-flash refresh rate from 60Hz to 23Hz - find the right spot to continue watching your video file (although I learned to remember the time at which I closed the video file to get back to watching quicker). Is this bug on the list of "To-be-fixed soon" list? Also, will Chroma Upscaling SuperRes be updated to the same version as Upscaling Refinement SuperRes? Last edited by XMonarchY; 1st October 2015 at 04:36. |
30th September 2015, 22:20 | #33274 | Link |
Haven't got any logs but MadVR 0.89.5 is pretty unstable for me. About half of the time, MPC-HC doesn't exit properly when I close it, plus sometimes I'll open a video and the audio will play with no video. If I switch to EVR it plays fine. Hopefully I'm not the only one.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
30th September 2015, 23:58 | #33275 | Link | |
The problem I think it doesn't always happen 100% after pause, for me it happen more often in windows mode and only seem to occur if I pause it long enough. Sent from my SM-T700 using Tapatalk Last edited by baii; 1st October 2015 at 00:01. |
1st October 2015, 04:04 | #33276 | Link | ||
Would it be prudent to have a setting that alters the crop a handful of frames before having a relatively large increase in the resolution in the next scene? I increased the GPU/present queue sizes however it doesn't seem to make a difference in this case. |
1st October 2015, 11:15 | #33277 | Link | |
Drawbacks (as madshi told us): no overlay mode and no NNEDI3 interop in this mode.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
1st October 2015, 14:40 | #33278 | Link |
Maybe according to reported render times. But that doesn't mean playback would be stable under extreme conditions while it wouldn't be with new path.
They both give very much the same GPU load reported by driver and it's never good to come in regions where you have almost no reserves left. |
1st October 2015, 16:45 | #33279 | Link | |
I'll give you exact numbers later, until then you can try it out for yourself
