18th September 2020, 01:26 | #60161 | Link |
Todays NVIDIA Driver:
Changes and Fixed Issues in Version 456.38 [madVR][MPC-HC]: Various HDR issues occur when using the madVR renderer with MPC-HC. [3038381] Yay! Hopefully this fixes the HDR issues.
LG OLED65C9PUA | Denon AVR-X3500H | Windows 11 | NVIDIA GeForce GTX 1050ti | LAV Filters | madVR | MediaPortal | Plex |
18th September 2020, 01:31 | #60162 | Link |
Already tested:
https://forum.doom9.org/showthread.p...50#post1923650 |
18th September 2020, 10:10 | #60164 | Link | |
When it is disabled Windows desktop etc is displayed by the TV with Auto(sRGB/BT.709) when using RGB 4:4:4 10-bit or 8-bit output on Adrenalin Display tab. On RGB 8-bit output the TV displays BT.709 UHD correctly and also switches correctly to BT.2020 for videos that use it. On RGB 10-bit output the TV displays BT.709 UHD as BT.2020. All off above were with "10 bit pixel format" disabled. However if I then enable the "10 bit pixel format" on the Adrenalin general settings and reboot, everything including the Windows desktop is displayed as BT.2020 by the TV and colours seem to be overly bright and vivid. I think you were right that it has something to do with AMD. On RGB 10-bit it sends all videos on full screen as BT.2020 and then if "10-bit pixel format" is enabled also, it sends everything including the desktop as BT.2020. Or then it is something on the TV, if there is 10-bit signal it automatically uses BT.2020 no matter what the video contains. I really don't know how these work under the hood but something like that. I guess it's just better to output everything as 8-bit as there does not seem to be any colour banding etc when using it, RGB 10-bit and 8-bit output seem to produce the same quality test patterns on the TV.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 18th September 2020 at 10:18. |
18th September 2020, 11:10 | #60165 | Link | |
I cant see that 10 bit switch anywhere in my "general" setttings, never heard of it but this sounds interesting, , can you provide a screen shot, please dont attach it using the forum though, is onedrive link or something else
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
18th September 2020, 12:47 | #60167 | Link |
there hasnt been any word on anything for over a year, your guess is as good as anyones
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions Last edited by mclingo; 18th September 2020 at 12:50. |
18th September 2020, 15:32 | #60168 | Link | |
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 |
18th September 2020, 16:01 | #60169 | Link |
I remember that game My first dGPU was Voodoo2. It's a real shame that there is so little competition these days.
18th September 2020, 17:03 | #60170 | Link |
I remember AVSForum back in 1999 when we were all building early Pentium HTPC's.
I got into that after buying the first HDTV mass released to the public. The RCA MM36100 36" 4:3 800x600 CRT TV with two VGA inputs. I used it with an HTPC and the first dish HD receiver, the RCA DTC100. Can't remember what video card I used but I'm sure it looked something like this. I'm pretty sure I was way late on my rent after buying that TV from Fry's Electronics in Woodland Hills, CA. Last edited by CZ Eddie; 18th September 2020 at 17:05. |
18th September 2020, 18:01 | #60172 | Link | |
as stated you ant add attachments to this thread, it sometimes takes days for them to be approved, i cant view it
18th September 2020, 18:04 | #60173 | Link | |
Yes you have. He's referring to the issue that happened when the Turing cards first came out and was worked around by setting the number of frames to 1. Ultimately it was fixed by a driver update by nVidia. Shocking that it wasn't a madvr issue after all.
18th September 2020, 18:07 | #60174 | Link |
anyone else on AMD card any idea what he's on about, I cant see anything in DISPLAY, VIDEO or GENERAL apart from "pixel format" in DISPLAY where you set FULL RGB/YBCR etc
18th September 2020, 18:37 | #60175 | Link | |
Since that was an Nvidia issue, so no need to worry guys |
18th September 2020, 18:44 | #60176 | Link | |
remove all old stuff by running it in save mode (automatically done by tool) Then after restart install the new driver and after installation do also a restart. Issue gone or does it persist? |
18th September 2020, 19:33 | #60178 | Link | |
https://1drv.ms/u/s!Ath_q56vIKVai90p...GIJ9Q?e=NhCqgA
18th September 2020, 19:33 | #60179 | Link |
It would seem so, if all you read is doom9. Madshi has been active all this time over on AVS.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex |
18th September 2020, 20:27 | #60180 | Link | |
(disclaimer: I'm not a dev so if what I said is wrong someone can correct me)
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
