18th January 2009, 16:20 | #401 | Link |
Programmer (or just 教务长)
I tested on USB all possible options:
1, 2, 3, 4 and 5 titles LITE menu with PAL system selection 1, 2, 3, 4 and 5 titles LITE menu with NTSC system selection These are 10 different tests and they all play on my PAL Playstation3. Try to download the whole PAL FULL or LITE. |
18th January 2009, 16:32 | #402 | Link | |
I've used the skip menu option and it played fine, but when i press "top menu" it goes to the menu without options. |
19th January 2009, 10:13 | #403 | Link |
The problem with non-showing-menu is fixed for DVD/BD recorded media. Probably it will fix the rare cases when menu is not shown during USB playback. (build 206).
I'm updating the full/lite links in the first post. |
19th January 2009, 12:03 | #406 | Link |
No, you don't, but sometimes downloads of important updated files fails. So it's better to download LITE package for your tv system and overwrite multiavchd folder.
Build 212: Now ImgBurn is supported. Check SETTINGS TAB. Last edited by deank; 19th January 2009 at 12:39. |
19th January 2009, 15:11 | #410 | Link |
PS3 tends to do strange things sometimes. If you see your movie so it is normal
Check this post. --- Please if someone can test if IMGBURN works for him. Last edited by deank; 19th January 2009 at 15:21. |
19th January 2009, 16:57 | #413 | Link |
Yes. I was thinking of this today. Please download FULL package of your choice and I'll post a link for MAC in a bit.
The link is still the same. multiAVCHD version 1.5 (build 213) for WinEmu/Mac Last edited by deank; 19th January 2009 at 17:08. |
19th January 2009, 17:09 | #414 | Link | |
Caped Crusader
Cheers for that. |
19th January 2009, 17:34 | #417 | Link |
If it is loading ok - it will work. All network functions are stripped, so no HTTP downloads of updated components is possible with _mac version.
I think that at this point (build 213) everything works as expected. Motion and static menu show okay via USB and optical media. Correct title count is shown for first 5 titles and all options work as expected. Things to do: * AVCHD split (it will split output to multiple AVCHD folders if certain size is reached for current AVCHD output). This was requested by turbojet while ago. It will help importing 8GB video (mkv/*ts) and multiAVCHD will generate two (or more) folders for two DVD9 discs. * m2ts split while importing AVCHD/BD folders - requested by shv few days ago. * custom menu and centered NC videos is delayed |
19th January 2009, 18:31 | #420 | Link | |
To avoid repeating the same things over and over again, maybe you should put a huge boilerplate in the first post that everything explained here will NOT be answered individually and that reading at least this first post is _absolutely_ mandatory before posting any "problems" with multiAVCHD... |
