14th October 2004, 17:37 | #182 | Link |
I guess you missed this:
http://forum.doom9.org/showthread.ph...793#post244793 2COOL has written a few really cool guides for pgcedit, some of which to do exactly what you ask. Jeanl |
15th October 2004, 06:53 | #183 | Link |
RE: Removing unwanted Titles or PGC's
Thanx 4 the reply.
I had a look at all those guides, but they only BLANK out the PGC's and Titles. In other words, they get replaced by a blank frame for Titles. This means that you'll have a few blank VOB files sitting on your DVD that's not needed at all and PGC's not used. Scenaria: I create a new DVD with PGC Edit and add 2 Titles. Title 2 is wrong and I need to replace it or I don't want it anymore. Now the only thing to do is to blank it out right? Now I add the correct Title, but now I have 3 Titles. The only way I get past this, is to close PGC Edit, start it up again and create a New DVD. Wouldn't it be cool to be able to delete it instead of starting over? Thanx km |
15th October 2004, 07:23 | #184 | Link |
Country Member
You really are a perfectionist Kaimaster. Those blanks take up a measly 10KB (plus the associated IFO and BUP) and you can disable the playback with PGCEdit's killplayback function anyway.
Les Only use genuine Verbatim or Taiyo Yuden media. |
15th October 2004, 09:45 | #185 | Link |
PgcEdit daemon
@Kaimaster
I have tried to wrote a function to delete an arbitrary PGC, in the title or menu domain, or the whole titleset. This is really not a piece of cake. There are many tables and parameters to update, in the VTS and VMG IFOs. All references to the deleted PGCs must be safely removed. Furthermore, and this is the big problem, all references to PGCs or titlesets following the removed one must be updated. I may write more easily a function to completely remove the LAST titleset of the DVD (VTSM and VTST), but here again there are difficulties. (For example, it is possible that one Title number in the deleted VTS is not the last one in the VMG_TT_SRPT table: I must therefore update all the JumpTT targets.) If you really want to cleanup totally your DVD of unwanted titlesets, you should use the New DVD and the Import functions, and modify the references in the commands yourself. That's what you suggested...
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 15th October 2004 at 09:51. |
18th October 2004, 16:07 | #186 | Link |
member
Hi r0lZ, i'm having some problems with Pgcedits macros. the import title closing clip and the import title intro clip i get errors, but the import first-play (start up) clip works fine. what i did was create a movie only backup with dvdshrink in re-author mode then tried to import the clips. here are the two error messages i get when i try to use the marcos.
invalid command name "set_menu_type" invalid command name "set_menu_type" while executing "set_menu_type 0 1 1 0 " (procedure "::macros::import_title_intro_clip" line 126) invoked from within "::macros::import_title_intro_clip" (menu invoke) and to other one is the same except of this line. (procedure "::macros::import_title_closing_clip" line 273) any ideas? thanks
some guides |
18th October 2004, 16:30 | #187 | Link |
PgcEdit daemon
Hi sweetness,
Bug found and fixed. A new version will be available soon...
20th October 2004, 14:00 | #188 | Link |
PgcEdit daemon
PgcEdit v0.3.6 released.
Download Added:
20th October 2004, 14:31 | #190 | Link | ||
PgcEdit daemon
20th October 2004, 17:12 | #192 | Link |
r0lZ, thanks for this new release!
It sounds like pgcedit's Kill Playback macro is now the most advanced around, as it now also handles cases (pointed out by 2COOL) where playback previously still occured. This is really cool. Can't wait to play with it! Jeanl |
20th October 2004, 17:25 | #193 | Link | |
PgcEdit daemon
However, though it is theorically possible to blank or skip any playback with PgcEdit, the case of a menu with buttons is not yet automated. You have still to follow the 2COOL's guide to get rid of them. Maybe I'll write a macro to automatize that...
20th October 2004, 17:32 | #194 | Link | |
Jeanl |
20th October 2004, 18:16 | #195 | Link | |||
Just a Member
@r0lZ
jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
20th October 2004, 19:11 | #196 | Link |
PgcEdit daemon
No, I think at BlankCell.exe. It adds a blank cell to any VOB. You know that: it's your job.
It is therefore now possible to exchange any cell with a blank one. This step was missing to complete the 2COOL's guide with PgcEdit alone. Thanks again, jsoto!
20th October 2004, 23:37 | #200 | Link | |
PGC Navigator in Training
2COOL |
