11th May 2007, 17:14 | #21 | Link |
DTS Pro Series
Je je je Dolby Surround EX in Sony Sound Forge 9 with VI.I
01. Menu / File / Open Wav. 02. Bla, bla, bla, bla, bla,..... 03. Menu / File Properties / Proyect 7.1 04. Add plug-in VI.I and Press Processing selection. 05. To select track 4 (channel LFE), Cut. 06. Copy track 7 (SC) and paste track 4, Menu / Edit / Paste. 07. Menu / File / Properties / Proyect 5.1 07. Configuration my Sound Card Creative X-FI (Creative ASIO) in Sony Sound Forge 9 FL FR CENTER SC SL SR 08. Enable LFE 09. Enable Exfbitstream Dolby Surround EX or Dolby Digital EX. WOOOOWWWW Frank je je je
Addict to the audio multichannel Last edited by Elektra999; 11th May 2007 at 19:46. |
11th May 2007, 19:13 | #22 | Link |
This is wrong what you are doing!!!
You're erasing LFE and leaving surrond center(SC)? SC is actually matrixed added into the two rear channels DURING DD EX encoding, NOT Discrete channel. Put that (last) way created AC3 EX in MediaInfo or play it with PowerDVD(check show info). How much channels does they show? (it should be real 6 or 5.1). So V.I is enough for DD EX. |
11th May 2007, 19:57 | #26 | Link |
DTS Pro Series
Not, not, not, VI.I channels SL, SR, SC Matrix, not discrete.
Srs Circle Surround channels SL, SR, SC yes discrete, VI.I no. Dolby Surround EX, chanels SL, SR, SC Matrix, VI.I works perfect.
Addict to the audio multichannel |
11th May 2007, 20:08 | #27 | Link |
DELET SC matrix from VI.I and let DD EX encoder create SC matrix, otherwise you're getting 2 SC.
DD EX 6.1 or 7.1 only exists during decoding. DD EX 6.1 or 7.1 have 5.1ch + EX/(SC or 2xBR*) matrix(encoded in SL and SR). SC, for 6.1 speakers, is created during playback from EX matrix. *BR-back rear(x2) (mono), for 7.1 speakers, are also created during playback from EX matrix. Last edited by SealTooGreat; 11th May 2007 at 20:30. |
12th May 2007, 18:35 | #29 | Link |
DTS Pro Series
Hello
I'm sorry, SealTooGreat. It was wrong. The order of channels in Sony Sound Forge 9 is bad. On what you were commenting it is nice: Yes, Proyect 5.1 (Sony Forge 9), Process with V.I, AC3 Pro window Exbitstrean Enable Dolby Surround EX Encoded= Dolby Surround EX (6.1) Sony Vegas 7, is different, allows me to add the channel SC and the order of channels, seems to be good. I'm Sorry SealTooGreat and
17th May 2007, 19:08 | #31 | Link |
It's better to use Sound Forge 9(SF9) with Sony Vegas 7(SV7), 'cause with SV7 you can apply 2ch limiter to each track, separately.
SF9 doesn't allow that, unless you have 6/8ch limiter (to apply to all 6ch at the same time). It's useful to create Surround Project template in SV7, before importing V.I_wav_6ch from SF9, with 2ch limiters assigned to each empty audio track(there should be 6 audio tracks with regulated Surround Pan for each channel - move pan point to appropriate channel and 4th track is only LFE). In "File->Properties->Audio->Muster bus mode" 5.1 surround must be selected (otherwise only stereo encoding is possible) , and change other settings upon your project (CD or DVD). Save template (use name you like) - "File->Save As". So every time, before importing V.I_wav_6ch in SV7, just load/open template. @Elektra999 I don't understand your last post. Last edited by SealTooGreat; 17th May 2007 at 20:31. |
17th May 2007, 20:09 | #33 | Link |
Well, I knew that . But it's tooo loooong. Can't process all 3 limiters at the same time.
And you have merge back those separate limiter_processed 2ch tracks into 6ch. Still don't have a clue how to do stereo->5.1ch with Sony Vegas 7 and V.I plugin. In fact I've managed to create 5.1 using stereo buses and 2-in-2-out plugins(fLfR, CLFE, sLsR) from V.I. suit, but can't encode to multichannel 'cause project is set to stereo. And 6-in-6-out doesn't work with surround bus, sound is distributed equally as no VST have been applied (Project bus mode is set to 5.1 surround). Last edited by SealTooGreat; 17th May 2007 at 20:44. |
26th May 2007, 19:39 | #35 | Link |
DTS Pro Series
Hello
To mix of channel SC, in channels SL and SR. DOLBY DIGITAL 6.1 IN SONY SOUND FORGE 9 - Menu / File / Properties / To write 7 - Processing with VI.I - Select Track 7 (channel SC) - Menu / Edit / Copy - Select track 5 (channel SL) - Menu / Edit / Paste Special / Mix, configuration: - He chooses the configuration that more you like for your room 6.1. 0dB, -3dB, -6dB. The same thing with the track 7 (channel SR) Now if that is DOLBY DIGITAL 6.1
27th May 2007, 04:34 | #36 | Link |
OK... You've mixed SC into SL&SR created from VST VI.I. But this doesn't change the fact that DD EX encoder is the ONLY ONE how will write EX flag into SL&SR. Again, V.I is enough for DOLBY DIGITAL EX, don't bother with VI.I unless you have 6.1 discreet capable DD encoder or you are simple satisfied with WAV_7ch.
27th May 2007, 10:07 | #37 | Link | ||
-xbsi2 1 -dsurexmod 2 (2 = Dolby Surround EX encoded) Quote:
27th May 2007, 10:43 | #38 | Link | |
As far as I know, for DD EX you need wav_5.1ch, the EX rest is a flag. Last edited by SealTooGreat; 27th May 2007 at 10:45. |
27th May 2007, 13:14 | #39 | Link | |
The same procedure than Dolby ProLogic (4/5 logical channels in two phisical channels). If the adequate mix is obtained and the flag is set, a DD EX decoder can recover the 7 channels. Off course with less quality than a 6.1 discrete channels system, because the matrix mix method is not perfect. |
27th May 2007, 13:45 | #40 | Link | |
You mean to obtain adequate mix before encoding and than set the flag? Isn't it encoder job to set adequate mix and flag at encoder time? Last edited by SealTooGreat; 27th May 2007 at 13:52. |
