20th March 2008, 13:58 | #21 | Link |
HDConvertToX author
ehm.. if you want you can KEEP inalterated the original audio track, just choosing Copy Original
now , if lame is ok.. i can only suppose a problem with aften.. i will check it! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
20th March 2008, 18:56 | #22 | Link |
Hi Buzzqw
The xvid encoding speed of the beta2 is o.k. now, thanks for fixing it. The safe-deinterlace funktion works like charme There is still a problem when using AVI-XviD as default setting: After starting the program the settings are o.k. After loading a video-file the audio bitrate slider jumps back to 112, no matter what the user's choosen before. I described it before under http://forum.doom9.org/showthread.ph...73#post1105473 Not a big thing but it would be comfortable if AutoMKV would remember these settings. |
21st March 2008, 08:30 | #25 | Link |
HDConvertToX author
@Crono141
sorry pal, but till Microsoft will not release a software capable of full 5.1 encoding, i will not support any problematic encoder BHH
21st March 2008, 10:48 | #26 | Link |
Hey guys,
Just checking in. Once again, big thanks to BHH for this great software. By the way, has anyone found ideal settings yet for .M2TS down-conversion to 720p x264/MKV? I've been experimenting with files from my videocam but I haven't found the right settings yet. -Aylwin- |
21st March 2008, 11:03 | #27 | Link | |
HDConvertToX author
BHH
21st March 2008, 11:28 | #29 | Link |
HDConvertToX author
i may suggest to post a unprocessed sample.. just to check any problem (also.. a log could help.. and even a image of the "quality issue)
BHH
21st March 2008, 14:11 | #30 | Link |
Posts: n/a
@buzzqw
Found a problem with the Suspend functionality - it assumes that windows is installed in C:\Windows drive and directory whereas in my case Windows is E: drive so I get the following error message when it attempts to suspend. Code:
Error loading c:\windows\system32\PowrProf.dll The specified module could not be found. EDIT: Strange the sources are encoding fine now whether using delayaudio or delaycut. Last edited by zacoz; 21st March 2008 at 16:50. |
21st March 2008, 14:20 | #32 | Link |
HDConvertToX author
if you put the neroaacenc_sse2.exe in \exe\besweet folder it will be silently renamed to neroaacenc.exe ...
thanks for the suspend! BHH
21st March 2008, 14:33 | #34 | Link |
HDConvertToX author
in \exe\dgindex folder launch delaycut.exe and us it for analysis
you can force automkv to use it by changing the Handle Delay in advanced settings BHH
21st March 2008, 15:09 | #35 | Link |
Hey all,
I'm having the worst time with WMV encoding! I want to put my large library of TV shows on DVD into a format that compresses easily, quickly, and streams to my Xbox. WVC1 seems to be the best choice, so I turn to trusty old AutoMKV. It errors out and says the muxed size was -1 bytes. Here's the funny thing: if I run the encoding command line option into a command prompt, it errors out. If I change the very end of the encoding string, the audio option, from 16 to 24, it encodes fine on the command prompt! I don't have a log, I'll do an encode to get one if you need an example. |
21st March 2008, 15:21 | #37 | Link |
It seems something changes in 0.96. What I said happened in 0.95, here's what I get in 0.96:
09:13:16 Dgindex CMD: C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=80 -YR=2 -AIF=[E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\VTS_01_1.VOB] -OF=[E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie] -exit -minimize 09:13:36 D2V file size: 404761 bytes 09:13:36 Audio 1: movie t80 2_0ch 192kbps delay 0ms.ac3 09:13:36 Pre Audio 1' Size: 69450240 bytes 09:13:36 Applying DelayAudio of 0 to audio file: movie t80 2_0ch 192kbps delay 0ms.ac3 09:13:36 Encoding E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie t80 2_0ch 192kbps delay 0ms.ac3 to WAV , as pre-process to WMV 09:14:26 Encoded 1' Audio Track: audio.wav 555601984 bytes 09:14:29 Number of Frames: 86732 09:14:29 Framerate: 29.970030 09:14:29 Movie length in Seconds: 2894 09:14:29 Movie Width/Height: 720/480 09:14:29 DgIndex AR: 4:3 09:16:28 Source is declared tff by a margin of 48/1. 09:16:28 Advanced Deinterlace Routines Log 09:16:28 Analyzed 501 sections of five frames 09:16:28 Found Interlace Sections: 116 23.15% 09:16:28 Found Progressive Sections:140 27.94% 09:16:28 Found Telecined Sections: 245 48.90% 09:16:28 Found Zero Mov: 27.94% 140 09:16:28 Found One Mov: 17.96% 90 09:16:28 Found Two Mov: 48.90% 245 09:16:28 Found Three Mov: 5.19% 26 09:16:28 Found Four Mov: 0.00% 0 09:16:28 Found Five Mov: 0.00% 0 09:16:28 Autoresize CMD: "C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\encoder\AVS2ASF.exe" -i "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.avs" -o "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.wmv" -framerate 29.970030 -rate 1807 -complexity 2 -maxkeydist 150 -bframes 3 -peakrate 2711 -profiletype 2 -ratecontrol 3 -vbv 180700 -motionsearchlevel 2 -mvcost 1 -mvrange 4 -dquantoption 1 -adaptiveGOP -pr "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audioencode.prx" 09:16:32 Final Muxed size: -1 bytes 09:16:32 Encoding finished: 00:03:50 elapsed time 09:16:32 ----------------------------------------------------------------------- 09:16:32 Script AutoCrop.log 09:16:32 09:16:32 Crop(6,0,712,480) 09:16:32 ----------------------------------------------------------------------- 09:16:32 Script movie.avs 09:16:32 09:16:32 #loadpluginstart 09:16:32 09:16:32 #test1 09:16:32 09:16:32 #importstart 09:16:32 09:16:32 #test2 09:16:32 09:16:32 movie = mpeg2source("E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.d2v") 09:16:32 function getOrder(clip c) { 09:16:32 order = GetParity(c) ? 1 : 0 09:16:32 Return order } 09:16:32 #filter1start 09:16:32 09:16:32 #test3 09:16:32 09:16:32 last=movie.Crop(6,0,712,480) 09:16:32 fixed_aspect = 1.318519 09:16:32 out_width = 640 09:16:32 #Aspect_Error = -1.111% 09:16:32 out_height = 480 09:16:32 #resizestart 09:16:32 09:16:32 #test4 09:16:32 09:16:32 SimpleResize(out_width,out_height) 09:16:32 #filter2start 09:16:32 09:16:32 #test5 09:16:32 09:16:32 RemoveGrain(mode=2) 09:16:32 audio=WavSource("E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audio.wav") 09:16:32 AudioDub(last,audio) 09:16:32 ----------------------------------------------------------------------- 09:16:32 Script mkvmaudio.avs 09:16:32 09:16:32 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\filter\NicAudio.dll") 09:16:32 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\filter\SoundOut.dll") 09:16:32 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\BeSweet\BassAudio.dll") 09:16:32 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\filter\FFmpegSource.dll") 09:16:32 NicAC3Source("E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie t80 2_0ch 192kbps delay 0ms.ac3") 09:16:32 DelayAudio(0.0000) 09:16:32 #Applying STEREO downmixing routines 09:16:32 function stereo(clip a) 09:16:32 { 09:16:32 flr = GetChannel(a, 1, 2) 09:16:32 fcc = GetChannel(a, 3) 09:16:32 lfe = GetChannel(a, 4) 09:16:32 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 09:16:32 mix = MergeChannels(lfc, lfc) 09:16:32 lrc = MixAudio(flr, mix, 0.2929, 1.0) 09:16:32 blr = GetChannel(a, 5, 6) 09:16:32 Return MixAudio(lrc, blr, 1.0, 0.2929) 09:16:32 } 09:16:32 # 09:16:32 6==Audiochannels() ? stereo() : last 09:16:32 function addvideo(clip c) { 09:16:32 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 09:16:32 Return audiodub(last,c) 09:16:32 } 09:16:32 Normalize() 09:16:32 09:16:32 ConvertAudioTo16bit() 09:16:32 Soundout(output="wav",type=1,autoclose=true,filename="audio.wav",showoutput=false) 09:16:32 09:16:32 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - Code:
"C:\Documents and Settings\Stephen\Desktop\AutoMKV0.96_full_beta1\exe\encoder\AVS2ASF.exe" -i "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.avs" -o "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.wmv" -framerate 29.970030 -rate 1807 -complexity 2 -maxkeydist 150 -bframes 3 -peakrate 2711 -profiletype 2 -ratecontrol 3 -vbv 180700 -motionsearchlevel 2 -mvcost 1 -mvrange 4 -dquantoption 1 -adaptiveGOP -pr "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audioencode.prx" Code:
************************************* VC-1 AVS2ASF v0.3 Encoding Sample Original Sample AVI2ASF code Copyright (C) Microsoft Corporation. All rights reserved. Avisynth, YV12 & Raw support added by Nic. ************************************* ERROR: Invalid framerate 29.970030. Failure in CVC1EncASF::Init hr = 0 VC1 SDK Error = -20 Final error code: -20 Total elapsed time in seconds = 0.000000 |
21st March 2008, 15:32 | #38 | Link |
HDConvertToX author
0.95 and 0.96 are totally different on wmv encoding..
i just need to know if in your audioencode.prx you changed somethings BHH
21st March 2008, 16:02 | #39 | Link | |
Here is my log on 0.95: Code:
09:27:21 Dgindex CMD: C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=80 -YR=2 -AIF=[E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\VTS_01_1.VOB] -OF=[E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie] -exit -minimize 09:27:50 D2V file size: 404761 bytes 09:27:50 Audio 1: movie t80 2_0ch 192kbps delay 0ms.ac3 09:27:50 Pre Audio 1' Size: 69450240 bytes 09:27:50 Applying DelayAudio of 0 to audio file: movie t80 2_0ch 192kbps delay 0ms.ac3 09:27:50 Encoding E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie t80 2_0ch 192kbps delay 0ms.ac3 to WAV , as pre-process to WMV 09:28:38 Encoded 1' Audio Track: audio.wav 555601984 bytes 09:28:40 Number of Frames: 86732 09:28:40 Framerate: 29.970030 09:28:40 Movie length in Seconds: 2894 09:28:40 Movie Width/Height: 720/480 09:28:40 DgIndex AR: 4:3 09:30:40 Source is declared tff by a margin of 48/1. 09:30:40 Advanced Deinterlace Routines Log 09:30:40 Analyzed 501 sections of five frames 09:30:40 Found Interlace Sections: 116 23.15% 09:30:40 Found Progressive Sections:140 27.94% 09:30:40 Found Telecined Sections: 245 48.90% 09:30:40 Found Zero Mov: 27.94% 140 09:30:40 Found One Mov: 17.96% 90 09:30:40 Found Two Mov: 48.90% 245 09:30:40 Found Three Mov: 5.19% 26 09:30:40 Found Four Mov: 0.00% 0 09:30:40 Found Five Mov: 0.00% 0 09:30:40 WMV CMD: cscript.exe "C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\encoder\WMCmd.vbs" -input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.avs" -output "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.wmv" -v_codec WMV9 -v_mode 3 -v_bitrate 1778253 -s_config "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\wmv_crb" -v_preset good -v_buffer 10000 -a_input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audio.wav" -a_codec WMAPRO -a_mode 1 -title "Season 1 Disc 1" -log wmv.log -year 2008 -copyright "Done with AutoMKV! 0.95c" -a_setting 192_48_2_16 09:30:47 Final Muxed size: -1 bytes 09:30:47 Encoding finished: 00:03:56 elapsed time 09:30:47 ----------------------------------------------------------------------- 09:30:47 Script AutoCrop.log 09:30:47 09:30:47 Crop(6,0,712,480) 09:30:47 ----------------------------------------------------------------------- 09:30:47 Script movie.avs 09:30:47 09:30:47 #loadpluginstart 09:30:47 09:30:47 #test1 09:30:47 09:30:47 #importstart 09:30:47 09:30:47 #test2 09:30:47 09:30:47 movie = mpeg2source("E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.d2v") 09:30:47 function getOrder(clip c) { 09:30:47 order = GetParity(c) ? 1 : 0 09:30:47 Return order } 09:30:47 #filter1start 09:30:47 09:30:47 #test3 09:30:47 09:30:47 last=movie.Crop(6,0,712,480) 09:30:47 fixed_aspect = 1.318485 09:30:47 out_width = 640 09:30:47 #Aspect_Error = -1.114% 09:30:47 out_height = 480 09:30:47 #resizestart 09:30:47 09:30:47 #test4 09:30:47 09:30:47 SimpleResize(out_width,out_height) 09:30:47 #filter2start 09:30:47 09:30:47 #test5 09:30:47 09:30:47 RemoveGrain(mode=2) 09:30:47 ----------------------------------------------------------------------- 09:30:47 Script mkvmaudio.avs 09:30:47 09:30:47 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\filter\NicAudio.dll") 09:30:47 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\filter\SoundOut.dll") 09:30:47 LoadPlugin("C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\filter\FFmpegSource.dll") 09:30:47 NicAC3Source("E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie t80 2_0ch 192kbps delay 0ms.ac3") 09:30:47 DelayAudio(0.0000) 09:30:47 #Applying STEREO downmixing routines 09:30:47 function stereo(clip a) 09:30:47 { 09:30:47 flr = GetChannel(a, 1, 2) 09:30:47 fcc = GetChannel(a, 3) 09:30:47 lfe = GetChannel(a, 4) 09:30:47 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 09:30:47 mix = MergeChannels(lfc, lfc) 09:30:47 lrc = MixAudio(flr, mix, 0.2929, 1.0) 09:30:47 blr = GetChannel(a, 5, 6) 09:30:47 Return MixAudio(lrc, blr, 1.0, 0.2929) 09:30:47 } 09:30:47 # 09:30:47 6==Audiochannels() ? stereo() : last 09:30:47 function addvideo(clip c) { 09:30:47 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 09:30:47 Return audiodub(last,c) 09:30:47 } 09:30:47 Normalize() 09:30:47 09:30:47 ConvertAudioTo16bit() 09:30:47 Soundout(output="wav",type=1,autoclose=true,filename="audio.wav",showoutput=false) 09:30:47 ----------------------------------------------------------------------- 09:30:47 Script wmv.log 09:30:47 09:30:47 Prepare to encode failed with error -1072886856 The input media format is invalid. 09:30:47 09:30:47 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - Code:
Microsoft (R) Windows Script Host Version 5.6 Copyright (C) Microsoft Corporation 1996-2001. All rights reserved. Prepare to encode failed with error -1072886856 The input media format is invalid. Code:
cscript.exe "C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\encoder\WMCmd.vbs" -input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.avs" -output "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.wmv" -v_codec WMV9 -v_mode 3 -v_bitrate 1778253 -s_config "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\wmv_crb" -v_preset good -v_buffer 10000 -a_input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audio.wav" -a_codec WMAPRO -a_mode 1 -title "Season 1 Disc 1" -log wmv.log -year 2008 -copyright "Done with AutoMKV! 0.95c" -a_setting 192_48_2_16 Code:
cscript.exe "C:\Documents and Settings\Stephen\Desktop\AutoMKV095_NORIP\exe\encoder\WMCmd.vbs" -input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.avs" -output "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\movie.wmv" -v_codec WMV9 -v_mode 3 -v_bitrate 1778253 -s_config "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\wmv_crb" -v_preset good -v_buffer 10000 -a_input "E:\Movies\TV Shows\MacGyver\Season 1 Disc 1\temp\audio.wav" -a_codec WMAPRO -a_mode 1 -title "Season 1 Disc 1" -log wmv.log -year 2008 -copyright "Done with AutoMKV! 0.95c" -a_setting 192_48_2_24 Code:
Microsoft (R) Windows Script Host Version 5.6 Copyright (C) Microsoft Corporation 1996-2001. All rights reserved. Microsoft (R) Windows Media Encoder Command Line Script Utility Copyright (C) Microsoft Corporation. All rights reserved. Title: Season 1 Disc 1 Year: 2008 Copyright: Done with AutoMKV! 0.95c Warning: Encoder failed to retrieve duration attribute from source plug-in. Trying alternate method now..... Source duration retrieved: 2893.958 seconds. ======== Begin Pass1 ======== Read: 9s (0.3%) Elapsed: 00:00:00 Left: 00:00:00 [9000x] Read: 12.8s (0.4%) Elapsed: 00:00:02 Left: 00:07:32 [6.37x] Read: 16s (0.6%) Elapsed: 00:00:04 Left: 00:11:59 [4x] Read: 19.5s (0.7%) Elapsed: 00:00:06 Left: 00:14:44 [3.25x] Read: 23.5s (0.8%) Elapsed: 00:00:08 Left: 00:16:17 [2.94x] Read: 27.2s (0.9%) Elapsed: 00:00:10 Left: 00:17:32 [2.72x] Read: 30.8s (1.1%) Elapsed: 00:00:12 Left: 00:18:37 [2.56x] Read: 34.5s (1.2%) Elapsed: 00:00:14 Left: 00:19:20 [2.46x] And it goes on... Last edited by InorganicMatter; 21st March 2008 at 16:04. |
21st March 2008, 16:07 | #40 | Link |
HDConvertToX author
... ehm.. wmcmd.vbs is NO more supported in 0.96
wmv encoding was totally change in this release BHH
automkv |
