31st March 2018, 21:02 | #8521 | Link | |
31st March 2018, 22:03 | #8522 | Link | |
-[Information] Versions --[Information] MeGUI: 2828 x86 --[Information] Update Check: stable update server --[Information] System Information ---[Information] Operating System: Windows 10 Pro 1709 x64 (10.0.16299.309) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.7 (4.7.02556) ---[Information] DPI: 125% (120/120) ---[Information] Monitor 1 ----[Information] Resolution: 1680x1050 ----[Information] Primary Screen: True
Win 10 Pro x64 |
1st April 2018, 08:34 | #8523 | Link | ||
I didn't update it though, and when I tested, it was correctly using the portable Avisynth+. Quote:
I'll try some different versions of MeGUI later on, maybe starting with a fresh installation of MeGUI, and if I discover anything interesting I'll report back. |
1st April 2018, 12:55 | #8524 | Link | ||
I hope this doesn't turn out to be an XP issue.
After testing a bunch of old MeGUI versions, I found the last MeGUI that'll use the portable Avisynth+ is version 2624. The next older version I have is 2620 and it also uses the portable Avisynth+. The next newer MeGUI I have is 2627 and it does not. Could it have anything to do with this? Quote:
1st April 2018, 17:12 | #8529 | Link | |
More help
The problem appears to be that the avi in question uses the DivX5 codec. I have tried other such files to the same effect - No Indexer. There is no problem with XVid avis which are indexed with LSmash or FFMS without difficulty. There are so few instances of DIVX5 around these days that this probably won't be that much of a hinderance. These are old files that I inherited. Interestingly The Solveig Splitter can split XVid avis but not DivX5 avis. You suggested I enable DirectShowSource which I did and AVIsource to which I could find no options in MeGUI settings. The principal reason I wanted to do all this was to add some chapters which AVIs do not support so a conversion to MKV or MP4 would be a first stage. Fortunately the somewhat less than sophisticated "AVC - All Video Converter" (freeware) was able to work with DivX5 and did a reasonable one-pass re-encode (DivX5 to Matroska). I have converted many XVid avis with MeGUI in the past and I thought I had converted DivX too (with both codecs using the .AVI extension one tends to treat them as interchangeable) but perhaps there has never been an index for DivX. If you can illuminate any of the above points then I should be grateful but if not it seems it is not the end of the world and thank you for looking at my problem. |
2nd April 2018, 15:30 | #8530 | Link | ||
mr2legs,
Until Zathor returns, maybe try changing the FourCC of an AVI to Xvid with MPEG4 Modifier to see if MeGUI will index it. That's a wild guess by the way, as I've got nothing else. You might need to post your log file. Quote:
And you can also try remuxing an AVI as MKV to see if MeGUI will then index the MKV, so you can use it as the source. |
2nd April 2018, 15:56 | #8532 | Link | |
2nd April 2018, 21:04 | #8533 | Link |
Fixed - THANKS!
Fantastic!
Just updated to MeGUI v2833 and DGindexNV 2053(20180402) and the audio file IS being placed right where it should be. Once again...THANK YOU very much!
Humanity does more than rhyme with insanity...it defines it. |
3rd April 2018, 02:46 | #8535 | Link | |
In the times we're living in it's very rewarding to see people working TOGETHER to make things work right. You and Zathor have made a very positive impression on me...I thank you for getting this program to work but even more I thank you for reminding me there are still humans out their who deserve our respect... Thank you both!
4th April 2018, 06:17 | #8537 | Link | ||
I did have the Visual C++ 2017 redistributable installed. The latest nnedi3 requires it, and it's working. The only oddity I noticed was it wasn't showing up in Add/Remove Programs, but all the same "api-ms-win" files were in the system32 folder. I re-installed it to make sure (it now shows up in Add/Remove Programs) but nothing has changed. I tried MeGUI 2830 without letting it update the runtime files, and then I updated the runtime files and MeGUI to version 2834. Same result either way. Avisynth is still showing as version 2.6 for the portable Avisynth. Thanks. Quote:
5th April 2018, 21:50 | #8538 | Link | |
6th April 2018, 13:02 | #8539 | Link |
Latest update 2834 broke DGIndex file indexer (DVD as source), you cannot set custom path or filename anymore.
Click Output and try doing any changes or just click Open it gives you error File not found, which doesn't make sense at all. You're not opening a file, you're saving a .d2v file ready for a job. It works if you click Queue, but that's not a solution for a DVD with multiple PGCs, you want to give custom paths and names. update: on top of that, you cannot go back to Stable update server from Developmental, saving/exiting/restarting the application always resets to Developmental server. Last edited by rhaz; 6th April 2018 at 13:05. |
6th April 2018, 18:22 | #8540 | Link | |
Are you using the x64 build of MeGUI? Then this is to be expected as there is no stable build yet. |
megui |
