Old 17th November 2011, 13:27   #1041  |  Link
Zenitram
Originally Posted by LoRd_MuldeR View Post
With v0.7.49 MediaInfo reported the duration of my Wave file just fine, while with v0.7.51 it does not
I change this part of the code for some other issues. All my sample files have duration, so I need a sample with this problem.
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 18th November 2011, 00:13   #1042  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It's a simple Wave+CUE file that I extracted with EAC directly from my original CD (using "Image" mode), so it should be easy to create such file yourself.
(Can't upload such big files with my ultra-slow internet connection)
Old 18th November 2011, 00:16   #1043  |  Link
Zenitram
It's a simple Wave+CUE file that I extracted with EAC directly from my original CD (using "Image" mode), so it should be easy to create such file yourself.connection)
I don't have a CD player, not so easy for me... I only need the first 10 KB of the file.
Old 18th November 2011, 00:28   #1044  |  Link
LoRd_MuldeR
Software Developer
Here we go
(Yes, the first 4 seconds are silent, but that's not very unusual with Audio CD's, I think)
File Type: zip Dump.zip (319 Bytes, 22 views)
Old 18th November 2011, 09:49   #1045  |  Link
Zenitram
I apologize for the mess, actually I was testing with my development version, not the official version, and I already corrected it, this is the reason I was not seeing problems on my files. So: it is OK, for next version.
Old 18th November 2011, 10:23   #1046  |  Link
LoRd_MuldeR
Software Developer
Thank you once again!
(BTW: Any idea yet when the next version is to be expected?)
Old 19th November 2011, 10:15   #1047  |  Link
Zenitram
2 weeks, I think. No big changes in the code currently, I am mainly on another (related) project for few weeks.
Old 19th November 2011, 16:13   #1048  |  Link
LoRd_MuldeR
Software Developer
Hmm, I just compiled the latest MediaInfo from SVN Trunk, but it seems there is another issue hiding somewhere:
The 32-Bit build detects the Duration of my Wave file just fine, while the 64-Bit build does not. Maybe some "32- vs. 64-Bit" data type size issue?
Old 20th November 2011, 00:53   #1049  |  Link
chaddawkins
I appreciate MediaInfo, thank you.
I build a codec pack for myself; I recently tried to update the MediaInfo_InfoTip.dll and MediaInfo.dll files but now MediaInfo_InfoTip.dll won't register. Did you change something to not allow this?
I have been using MediaInfo_InfoTip.dll file version 0.7.8.0 and modified date is December ‎09, ‎2008. I use Inno to compile and my registry entry looks like this:
[Files]
Source: {app}\InfoTip\MediaInfo.dll; DestDir: {app}\MediaInfo; Flags: uninsrestartdelete; Check: not IsWin64
Source: {app}\InfoTip\MediaInfo_InfoTip.dll; DestDir: {app}\MediaInfo; Flags: regserver uninsrestartdelete; Check: not IsWin64
Source: {app}\InfoTip\x64\MediaInfo.dll; DestDir: {app}\MediaInfo; Flags: uninsrestartdelete; Check: IsWin64
Source: {app}\InfoTip\x64\MediaInfo_InfoTip.dll; DestDir: {app}\MediaInfo; Flags: regserver uninsrestartdelete; Check: IsWin64
BTW, these are the only files that I use; along with the correct registry entries I get the shell extension.
chaddawkins is offline   Reply With Quote
Old 20th November 2011, 18:51   #1050  |  Link
Zenitram
I remember I changed something in the Windows explorer interface, but I don't remember exactly which stuff. I don't use the DLL registration directly now (I update the registry directly, more possibilities). I see that regsvr32 registration fails, registration is not something I consider as nothing, but this is not my priority to correct it. I will review the whole code some day, but no ETA.
In the meanwhile, you can update only MediaInfo.dll (no need to update MediaInfo_InfoTip.dll), the binary interface of MadiaInfo.dll has not changed since 0.7.0.0 (in 2005).
Old 20th November 2011, 19:48   #1051  |  Link
LoRd_MuldeR
Software Developer
Any ideas about the 64-Bit issue yet?
Old 20th November 2011, 19:59   #1052  |  Link
Zenitram
No. I can reproduce the issue, but I still don't find the reason (debug version works well...)
Old 20th November 2011, 20:18   #1053  |  Link
LoRd_MuldeR
Software Developer
Thank you for confirming the problem! So it's definitely not a build issue on my side, at least.
Old 22nd November 2011, 05:54   #1054  |  Link
Toddler Naruto
Playful Explorer
Toddler Naruto's Avatar
Does it take so much time to right click on a file and select "MediaInfo"?
That's not the point. I want MediaInfo to minimize to system tray instead of Taskbar while is it running.
Toddler Naruto is offline   Reply With Quote
Old 22nd November 2011, 08:31   #1055  |  Link
Zenitram
That's the point. MediaInfo never "runs", it takes few seconds to analyze a file you right click, you don't have the time to minimize it (this is not a compression program taking 10 hours to run). You never said the reason you need to minimize to tray something not running, instead of only right click on the file and select "MediaInfo".
Anyway, exactly same reply than Mosu + if you really need it and if you are not able to code it, you can buy professionnal services from me.
Old 29th November 2011, 03:21   #1056  |  Link
chaddawkins
that works just fine, thank you
Old 17th December 2011, 18:34   #1057  |  Link
pascalwil
Hi there
Sorry if I missed it but I don't seem to find the answer in the previous pages.
I get a reported delay for the AAC track of an MKV of 13 ms relative to video.
And Eac3to reports the same delay. Just to mention they are in line since I've read about this issue between MediaInfo & Eac3to.
Anyway my question is what to make of this delay?
I need to convert AAC to AC3 and add new AC3 to MKV for my standalone player.
Shall I set audio delay to 13 ms (like reported for AAC) in mkvmerge? Or no delay for AC3 will do it?
Thanks
pascalwil is offline   Reply With Quote
Old 17th December 2011, 18:37   #1058  |  Link
Zenitram
You take care to have the same delay in your converted file (so: yes, you put this value into mkvmerge corresponding field), else audio will not be in sync.
Old 17th December 2011, 19:29   #1059  |  Link
pascalwil
Thanks a lot Zenitram
I've done it both ways with a 13 ms delay and without any delay for the AC3
I can't tell about the audio being out of sync in the case of no delay (I guess 13 ms is too small to be spotted).
But with your clarification I know how to do it the right way using info from MediaInfo.
BTW thanks for such a good tool.
Cheers
Old 18th December 2011, 22:00   #1060  |  Link
Zenitram
I wanted to work on this issue (yeah, delay was long... ), but all my files are OK now with the current SVN. Could you confirm it? If there are still some issues on your side, I think I need a sample file.
