Old 17th August 2011, 22:41   #981  |  Link
Zenitram
Originally Posted by LoRd_MuldeR View Post
Now with Windows 2000 compatibility fix
What is wrong with my official build and Windows 2000?
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 17th August 2011, 23:07   #982  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If you still use MSVC 9.0 to make your builds, then probably nothing.
But I use MSVC 10.0 for quite some now and therefore the binaries won't run on Windows 2000 without the fix
See also:
http://mulder.googlecode.com/svn/tru...Lib/README.txt
Old 17th August 2011, 23:19   #983  |  Link
Zenitram
I use MSVC 9.0 for CLI versions of MediaInfo for this reason actually, I was afraid you mean that my version was not working anymore with Windows 2000.
Worse, I use MSVC 8.0 (MSVC 2005!) for 32-bit DLL in order to be compatible with Windows 95 ;-) (yes, some crazy people still use Windows 95, and they use up to date MediaInfo... I force myself not to try to understand this)
(64-bit versions are built with MSVC 10 because all 64-bit OS are currently supported).
Such limitations from Microsoft is a bit frustrating...
Old 17th August 2011, 23:36   #984  |  Link
LoRd_MuldeR
Software Developer
It actually is pretty easy to get MSVC 10.0 binaries running under Windows 2000.
In my test even complex stuff, such as the Qt-framework, appears to work flawlessly this way.
People even try to run Win32 GUI applications on DOS, using the HX Extender
To be fair, the backward compatibility provided by Microsoft is pretty good compared to, let's say, Apple
Old 18th August 2011, 01:00   #985  |  Link
smok3
brontosaurusrex
smok3's Avatar
question, this:
head -c 100000 filebig.ext > filesmall.ext
mediainfo filesmall.ext = mediainfo filebig.ext
will fail in what circumstances (if any) ?
certain other member
smok3 is offline   Reply With Quote
Old 18th August 2011, 09:57   #986  |  Link
Zenitram
May fail.
May not fail.
This depends of the content of the file (if header is at beginning or at end of the file, if index is included in the partial file...), format (for MPEG-TS, you'll have the duration of the partial file...).
MediaInfo is designed to provide maximum info it can with partial files. But there is no list of circumstances, currently (nobody has requested such thing).
Old 18th August 2011, 11:13   #987  |  Link
smok3
brontosaurusrex
smok3's Avatar
just thinkering with the idea to make a sort of a web app, but so far i can't see a php/http upload way which would stop uploading when certain file size is reached.
p.s. my usual avi and mp4 files do pass the head test.
Old 18th August 2011, 11:26   #988  |  Link
Zenitram
This is in the pipe on my side, but with a C++ server, in order to have fine control about when and how to cut the connexion (MediaInfo DLL API provides fine control of when to cut instead of a hard-coded value)
You are lucky. This is not the case of all the files I have.
Old 26th August 2011, 17:02   #989  |  Link
Brazil2
Zenitram, you may want to check this:
http://forum.doom9.org/showthread.ph...12#post1522012
http://forum.doom9.org/showthread.ph...35#post1522035
Brazil2 is offline   Reply With Quote
Old 27th August 2011, 20:45   #990  |  Link
Zenitram
Done. Thanks for reporting the issue to me.
Old 20th September 2011, 10:08   #991  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by Kurtnoise View Post
cdda support is on the way...
I wait ;-)
http://sourceforge.net/tracker/index...62&atid=581183
Old 20th September 2011, 10:10   #992  |  Link
Zenitram
Don't worry, I am on it (several disagreements ;-) )
Old 21st September 2011, 13:50   #993  |  Link
Zenitram
Are you going to add support for .y4m ?
Already done since 0.7.45:
General
Complete name : akiyo_cif.y4m
Format : YUV4MPEG2
File size : 43.5 MiB
Video
Format : YUV
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : PAL
Color space : YUV
Scan type : Progressive
Compression mode : Lossless
Edit: I remarked that Windows explorer integration is not done for .y4m, I'll add it.
Old 24th September 2011, 15:36   #994  |  Link
LoRd_MuldeR
Software Developer
Thanks for the new version.
However there still is a longstanding "cosmetic" bug:
D:\SVN\Tools\mediainfo_0.7.50_AllInclusive>MediaInfo-x64.exe --Help
MediaInfo Command line,
MediaInfoLib - v0.7.50Usage: "MediaInfo [-Options...] FileName1 [Filename2...]"
I think there should be a linebreak or at least a whitespace after the version number
Old 25th September 2011, 13:19   #995  |  Link
iwod
Will MediaTab gets updated or is it an entirely separate project?
iwod is offline   Reply With Quote
Old 26th September 2011, 12:29   #996  |  Link
Zenitram
Oups. Windows Unicode only. Corrected.
This is a third-party project, I am not involved in it. Anyway, I asked its author to do a new version.
Old 27th September 2011, 10:05   #997  |  Link
Zenitram
From its author (he can not post here due to the stupid 5-day "you must wait" obligation for new registerd users):
"I have some ideas for a next version (including unicode file names support) but I'm actually a little bit busy. The project is alive but next version has no date release. Execute the updater once at week "
Old 27th September 2011, 21:08   #998  |  Link
LoRd_MuldeR
Software Developer
Zenitram, what do you think about a more general fix for stdout/stderr and cout/cerr on Win32?
http://pastie.org/private/a5cz9atppnrcgcwyuega
Old 28th September 2011, 00:29   #999  |  Link
Zenitram
This is a bit cryptic for me .
OK, I take it. In SVN.
Old 28th September 2011, 00:41   #1000  |  Link
LoRd_MuldeR
Software Developer
It definitely is cryptic
Unfortunately the only way to convert an operating system file HANDLE into a normal C-style FILE pointer (as needed to replace 'stdout' and fix the 'cout' object) is converting it into a CRT file descriptor first, by calling _open_osfhandle(), and then converting it further to a FILE pointer, by calling _fdopen(). For the 'cout' we additionally need to wrap it into an std::filebuf object...
But it's more or less what Microsoft recommends, except that we explicitly do not want "text" (aka "UTF-8 mangling") mode:
http://support.microsoft.com/default...b;en-us;105305
