24th October 2019, 20:16 | #41 | Link |
If you run the mpv.net setup and after that use the default apps dialog then I believe all extensions work, or at least it is trivial to make them work and you don't have to do that often, most apps are decent enough not to enable file type registration by default. I've not having problems with the new behavior, maybe it's not a bad thing that windows don't allow hijacking extensions without user confirmation, as far as I know this protection has not been cracked.
24th October 2019, 20:48 | #42 | Link |
I wouldn't call it protection, because it's not that apps do it on their own (which is bad) it's also that MS removed the option from user to do it as a choice, intensionally.
It's the old good MS forcing things on users that they don't want and removing options that they do want. If there is a portable version of mpv I could try it.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
24th October 2019, 21:24 | #43 | Link |
I believe there is some hash value only Windows can create so it can be called protection.
mpv does not have an installer, you can get it here: https://mpv.io/installation/ Docs are here: https://mpv.io/manual/master/ It takes some commitment to understand and use it successfully. My frontend is still mpv and makes few things easier: https://github.com/stax76/mpv.net
25th October 2019, 06:19 | #44 | Link | |
I will use MPV later today. Thank you.
25th October 2019, 08:19 | #45 | Link |
Well, the batch script of installation of various extensions for MPV certainly doesn't work for registration of those extensions.
It just opens the Default Apps of Win10, so it can't bring back the old functionality of previous control panel. Now, regarding the MPV and yours MPV.NET...well...it's a weird, interesting player but with a 228 pages manual
25th October 2019, 09:34 | #46 | Link |
For testing a player it's maybe better to keep the file associations for the current player and test it with 'Open with', or 'Open with++' or drag and drop or something like that.
Maybe you need to run the script with elevated privileges, if you have both issues with MediaInfo.NET and the mpv script then maybe there is something wrong with your system or you are doing something wrong. If you configure mpv then you need to search and navigate the manual, the best way doing this is using the single page HTML manual so you can do a full text search using the browser, it has 7000 lines, I've never heard that somebody had regrets learning it, you not only learn how to use mpv, you learn about software in general.
25th October 2019, 13:29 | #47 | Link | ||
I just gave that script a chance, but it didn't work obviously. It registered itself only to the orphan extensions, just like MediaInfoGUI.NET If it's impossible to bring back the old functionality of the control panel, then the only solution would be to register a media player as default media player and leave Windows and not you to decide which extensions belong to that player. I haven't done this yet to be honest, I was looking for the old functionality even as a hack. Quote:
I have even abandoned my old love of PotPlayer for MPC-HC. Not so much free time for reading manuals these days!
25th October 2019, 15:31 | #48 | Link |
It works but you need to change the default app after the registration in Windows 10 at: Apps > Default Apps
mpc-be automatically opens the default apps page after the registration by calling ms-settings:defaultapps, mpv.net has a button to open it in its OS Setup dialog. For MediaInfo.NET it's not necessary as it doesn't change the default app but only add a verb (menu item).
25th October 2019, 19:10 | #49 | Link |
After running the script and changing the default video/audio player to mpv, I got only 18 extensions supported by app but not registered to the app.
I wrote only, because MPC-HC leaves a lot more unregistered extensions than those it supports. Yours mpv.net leaves only 8 unregistered extensions but I think it supports less extensions than mpv. MPC-HC supports a lot more extensions than both mpv and mpv.net. BTW, mpv is a modern player supporting D3D11VA video decoding and your version of mpv.net is user friendly too. While waiting for the next version of MPC-HC with - hopefully - embedded support of mpcVR renderer, I will keep mpv.net as my default player.
27th October 2019, 17:18 | #50 | Link |
5.1 --- - new setting 'Theme' added with 'Light', 'Dark' and 'System' option, theme colors are not hard coded but defined in Settings.xml - fix for window starting in background on very first start - file association uninstall scans now all extensions and not only the ones that are defined in the settings - encoding settings are now alphabetically ordered - compact summary is no longer limited to raw view, it's now also available in normal view https://github.com/stax76/MediaInfo.NET
28th October 2019, 21:55 | #51 | Link |
I did a last polishing today before work on staxrip and mpv.net continues.
5.2 --- - in the settings dialog the layout was improved, the font picker was replaced with a drop down and a link was added to open the settings folder - using raw view, MediaInfo is now queried only once instead of twice which is marginally more efficient - on startup MediaInfo.NET registers itself at HKCU\Software\Microsoft\Windows\CurrentVersion\App Paths\ which enables third party apps to find and start MediaInfo.NET - a assembly title attribute was added so the shell will use MediaInfo.NET instead of MediaInfoNET (for instance in the Explorer 'Open with' menu) - the website was improved and added to the context menu - the about dialog shows now the MediaInfo version - all message boxes were migrated to use the TaskDialog API which has a improved presentation and copy and support links in case of an error screenshot of the improved settings dialog: https://i.postimg.cc/xTY4yYGb/Screenshot-44.png Next staxrip build will integrate MediaInfo.NET. runtimes: https://dotnet.microsoft.com/downloa...re/3.0/runtime website: https://github.com/stax76/MediaInfo.NET
30th October 2019, 16:05 | #52 | Link |
5.3 --- - in normal view language names are now shown instead of two letter language codes - MediaInfo API spelling errors were corrected - duplicated entries are now removed - critical fix: file associations did not work when UserChoice key was defined runtimes: https://dotnet.microsoft.com/downloa...re/3.0/runtime website: https://github.com/stax76/MediaInfo.NET
1st November 2019, 19:10 | #54 | Link |
You're welcome!
2nd December 2019, 02:19 | #55 | Link |
5.4.0.0 ------- - new: the track navigation tab bar was only showing the format family like DTS, now it's showing the exact format like DTS XLL - new: update check, must first be enabled in settings - new: update feature, requires PowerShell 5 and curl, an up to date Windows 10 system has both included https://dotnet.microsoft.com/downloa...re/3.0/runtime website: https://github.com/stax76/MediaInfo.NET
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 2nd December 2019 at 02:26. |
8th December 2019, 02:29 | #56 | Link |
Cat
Thanks
MediaInfo.NET is just incredible, thank you again very much stax76! Drag and drop. Customizable (fonts, dark mode, etc). Beautiful. Works great in Windows "Send To" menu. Previously using MediaInfo "lite" (by Atak Snajpera).
Nitpicks: The "menu" section seems formatted oddly: Chapter times read "00[30 spaces]:[1 space]00:00.000" but perhaps should be "00:00:00.000" with no spaces. Then chapter names could be aligned nicely like rest of text. Also: there in no mention of "menu" in top summary, maybe by design though. And: (at risk of being slapped) top summary for "text" is not labeled "T" but "S" (for subtitle). Last edited by OAKside; 8th December 2019 at 02:36. |
7th March 2020, 16:07 | #57 | Link |
Thanks for the awesome feedback, new build should have everything covered!
Please note that it's a 32bit only app now. https://github.com/stax76/MediaInfo....es/tag/5.5.0.0 https://dotnet.microsoft.com/downloa...urrent/runtime
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 7th March 2020 at 16:18. |
7th March 2020, 20:21 | #58 | Link |
App Digger
Does it mean that I need to install .NET Core Runtime x86 along with x64?
I updated .NET Core Runtime x64 to the latest one, but 5.5.0.0 doesn't seem to launch at all. I can't see any instance of MediaInfo.NET on Task Manager. I rolled back to the previous version (5.4.0.0), and it works nicely (without x86). |
7th March 2020, 21:17 | #59 | Link | |
Generally .NET code can be built against x64, x86 or Any Platform which works on both due to the just in time compiler, the MediaInfo library is native though so it's either x64 or x86. WebAssembly which can also be used outside the web is interesting because it's fast but also using just in time compilation so works on any platform. Core or .NET 5 as it will be called later this year has also a mode where the entire runtime is included and it appears as a regular application that does not need a runtime, right now the files are too big, I think it involves a complicated process called tree shaking and will be one of the most valuable features of the new platform once it's ready. Going x86 only is a way to achieve simplicity because Windows supports both side by side and for certain types of apps it's not making a real difference.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 7th March 2020 at 21:33. |
7th March 2020, 21:54 | #60 | Link |
I've indeed missed updating the target Core platform from 3.0 to 3.1 and just made another release:
5.5.0.0 -> Core 3.0 x86 5.6.0.0 -> Core 3.1 x86 https://github.com/stax76/MediaInfo.NET/releases https://dotnet.microsoft.com/downloa...urrent/runtime
