Old 10th October 2017, 20:15   #41  |  Link
zurv
Here is the auto benchmark run on (windows 10 x64)
i9-7980xe @ 4.7 (with AVX offset of 12 and avx512 of 15)
|     CPU             |   x264  |   x265  |   LAVC  |   auto  |   MMX2  |    SSE  |   SSE2  |   SSE3  |   SSE4  |    AVX  |   AVX2  |    All  |
|  Core i9-7980XE  |  44.89  |   9.34  |   186  |   6.84  |   2.48  |    2.46  |   3.69  |   3.86  |   5.25  |    5.75  |   6.71  |    N/A  |
I'm still playing around with the offsets. But 18 cores + avx. stuff gets HOT (mainly the VRMs)
zurv is offline   Reply With Quote
Old 15th October 2017, 12:39   #42  |  Link
NikosD
With an all core turbo clock@4.7 GHz you are approaching a 600W power consumption.
Have you delidded the CPU ?
What is the translation of AVX offset of 12 in clock speed ?
I'm assuming that you have a good liquid cooler in order to go that high.
Win 10 x64 (18363.476) - Core i3-9100F - nVidia 1660 (441.41)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 15th October 2017, 13:06   #43  |  Link
nevcairiel
Every offset reduces the clock by 100MHz, so thats 1200 less in AVX2 mode.
Old 15th October 2017, 16:46   #44  |  Link
zurv
oddly the 7980 is ez'r to cool than the 7900 (i have that too), the die is much larger on the 7980. Yes, i delided but it wasn't as helpful as with other CPUs (maybe 5C drop)
The issue with the AVX stuff (and 512 even more) is the power draw. Cooling the CPU isn't a problem, but so much power is going through the CPU package and VRM.. ugh. (I have a mono block too.) (Mesh is a problem too as the jacks up power usage.. normally i'd want to run it at 32 (default is 24.) But AVX + higher mesh is monster power/heat.
Also, quick stuff (even this benchmark) is fine. The hard part is something that will be stable for a long time. Doing a 4k video (game capture lossless) for 30min in x264 is still 2-3 hours. (hrmm.. video that no one really look at.. and YT totally re-encodes to pooo quality.. so maybe i shouldn't be using "very slow"... )
I wonder how much faster avx is vs not using it. Ie, over 18 cores I'm losing over 18gigs of speed when using avx. I'm assuming that it is worth it.
(also, the default speed for the 7980 is 2.6ghz. It OCs really well. Most people are getting 4.5-.49 on the OC. AVX is a problem, but most don't use that. That said, the new Time Spy 4k 3dmark test does.)
Old 15th October 2017, 18:27   #45  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
If you do not care about AVX performance then maybe you should just have bought ThreadRipper 1950x for 2 times less. In non-AVX tasks difference between those two is not big.
Old 15th October 2017, 18:35   #46  |  Link
zurv
that is a silly reply. One could just have the encoder not use avx. clock to clock intel is faster and there are more core on the 7980. (also the 7980 OCs much higher than the threadripper too. So more cores, clock to clock faster and faster clocks.) perf matters more than cost. Other than encoding nothing i do uses avx. So even for single core usages this CPU is better for me than threadripper. (the 7980 OCs just as well as the 7900 (which i also have) ... well.. other than avx )
AVX 512 is a big deal (or so i'm told ) the i9s are the only desktop CPU with it. I'm not fully clear by that is but i haven't looked into it much.
Old 15th October 2017, 19:06   #47  |  Link
Atak_Snajpera
AMD 1 core+SMT=Intel 1 core+HT
You will have to wait another 10 years to see decent support in apps for this SIMD instructions. AVX-512 for now is just a placebo.
Old 15th October 2017, 19:16   #48  |  Link
NikosD
AVX512 is simply not existent and as Atak_Snajpera said in the previous post, don't expect it soon.
Anandtech.com is looking for apps leveraging AVX512 since i9 7900X launch and they didn't find any to test it.
Also, as i asked you before, do you use an AIO liquid cooler for the 18core ?
Old 27th December 2017, 07:38   #49  |  Link
littleD
littleD's Avatar
Not really impressive but good to know
|  Core i5-7200U  |  4.79  |   0.94  |    35  |   0.78  |   0.23  |    0.23  |   0.36  |   0.39  |   0.61  |    0.61  |   0.77  |    N/A  |
littleD is offline   Reply With Quote
Old 3rd January 2018, 18:41   #50  |  Link
Boulder
Pig on the wing
Boulder's Avatar
So what is the current optimal bang for buck CPU to get if 95% of all use is encoding with x265 and processing with Vapoursynth? I'm unsure about the current reasonable prices because Ryzens and i7's are often quite close?
Old 7th January 2018, 17:37   #51  |  Link
JMX
|  Core i9-7900X      |  29.37  |   5.47  |   145   |   4.38  |  1.35   |    1.35 |   2.14  |   2.32  |   3.49  |   3.50  |   4.30  |    N/A  |
no overclocking of any kind - just a stock computer
some error messages while the auto script ran but I didn't really payed attention.
JMX is offline   Reply With Quote
Old 26th April 2018, 01:03   #52  |  Link
RanmaCanada
Anyone with a Ryzen+ want to run this bench so we can compare apples to apples? It would be interesting to see it benched properly as the review sites aren't doing x265 benchmarks justice.
Old 26th April 2018, 15:12   #53  |  Link
TEB
av_interleaved_write_frame(): Invalid argument
Error writing trailer of pipe:: Invalid argument00:00:04.37 bitrate=4777574.4kbits/s speed=0.123x
frame= 105 fps=2.3 q=-0.0 Lsize= 2551500kB time=00:00:04.37 bitrate=4777574.4kbits/s speed=0.094x
video:2551500kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
Conversion failed!
|  Ryzen 7 1800X      |  19.96  |   2.85  |    67  |   2.08  |   1.02  |    1.03  |   1.52  |   1.58  |   1.91  |   2.09  |   2.16  |    N/A  |
TEB is offline   Reply With Quote
Old 17th June 2018, 05:59   #54  |  Link
dex8472
Hi guys, here's my benchmark. Stock config.
Ryzen 7 2700x @ 3.70 GHz
i7-4770k @ 3.50 GHz
i7-4790k @ 4 GHz
|  Ryzen 7 2700X      |  21.62  |   3.51  |   124   |   2.78  |   1.14  |   1.15  |   1.75  |   1.90  |   2.72  |   2.74  |   2.84  |    N/A  |
|  Core i7-4770K      |  10.03  |   1.84  |    64   |   1.50  |   0.42  |   0.42  |   0.69  |   0.75  |   1.16  |   1.19  |   1.47  |    N/A  |
|  Core i7-4790K      |  10.76  |   2.03  |    65   |   1.59  |   0.47  |   0.47  |   0.77  |   0.84  |   1.29  |   1.31  |   1.58  |    N/A  |
dex8472 is offline   Reply With Quote
Old 21st July 2018, 07:06   #55  |  Link
RanmaCanada
Is there any way we can get the benchmark updated, as several people with Epyc machines have tried to run it, and it will not run.
Old 21st July 2018, 09:49   #56  |  Link
NikosD
If it doesn't run properly for EPYC it won't run for Threadripper 2, too.
Old 23rd July 2018, 06:28   #57  |  Link
DotJun
Will you be adding avx512 to the benchmark?
DotJun is offline   Reply With Quote
Old 23rd July 2018, 10:34   #58  |  Link
Atak_Snajpera
Why???
Old 23rd July 2018, 10:35   #59  |  Link
Atak_Snajpera
avx512 is almost useless
https://networkbuilders.intel.com/do...nsions-512.pdf
Old 23rd July 2018, 13:13   #60  |  Link
NikosD
Why???
Due to the similar many core architecture I guess.
Unless of course EPYC has a different problem.
